Old Sun, Feb-27-2011, 04:44:02 PM   #1
95AWM3
Rotary Abortionist
Reputation: 0 95AWM3 is on a distinguished road
Default another cranks but no start problem. help
Hello to all on the forums, I am new to this one. I have searched all the key phrases I would think would help but they havent...
Rundown of problem:
I own a 1995 M3, with 180k on the car and a supposed rebuild at 100k.
I am in process to have a full rebuild done SOON, but for now this is my DD.
Problem: Friday, drove to a friends to stay the night to carpool to work next morning, car ran fine. Parked it overnight in his driveway, had no problems. Saturday morning at 630am, start the car just fine, no hesitation at all. Fired right up, let idle for maybe a min and moved to the next spot over so his girlfriend could get out of the garage. Shut car off, go to work etc etc. Go to leave to go home that night around 11pm. Car will crank and crank, no fire up though. it sounds very boggy but it still hasnt caught and idled since. I am very limited for now but want to post this ASAP.
Fuses all appear to be good, battery has power, and I can hear the fuel pump come on when I turn the key to the number 2 spot.
For the most part my searches have turned up threads about the 1st time it wont catch and hold idle but the 2nd time it will always work. mine will not.
When I have a friend crank it, I can smell gas and feel the exhaust pulses from my exhaust still. Which leads me to belive this is a spark related issue...
When i search for this issue it comes up with moslty CPS replacements if the code has been thrown.
I do not see that a code has been thrown though, the OBC doesnt register any problems, and there wasnt a code thrown yesterday morning. If i get an odb1 tester will it still register even if theres not a CEL present?
I live in the pacific northwest of Washington state, Tacoma to be exact, currently car is in Bonney lake. We have been experiencing zero cold weather lately, and I was wondering if this could attribute to this condition? By cold weather I mean getting to 15 degrees at night and we have had snow flurries the last week.
Any help with this is greatly appreciated! Sorry if this is a long post, or has dumb questions in it. I am new to BMW's at this point, not new to working on cars as ive owned a 2nd gen rx7 for 4 years.
Sincerely
-pat
Jump to top 95AWM3 is offline   Reply With Quote
Old Sun, Feb-27-2011, 05:03:22 PM   #2
n1kogr
n1kogr's Avatar
Reputation: 0 n1kogr is on a distinguished road
Default Re: another cranks but no start problem. help
ive experienced that problem with a 740il. Replaced fuel pump and fuel filter turned out to be a crank sensor. (easy fix)
LSB e46 m3 [daily
Cosmos e36 m3/4/5 [sold
Jump to top n1kogr is offline   Reply With Quote
Old Sun, Feb-27-2011, 05:14:56 PM   #3
bmray22
Reputation: 0 bmray22 is on a distinguished road
flooded-spark plugs are probably wet with gas. i'd pull them out and dry/clean them or replace them if its been awhile.
Jump to top bmray22 is offline   Reply With Quote
Old Sun, Feb-27-2011, 05:27:49 PM   #4
das borgen
Off-Topic King
das borgen's Avatar
Reputation: 0 das borgen is on a distinguished road
this sounds like a textbook crank position sensor problem
here is how to replace
http://www.pelicanparts.com/bmw/tech...aft-Sensor.htm
here is where to buy
http://www.autohausaz.com/search/pro...er=12141726066
the CPS is on all OBD1 6cyl E36 (325, M3 92-95) and OBD1 E34 525i
alternatively, this can be a fuel problem....test fuel pressure...it should be somewhere between 43 and 54 psi....I can t remember what it s supposed to be and i m too lazy to go down 2 flights of stairs to look in the service manual
Jump to top das borgen is offline   Reply With Quote
Old Sun, Feb-27-2011, 08:49:56 PM   #5
95AWM3
Rotary Abortionist
Thank you all for the fast replies...
I just changed the spark plugs, cylinder 5 had a small amount of oil in it.
Still that didnt help, ordering the CPS tonight and I will keep it updated when I install it.
Thanks again
-pat
just another supercharged e36...
Old Mon, Feb-28-2011, 02:46:42 PM   #6
turbo5s
Reputation: 0 turbo5s is on a distinguished road
Will the DME still operate the injetors without a CPS signal?
when you say "zero cold weather".., maybe the IACV stuck shut? I know if it's stuck 1/4 open or a little less, my engine won't hold idle, it starts and runs about 1 second before stalling unless I give it gas. However it would start reliably. (But say it was stuck completely shut)
Sounds boggy you say..? Any less boggy if you crack the throttle open?
you won't get a cps code if the car wasn't running when the sensor died..
Jump to top turbo5s is offline   Reply With Quote
Old Tue, Mar-01-2011, 09:37:49 PM   #7
95AWM3
Rotary Abortionist
Boggy like when cranking it will try and catch to old idle. No on the throttle helping at all. But my tach only makes it to about 200 then nothing. Cps will be in tomorrow and I will report.
Old Tue, Mar-01-2011, 10:47:08 PM   #8
marvinstockman
Reputation: 0 marvinstockman is on a distinguished road
Next time try a squirt of starting fluid or carb cleaner in the intake. If it starts, your problem is electrical. If not, probably fuel or possible coded key issue.
Don't use too much starter fluid, just a couple of squirts.
Jump to top marvinstockman is offline   Reply With Quote
Old Wed, Mar-02-2011, 12:15:10 PM   #9
turbo5s
IF not the CPS, maybe unloader relay? Looks like it powers the coils. (if you test for spark and have none)
Old Wed, Mar-02-2011, 03:46:00 PM   #10
Avusblau95
Avusblau95's Avatar
Reputation: 0 Avusblau95 is on a distinguished road
Make sure theirs no fluid in the DME's compartment. 95's are notorious for flooding out there dme's from clogged rain gutters. Might have a fried DME, happened to me. My car would turn over but just not start.
1995 Avusblau M3, Lots-o-mods
Jump to top Avusblau95 is offline   Reply With Quote
cranks, e36, no start
Discussing another cranks but no start problem. help in the E36 M3 (1992-1999) Forum - {Euro - S50 B32 321hp @ 7400 rpm} {U.S. - S52 B32 240 hp @ 6000 rpm}
