View Poll Results: If you own an E46 M3, do you wish that Double VANOS never existed for the E46 M3?
Yes, I have had a VANOS problem and I think that the costs outweigh the benefits 19 14.62%
Yes, I have not had a VANOS problem but I think that the potential costs outweigh the benefits 29 22.31%
No, I have had a VANOS problem but I think that the benefits outweigh the costs 18 13.85%
No, I have not had a VANOS problem and I think that the benefits outweigh the potential costs 64 49.23%
Voters: 130. You may not vote on this poll
Old Mon, Feb-07-2011, 04:30:28 PM   #1
maveric23
maveric23's Avatar
Reputation: 0 maveric23 is on a distinguished road
Question VANOS Poll: Do you wish that High-Pressure Double VANOS never existed for the E46 M3?
The E46 M3's engine is equipped with step-less High-Pressure Double VANOS which varies valve timing on the intake and exhaust camshafts to optimize power output throughout the rev range for better performance, improved fuel efficiency, and lower emissions. However, there are a number of problems associated with the VANOS that can lead to costly repairs. There are 4 main VANOS failures (here's a related poll):
  1. VANOS solenoid
  2. VANOS actuator
  3. VANOS oil pump drive tabs on the exhaust cam gear sprocket/spline hub
  4. VANOS intake cam gear bolts
Here is the poll question for E46 M3 owners: All things considered, do you wish that High-Pressure Double VANOS never existed for the E46 M3?
Please, only respond to this poll if you've owned an E46 M3 for at least 6 months. Please feel free to elaborate about your selection here. Thanks!
Do you wish that Double VANOS never existed? Vote!
2004 Silver Gray/Black M3 Convertible
Jump to top maveric23 is offline   Reply With Quote
Old Mon, Feb-07-2011, 04:53:37 PM   #2
Jonathan 90 M3
Jonathan 90 M3's Avatar
Reputation: 0 Jonathan 90 M3 is on a distinguished road
Default Re: VANOS Poll: Do you wish that Double VANOS never existed for the E46 M3?
You do realize that the vast majority of M3s on the road have not had VANOS issues, right? Don't let the forum hype get to you.
Most people who daily these cars would hate the type of power delivery that an old school ///M engine would have.
'05 E46 M3 Imolarot/Cinnamon - CURRENT
'98 E36 M3 Estorilblau/Dove - SOLD
'90 E30 M3 Brilliantrot/Black - SOLD
Jump to top Jonathan 90 M3 is offline   Reply With Quote
Old Mon, Feb-07-2011, 05:31:30 PM   #3
Foo2rama
2004 E46 M3
Foo2rama's Avatar
Reputation: 0 Foo2rama is on a distinguished road
Doh worded it weird... The one vote for "No, I have had a VANOS problem but I think that the benefits outweigh the costs" should be in the bottom, as I have had no issues.
As for vanos being bad, the larger issue is the high pressure vanos that we have, which is now a low pressure vanos system in the new cars. The lower pressure system is a tad more reliable.
As for removing dual vanos entirely? Well have fun with your lower torque and lower HP engine. You would not be able to get the torque curve and HP out of this engine without it.
2004 Mystic Blau Imola Rot ///M3 Coupe SMG
Other Rides
73- 240z - L28 Block w e31 heads - prepping as a track toy
95- Legend Coupe - C32A5 block - totaled while parked
96- Dodge Ram 4x4 5.9 - totaled while parked in a seperate incident
Jump to top Foo2rama is offline   Reply With Quote
Old Mon, Feb-07-2011, 06:18:59 PM   #4
EricSMG
30 something
The VANOS is what defines this motor's flat, long torque curve. Without VANOS, you can't have good low-mid and top end... you only get to pick one or the other.
So, no, I don't wish that we didn't have double VANOS.... the car would not be same.
'04 46M 6MT || '01 330Ci 5MT
Old Mon, Feb-07-2011, 06:51:14 PM   #5
hogger453
hogger453's Avatar
Reputation: 0 hogger453 is on a distinguished road
Wouldn't change a thing. Besides, if the Vanos does go it is very easy to work on.
Jump to top hogger453 is offline   Reply With Quote
Old Fri, Feb-11-2011, 09:41:57 PM   #6
maveric23
maveric23's Avatar
Lightbulb Re: VANOS Poll: Do you wish that Double VANOS never existed for the E46 M3?
Yeah, but I'm not sure if it outweighs the potential costs of fixing VANOS failures.
My VANOS actuator failed and I did not notice a material difference in daily driving from when it was fully functioning. I ran it up to 6,000 rpms too.
I think I might be happier with a fixed camshaft design where I didn't have to worry about the VANOS. Even after fixing my actuator, there's a chance of another VANOS failure!
Old Fri, Feb-11-2011, 10:27:26 PM   #7
JREEVES197
Reputation: 0 JREEVES197 is on a distinguished road
No, I like the performance(when its working) I just wish the engineers would go back to the drawing board tomorrow and fix the fing issues.
Jump to top JREEVES197 is offline   Reply With Quote
Old Fri, Feb-11-2011, 10:45:18 PM   #8
StevoTheHobo
Literally passes gas for a living
StevoTheHobo's Avatar
Reputation: 0 StevoTheHobo is on a distinguished road
Does anyone know what the mechanical differences are between the newer double-VANOS systems (e.g. - in an N52 or N54) versus the double-VANOS in the S54 besides the S54 using a high pressure oil system? Also, I think BMW could have designed the cam gear bolts and cam sprockets better so that we wouldn't have seen the failures that we have.
2003.5 TiAg ///M3 "Betsy," Black Nappa interior
120,000 miles and counting
Stuff done so far
Intake: Macht Schnell elbow, aFe ProDry filter, RPI scoops
Engine:Denso Iridium UX024
Exhaust: Supersprint V2 Stepped headers, CPI pipe w/ 200 cell cats
Cooling: Rogue silicone coolant hoses, Updated OEM water pump
Brakes: TMS SS brake lines, CSL rotors
Suspension: Koni Sport + OEM springs, Meyle HD RSMs, OEM RTABs + TMS limiters, Rogue FCABs, TMS rear camber arms, Meyle HD front swaybar links
Drivetrain: UUC shifter
Chassis/Frame: TMS rear subframe reinforcement kit, TMS rear shock tower reinforcement plates
Exterior: Seibon CSL-style CF trunk (painted in TiAg), EurosportDesign clear front reflectors, Depo LED front corners, Khoalty projector foglights, VMR VB3 gunmetal, black side and kidney grills
Interior: Khoalty LED interior/trunk lights
Stereo: Custom Clarion navigation install
Jump to top StevoTheHobo is offline   Reply With Quote
Old Fri, Feb-11-2011, 10:48:10 PM   #9
suaveflooder
suaveflooder's Avatar
Reputation: 0 suaveflooder is on a distinguished road
I don't think that he does. All he does is post in the vanos threads it seems. Kinda funny actually. I don't think he will ever truly enjoy his car because he is too worried about potential failure.
Could these problems happen to my car? Absolutely. Am I worried about them? No. I am prepared as every person who owns a luxury sports car should be. These aren't cheap cars! Something breaks, expect to spend a pretty penny fixing it.
Don't own a car that you can't fix if the need arises. That's why the honda civic exists.
2013 FR-S
Jump to top suaveflooder is offline   Reply With Quote
Old Fri, Feb-11-2011, 11:08:21 PM   #10
ch0pst1x88
ch0pst1x88's Avatar
Reputation: 0 ch0pst1x88 is on a distinguished road
hahaha good thing i have one just in case the M breaks down on me
Jump to top ch0pst1x88 is online now   Reply With Quote
vanos
Discussing VANOS Poll: Do you wish that Double VANOS never existed for the E46 M3? in the E46 M3 (2001-2006) Forum - Engine: S54 - Max Hp: 333 hp at 7,900 rpm / 262 lb/ft at 4,900 rpm
