Old Thu, Dec-02-2010, 11:52:29 PM   #1
svb
Reputation: 0 svb is on a distinguished road
Default Dash in pieces, need to remove factory bmw ipod
Thanks to all the info on this board, I was able to carefully and successfully get behind my nav unit to remove the bmw factory ipod connection so that I an install my DICE in the trunk. Unfortunately, now I'm stuck. I removed the black Ipod cable from the module and removed the module. But I'm not sure how to remove the rest of the plug. Its still connected to a small blue connector and a larger black connector. What do I do next?? I want to make sure this is completely disconnected so I can use SIRIUS and IPOD through Dice silverline
http://members.roadfly.com/retina/yonm3.jpg
Jump to top svb is offline   Reply With Quote
Old Fri, Dec-03-2010, 12:43:03 AM   #2
hinrichs
Non Purist
hinrichs's Avatar
Reputation: 0 hinrichs is on a distinguished road
the wiring needs to be changed back to stock, took me a little while to figure it out at first and searching on here didnt help at all, then again i just have the normal cd played
I wish I could be more specific tho on how to go back to stock but without looking at it again i cant remember exactly where everything goes but I did just remove the module first and the dice wouldnt work untill the wiring went back to stock
99.5 A4
Jump to top hinrichs is offline   Reply With Quote
Old Tue, Dec-28-2010, 08:56:33 PM   #3
monochrom3
P-Car Noob
monochrom3's Avatar
Reputation: 0 monochrom3 has disabled reputation
Default Re: Dash in pieces, need to remove factory bmw ipod
to see if anyone can shed light on this. I'm guessing I need a BMW-specific tool or something.
997.2 GT3: Carrara White, no mods necessary
MKV GTI: Black Magic Pearl, 4-Door, DSG, APR Stage 1, Omanyt (R32) wheels, Wolfsburg front end (daily driver)
e36 M3: TechnoViolet, gutted, AutoPower rollbar, CF sunroof delete, BW door panels (track toy)
e46 M3: TiAg, ESS VT450, Dinan 3.91's, Euro headers/cats, SS x-pipe, SS race muffler; GC coilovers & swaybar; Stoptech ST60/40; OEM CSL bootlid, Dinan 19's (sold)
Jump to top monochrom3 is offline   Reply With Quote
Old Tue, Dec-28-2010, 09:13:35 PM   #4
daytonaviolet
OEM CSL Whoore
daytonaviolet's Avatar
are you referring to the blue connectors? just hold both ends and pull.
bmw, dash, factory, ipod, pieces, remove
Discussing Dash in pieces, need to remove factory bmw ipod in the E46 M3 (2001-2006) Forum - Engine: S54 - Max Hp: 333 hp at 7,900 rpm / 262 lb/ft at 4,900 rpm
