Old Fri, Jun-18-2004, 01:13:54 PM   #1
MrBitner
Reputation: 0 MrBitner is on a distinguished road
Default Rear Shock Installation ... !!??
I'm doing my rear shocks today and I've read all the DIYs, well most of them at least. I just wanted to get some last advice or tips before I tackle this job. This will be my first time and it doesn't seem too difficult, but I just wanted to double check since I don't have a manual.
Just some tips or suggestions would help. Also, if anybody knows where a really good DIY is ... that would also help.
Thanks,
Jason
Jump to top MrBitner is offline   Reply With Quote
Old Fri, Jun-18-2004, 01:32:56 PM   #2
tonykhar
tonykhar's Avatar
Reputation: 0 tonykhar is on a distinguished road
Don't forget to check the RSM's. while you're there. Or just get the Parts for the e46 and replace them anyways.
Jump to top tonykhar is offline   Reply With Quote
Old Fri, Jun-18-2004, 04:16:35 PM   #3
BAMBAM
Reputation: 0 BAMBAM is on a distinguished road
What area do you live in? I need to see how its done...
Jump to top BAMBAM is offline   Reply With Quote
Old Fri, Jun-18-2004, 04:39:57 PM   #4
Tpb31
Tpb31's Avatar
Reputation: 0 Tpb31 is on a distinguished road
http://www.logun.org/e36_info.htm or you can try
http://www.geocities.com/e36rulz/diy.html
I haven't done that yet, so I can't give you any advise, but there are some DIY links
Jump to top Tpb31 is offline   Reply With Quote
Old Fri, Jun-18-2004, 06:11:22 PM   #5
jspbtown
jspbtown's Avatar
Reputation: 0 jspbtown is on a distinguished road
Not sure if you have a coupe/vert or sedan, but I just replaced my rsms on 1998 vert and it was very easy. I didn't even take the wheel off. On the non-vert models you have to remove alot of stuff in the trunk to get them off, but they are only held in with two nuts, and the shocks are held to the mounts with one nut. I upgraded to the E46 mounts on my car and they fit perfect. Total cost for the mounts (which by the way were totally shot after 60K miles) was $50.00. That included two mounts, and all the nuts and two gaskets. If you wanted to pinch pennies you could re-use the nuts.
Jump to top jspbtown is offline   Reply With Quote
Old Fri, Jun-18-2004, 07:19:45 PM   #6
BAMBAM
You don't even have to take off the wheels when you replace the RSMs? anybody have a good detailed guide how to do it?
Old Fri, Jun-18-2004, 07:27:14 PM   #7
SG_M3
#56 JP M3
Reputation: 0 SG_M3 has disabled reputation
http://www.logun.org/shockmnts.htm
Sean
- 98 M3 EB/BLK
Jump to top SG_M3 is offline   Reply With Quote
Old Sat, Jun-19-2004, 01:48:53 AM   #8
jspbtown
jspbtown's Avatar
Nope....didn't take the rear wheels off. Jacked up the rear, removed the 2 upper rear shock mount nuts (again different for a vert), reached under the car and removed the one nut holding the lower part of the shock on and wiggled it out. Put the new mount on the old shock on my bench, then slid the shock back up into the mount. I was able to hold the shock with one hand and start one of the two nuts that hold the upper shock mount. I went back up top and tightened the two nuts and then used a small bar to raise the rear tire a little to slide the lower shock mount on. Tightened the nut and I was done. Real easy. Took my time and it was about an hour for both sides.
Old Sat, Jun-19-2004, 06:02:02 AM   #9
Avus Blur
S.S.D.D.
Reputation: 0 Avus Blur is on a distinguished road
You have to take out the rear speakers. That is the only PITA part of the job. Other than that, its as easy as changing your oil.
-Tim
1995 M3
Avus/Dove Grey
Conforti Euro Intake w/ TMS chip
Motorsport Brace
X Brace
V2 Splitters
Hardwired V1
DEPOs w/ DDE plus & X-tec 6000K HIDs
UUC Twin Silencer exhaust
Jump to top Avus Blur is offline   Reply With Quote
Old Sat, Jun-19-2004, 06:40:41 AM   #10
Sirius
How many licks..
Sirius's Avatar
What? You do not. I didnt and I have the subs in my way...
♪♫♪♪♫♪ Trevor ♪♫♪♪♫♪
97' M3. '10 R6.
Will a rear shock tower brace reduce the chance of a rear sub-frame failure? M3 Rider E46 M3 (2001-2006) 8 Fri, Feb-16-2007 07:38:55 PM
OE RSM ( Rear Shock Mount ) and OE Rear Shock AngelsToy E36 M3 (1992-1999) 3 Thu, Jul-27-2006 05:26:16 PM
shock and spring installation questions.... M3nEwBoOtY E36 M3 (1992-1999) 5 Fri, Aug-26-2005 08:17:50 PM
Rear shock mount/Rear Shock Tower Bar zero4 E46 M3 (2001-2006) 8 Sun, Apr-03-2005 07:12:57 PM
Will rear shock replacement fix shock mounting bracket problem carlsturm E36 M3 (1992-1999) 10 Sun, Oct-24-2004 07:34:05 PM
Discussing Rear Shock Installation ... !!?? in the E36 M3 (1992-1999) Forum - {Euro - S50 B32 321hp @ 7400 rpm} {U.S. - S52 B32 240 hp @ 6000 rpm}
