#1 | ||
![]() Location: SE PA
Preface: I go into a lot of detail in this thread on the things you can do with the intravee. By no means do you have to. If you just want to use it as an iPod adaptor, it's a super easy install and is hugely better than any other iPod adaptor sold for the car. This things that are gone into in this thread shouldn't scare you away from the intravee, none are necessary in the slightest. But, awesome, you can do them if you want to
![]() I don't understand how this thing flies so far under the radar. I view it as a basic requirement if you have nav. And, no, I don't sell this. In fact, as far as I know the only way to get it is to order it from England. That's the only reason I can see why this thing is flying under the radar so fully! Features: 1) best iPod interface for the car, bar none 2) programable buttons 3) automatic clock setting based on GPS 4) Graphical display of the parking distance control sensors on the nav screen, automatically enabled when you put the car in reverse 5) automatic folding up of side mirrors, if you have power fold mirrors 6) Data logging of your car when you drop it off at the dealership/shop-- including if it was revved out when cold! 7) updatable firmware with new features added regularly 8) No glitchiness! 9) support for many, MANY alpine devices-- MP3 CD changers, HD radio, sirius, xm, etc etc. Now, to show each feature so people fully appreciate this... 1) You can search by artist, playlist, album, etc etc-- and each time scroll through the available options and select what you want. 2) You can program the following buttons: 1, 2, 3, 4, 5, 6, clock, dolby (e46 doesn't have this button), phone, steering wheel phone, m/t. (the last 3 you can only program if you don't have bluetooth). You can set them up to take you directly to specific playlists, switch between intravee devices (change iPods, go to XM, etc), or to take you to specific menus (playlist search, etc). That said, you NEVER have to do anything by obscure button combinations-- you can always use the menus to navigate to anything. 3) I never have to set my clock after disconnecting the battery, it always sets itself as soon as the car gets GPS lock. This is better than just being lazy-- it means my car has a built in exactly correct clock . 4) I don't have pics of the nav interface, but here's how it looks on the e39 cluster (left side bars are signal strength from the front of the car (it's front 4 sensors), right side bars are the signal strength from the rear sensors. These let you know where the objects you're hearing are, so you can better judge if they're actually a threat! Plus it tells you exact distances. ![]() 5) Don't have a pic of this, but... once you turn it on, if you hold the lock button on your remote the mirrors fold up. When you unlock the car they come back down. 6) Haven't you always wanted to know how your car is driven when you drop it off at the stealer/shop? Well, now you can... in great detail (log file stolen from M5board): ![]() 7) No pic of this either. They keep adding new features regularly, though (PDC feature was just added, for example). 8) This is the 3rd iPod adaptor I've had on this car. Previous adaptors have all required unplugging and replugging (resetting) on a fairly regular basis. In the 2 years I've been using the intravee now, I've NEVER had to reset it. Not even once. 9) nice feature for catless/race cats/diesel owners: switch to recirculate on reverse and back to previous setting after 10) auto map zoom based on speed (zooms out as you speed up, in as you slow down, at intervals and a starting speed of your choosing) 11) Automatic muting of music in reverse, so you hear the PDC beeping 12) electronic diagnostic screen-- temps, highest temps, revs, highest revs, actual speed, highest actual speed, etc 13) Assign keys to settings-- as in, share a key with your significant other? It can automatically select your iPod when using your key and their iPod when using their key Intravee supported device list to date: KCA-420i iPod interface ![]() CHA-S634 6 Disk MP3 CD Changer ![]() CHA-S624 6 Disk CD Text Capable CD Changer ![]() CHA-S614 6 Disk CD Changer ![]() CHA-S605 6 Disk CD Changer ![]() CHA-S604 6 Disk CD Changer ![]() MHA-S670 6 Disk MD Changer ![]() KCA-410c 2 Port AI-Net switch plus 2 Aux inputs ![]() KCA-400c 4 Port AI-Net switch ![]() TUA-T100DAB DAB digital radio tuner (Europe) ![]() Support with V6 firmware CHA-1214 12 Disk CD Changer ![]() CHA-1204 12 Disk CD Changer ![]() DHA-S690 6 disk DVD changer ![]() DHA-S680P 6 disk DVD changer ![]() Intravee 3 port switch ![]() Support with Intravee serial number greater than 003000 TUA-T500HD HD digital radio tuner (America) ![]() TUA-T550HD HD digital radio tuner (America) ![]() TUA-T020XM XM satellite radio tuner (America) ![]() SIRALP-1 Sirius satellite radio tuner (America) ![]() Support in development KCA-SC100 Sirius satellite radio interface (America) ![]() Support being investigated for future firmware DVA-5205p DVD player ![]() DVA-5210 DVD player ![]() 'Theoretical' support, but not tested SIR-ALP10T Sirius satellite radio tuner (America) ![]() Edit: just found this on another forum and it amused me: Quote:
Final note: some of the features listed above are MKIV only. Specifically the advanced search modes. Disclaimer: the below is starting to get fairly complex. You don't have to worry about how complicated his system is. All you actually need to enjoy an intravee is an intravee and an iPod. The below is just to show how far it'll let you go, if you so desire! Another edit, sweet new feature thanks to CCFJ1--- the ability to use control an aftermarket amplifier through the stock nav display: Quote:
Current Cars: 2005 IR/IR M3, 2003 TiAg M5, 1995 S50 B32 GT3 RS Green M3 Race Car _____Former Cars: 2004 TiAg/IR M3, 1996 TV/black M3, 1995 AW M3 shell Useful stuff: Objective suspension comparison, DIY suspension install VIDEOS (e36 version), Stick Driving Basics, e46 Climate Control, Better Fuel Economy 101, 10W-60 TWS Everything on the car: Mod List __________ HighRes M Wallpapers (Misc collected pics) <--- save target to desktop Selling: Suspensions, brakes, safety equipment, etc (ask away!) Renting: Valve shim adjustment kit, RTAB tool, Ball joint tool Last edited by Obioban; Mon, Apr-08-2013 at 06:47:11 PM. |
#2 | |
The Russian
![]() Location: Stamford
edit 11/30/2012
The creator of intravee died last week. One of his friends, RichardP on here, gave the back story later on in the thread. I'm editing it to here so it doesn't get lost in the shuffle: Quote:
![]() 2003 M5 Last edited by Surge709; Fri, Nov-30-2012 at 10:59:55 AM. |
Yep, I love mine. I still won't go with the DICE Mediabridge since it doesn't support enhanced text. IE, it doesn't use the ENTIRE NAV screen like the Intravee does.
My one wish... Support for streaming audio from the iPhone. But that is more of a problem with the KCA-420i. You have to use the AUX port off the phone into a KCA-420c or the AUX port on the BMW (if you have one). |
#4 |
The Russian
I really want Bluetooth support through intravee as I think this would work better than the retrofitted OEM one for my car
![]() 2003 M5 |
#5 |
![]() Location: Philadelphia
Pretty Sick, i never heard of this one before.
04 SMG Imola Red | Black Cloth / Leather Interior | Koni Yellow's | Rouge RSM | Power Flex RTAB | JVT Headers | Custom Performance CRT 400 Section 1 | Turner Sub Frame Reinforcement | Smoke Corners | Kidney's & Gills Matte Black | Angel Eyes | CSL Diffuser | CSL Boot Lid |
#6 |
![]() Location: Greeley
+1, nice review.
Cosmetic/Aero: BW splitter, BW canards, Brooks pro wing, V-CSL bootlid, Tekerbon CSL diffuser, V-GTR hood, CF moonroof delete, CF kidney grills, CF gills, and CF roundels Suspension/Brakes: MOTON CS 850/450 (rear coilover), GC F/R race sways, RE FCAB/RTAB (track), TMS rear camber arms, GC race camber plates, TMS solid subframe bushings, ZCP F/R rotors, brass caliper guides, BW SS lines, PFC RH665, PFC-01, BW brake ducts/baking plates. Performance: BW/EPIC Tune, aFe stg2 intake, SS V2 stepped headers, BW race exhaust, TMS pullies, JB Racing clutch/LW flywheel, TMS solid motor mounts, TMS solid trans mounts, BW solid diff mounts, RE shifter linkage, and BW race shifter. Misc: TMS subframe reinforcement kit, Sparco PRO ADV seat, Sparco side mounts, VAC floor mounts, Kirk Comp. Roll Bar, Schroth Profi III 6-Point harnesses, Jafster shift knob, BimmerWorld 75mm wheel studs, and Enkei NT03+M. |
#7 |
D@mnit! Nav is the one option that I really wish I had
#8 |
nav and xenons are the only two options I consider must have. And, really, xenons much less so these days with all the retrofits
Current Cars: 2005 IR/IR M3, 2003 TiAg M5, 1995 S50 B32 GT3 RS Green M3 Race Car _____Former Cars: 2004 TiAg/IR M3, 1996 TV/black M3, 1995 AW M3 shell Useful stuff: Objective suspension comparison, DIY suspension install VIDEOS (e36 version), Stick Driving Basics, e46 Climate Control, Better Fuel Economy 101, 10W-60 TWS Everything on the car: Mod List __________ HighRes M Wallpapers (Misc collected pics) <--- save target to desktop Selling: Suspensions, brakes, safety equipment, etc (ask away!) Renting: Valve shim adjustment kit, RTAB tool, Ball joint tool |
#9 |
Have you ever seen any GOOD QUALITY non-nav to nav conversions? I've seen several threads where it has been discussed but never seen anyone who has actually done the conversion.
2006, AW 6spd. SOLD Last edited by Voltaire; Fri, Dec-17-2010 at 03:38:52 PM. |
#10 |
The Russian
Xenons I disagree on as both you and I are effectively running non stock xenons but something much better! Thank you Lightweks!
![]() 2003 M5 |
| adaptor, highly, intravee, ipod, nav, rated, read |
