Go Back   BMW M3 Forum.com (E30 M3 | E36 M3 | E46 M3 | E92 M3 | F80/X) > BMW M3 Discussions > Member Photos and Videos
Member Photos and Videos Place to post and discuss BMW and other automotive videos and photos.
Old Fri, Jan-07-2011, 03:09:53 PM   #11
Nachos23
SweetXi
Nachos23's Avatar
Reputation: 0 Nachos23 is on a distinguished road
Default Re: New Carbon Fiber Engine Parts (BMW and Ferrari)
Originally Posted by deeznutz972 View Post
does that replace the oem sill or just cover it up?
BTW great work man!
Hey Thanks!!! To answer the question on the CF link that was posted. Those pieces are overlays and are glued onto the OE pieces. Basically what I do, but they use release fabric between CF and base part to allow them to separate the parts when dried. Then they finish the overlay and attach double-sided tape to base. You can see that in the pictures if you look carefully.
Difference with my parts, is I physically attach the CF to the part making it permanent.
My Rides:
2009 e90 335Xi
540hp BB Back-end flash & JB4
2000 Z3 M Roadster Convertible
Jump to top Nachos23 is offline   Reply With Quote
Old Sun, Jan-09-2011, 12:40:26 AM   #12
Nachos23
SweetXi
Nachos23's Avatar
Hey!
Got the intakes finished; well one completely and the seconf requires painting of the edges (tomorrow) and it'll be done....
Here they are:
My Rides:
2009 e90 335Xi
Old Sat, Jan-15-2011, 07:59:48 PM   #13
Nachos23
SweetXi
Nachos23's Avatar
Default Carbon Fiber Ferrari 360 Intakes Installed!!
Went by my buddies dealership and installed the 360 intakes. Need to completely finish them before we can sell them, but, they look real nice so far. They are 95% done; some final sanding, painting and clear coat and they're done!
Here are the pictures:
Stock vs. wrapped:
Engine Compartment; low angle:
Engine Compartment; Higher Angle
Close-Up Right intake (needs final paint and sanding)
Close-Up Left intake (needs final paint and sanding)
Well?
My Rides:
2009 e90 335Xi
Old Fri, Jan-28-2011, 07:34:41 AM   #14
MPOWERD
Mod Hound!
MPOWERD's Avatar
Reputation: 0 MPOWERD is on a distinguished road
If you want to protect your BMW engine covers form the engine heat and keep the clear coat from cracking and yellowing you should line the inisde iwth lavamat...
I added it to my CF engine cover and it cut the tranferred heat in half...
Your work is to nice to lose to direct transferred heat from mounting on the motor...
http://www.m3forum.net/m3forum/image.php?type=sigpic&userid=91859&dateline=123241  4897
2003.5 e46 ///M 3 TiAg Cabriolet SMG II...
<> CSL Carbon Fiber Intake w/MAF, Brembo Gran Turismo, Euro Headers & Cats, K&N 69, Radenergie Carbon Fiber Strutbar
<> EAS Carbon Fiber Kidney Grills, Carbon Fiber Fender Grills, SMG Carbon Fiber Paddles, Vorsteiner 2 Sided CF VCSL Boot
<> EAS Slvr Carbon Fiber Interior Trim, Blk Carbon Fiber SMG Dome, Carbon Fiber Console, & Blk/Slvr Steering Wheel Trim
<> EAS Carbon Fiber Engine Bay, Vorsteiner Carbon Fiber Valve Cover, RPI Intake Scoops, CarPC w/Nav/MP3/HD Radio/TV
<> Eisenmann Race Exhaust, Supersprint X-Pipe with Resonator, Ekarbon 1/2 Carbon Fiber Diffuser, DEPO Smoked Corners
<> 19x8.5 19x9.5 VMR V710s in HyperSilver, Painted Corner Reflectors, EAS Carbon Fiber Emblems, Carbon Fiber Hood Vent
<> Slvr CF Pedals, OEM 2-Tone Hardtop, Windscreen, & Alarm, 6K Headlights & HID Fogs, Blk Carbon Fiber Headlight Trim
Jump to top MPOWERD is offline   Reply With Quote
Old Fri, Jan-28-2011, 02:28:41 PM   #15
Nachos23
SweetXi
Nachos23's Avatar
Thanks!!!! I will try to find a source locally....
My Rides:
2009 e90 335Xi
Old Fri, Jan-28-2011, 02:55:11 PM   #16
Nachos23
SweetXi
Nachos23's Avatar
Got it!! Got a big sheet of it with the adhesive backing. Going to install prior to putting parts back on engine!! Thanks for the heads-up!!
My Rides:
2009 e90 335Xi
Old Sat, Jan-29-2011, 12:45:03 PM   #17
eoddom
Reputation: 0 eoddom is on a distinguished road
Wouldnt you worry that the heat not transferring to certain parts of the engine would cause the engine not to cool properly?
Jump to top eoddom is offline   Reply With Quote
Old Sat, Jan-29-2011, 03:56:06 PM   #18
Nachos23
SweetXi
Nachos23's Avatar
No actually, the pieces I'm wrapping are more cosmetic pieces.
The fuel rail cover is intended to hide all the fuel delivery and management pieces and to give a nice clean appearance to the top of the engine.
Similarly, the valve cover piece doesn't actually cover the valves or dissipate heat from that area. It's job is to reduce the heat (block) transferred into engine compartment as well as to cover the parts underneath and provide a nice engine bay appearance.
Adding the Lava Mat will actually help keep the engine bay cooler and reduce heat to the parts signficantly.
My Rides:
2009 e90 335Xi
Old Sat, Jan-29-2011, 08:09:32 PM   #19
NiceE46
Versace baby rattle got me sleepless in Seattle
NiceE46's Avatar
Reputation: 0 NiceE46 is on a distinguished road
Location: Non-stop through desert, salisbury steak sweater
Germany
Nice work man.
'05 SG/IR
Originally Posted by M3Dom View Post
I hear if you get bit by a squirrel you get the raves, This is when you say you're going to post pics and never ever do.
Originally Posted by P4lm3r View Post
Sweet e39! Manual trans, too. Good joob!
Jump to top NiceE46 is offline   Reply With Quote
Old Sat, Jan-29-2011, 09:13:42 PM   #20
M3ANMACHINE
@natrajusa
M3ANMACHINE's Avatar
Time to make a CSL intake!
2011 E90 ///M3 | Space Grey | Fox Red | DCT | ZCP | Slicktop
2008 E90 M3 | AW | 6MT | Slicktop
2004 E46 M3 | CB | SMG
carbon fiber, engine, interior, trim, wrapping
Discussing New Carbon Fiber Engine Parts (BMW and Ferrari) in the Member Photos and Videos Forum - Place to post and discuss BMW and other automotive videos and photos. at BMW M3 Forum.com (E30 M3 | E36 M3 | E46 M3 | E92 M3 | F80/X)
