Calbears
Hi All,
I just recently joined the M3 forum and wanted to know if any of you have low profile tires on 19'' rims, 235F/285R and what psi are you putting in? When I got the car it had 35 psi and after going to some independent car shop for oil change the flat tire sensor came on. I tried to reset but it would come back on within a few minutes. What didn't make sense was after more psi was put into the tire the sensor for flat tire came on? Anyone ever had this happen before? Apparently the indy shop put in 42 psi on all 4 tires, anyone have any recommendation for low profile tires with the above dimension and recommended psi that's in median range? Thanks! |
2004 E46 M3
![]() Location: Costa Mesa
I run around 38psi
open your manual and read how to reset the tire pressure warning (I forget how atm.) The e46 M does not use sensors in the tire, it uses wheel speed sensors.
__________________ 2004 Mystic Blau Imola Rot ///M3 Coupe SMG Other Rides 73- 240z - L28 Block w e31 heads - prepping as a track toy 95- Legend Coupe - C32A5 block - totaled while parked 96- Dodge Ram 4x4 5.9 - totaled while parked in a seperate incident |
wants +28 TE37s
42psi cold? I go with 36psi cold but if you're within 34-38 you'll be good IMO...
CB/GRAY Last edited by RynoS54; Fri, Apr-01-2011 at 07:57:57 AM. |
#4 | |
#5 |
35-36 square, cold. 42 cold is a sign that someone doesn't know what they are doing - assuming you aren't hauling 3-4 passengers all the time.
If you have a TPS warning - you have inconsistent same-axle pressures. Check them.
#6 |
38psi all around FTW.
Current: 2005 Titaniumsilber M3 Coupe Dinan Stage 1 software UUC EVO 3 + DSSR Look Ma! No sunroof! "Wood" trim! Unpowered Cloth Seats! NAV! Michelin Pilot Super Sports on OEM 19's "If everything is under control, you are just not driving fast enough!" - Sir Stirling Moss |
#7 | |
I'm THERE!
![]() Location: I.E.
I run 35F and 36R.
2006 TiAg ///M3 Coupe I so wanted to keep it stock ![]() Huper Optik CS40 Complete CS50 Front WS///VMR Gunmetal CSL Reps 19' Ultra-staggard///Matte black grill\gills///V1 hard-wired///Eibach Pro-kit///Dinan exhaust |
#8 |
Resident User
![]() Location: SEFLa
i guess im the only running more psi in the fronts than the rears- 37f/35r cold for street use - i feel the more psi in the fronts helps acceleration, since the car is pushing rather than pulling (RWD)- so I take off from the inertia of the front tires
#9 | |
![]() Location: Eagleville, PA
i go by what I've seen as the prevailing numbers found in other threads like this:
39f/37r
#10 | |
2004 E46 M3
Also never heard that is true on other cars.
