Old Sat, Nov-13-2010, 10:51:08 PM   #1
fiveightandten
fiveightandten's Avatar
Default RTAB pocket failure quick video inside and some info on diagnosing
A friend of mine was having a suspension clunk, so we put the car up in the air to have a look. I noticed one of the welded bungs on the driver's side RTAB pocket has separated. So I took a quick vid.
The car is on its second set of OEM RTABs. The PO replaced his originals around 120K or so...so he doesn't know what they looked like at the time. We don't know how long the car has been like this.
The symptoms were as follows:
-Clunking noise coming from the rear at low speeds when going over bumps or elevation changes.
-Could reproduce the clunk by shaking the car left to right.
-NO clunk heard as a result of going over bumps while driving at speed.
Sorry for the cell phone video...it was all I had on me at the time. You'll have to look close. This is just me prying gently on the RTAB console with a small pry bar. It pulls away from the unibody pretty readily with little force.
Anyways...hopefully this video will be useful to anyone looking to check their RTAB pocket for failure. A little poke with the pry bar makes it pretty visible. Be gentle under there. And when you get your car aligned, tell the place to be mindful for NOT overtorquing these bolts.
-Nick
Old Sat, Nov-13-2010, 10:58:55 PM   #2
PurduinaM3
Reputation: 0 PurduinaM3 is on a distinguished road
Damn, that sucks man. Whose car is this, teh hooms?
It happens though, Poly or not...
Jump to top PurduinaM3 is offline   Reply With Quote
Old Sun, Nov-14-2010, 12:40:11 AM   #3
shaeff
Maintenance FTW
Reputation: 0 shaeff is on a distinguished road
That sucks. Whenever I get my car aligned, I leave a torque spec sheet sitting on the driver's seat when I leave the car and ask politely that they follow it due to reasons just like this.
And edit: agreed on poly or OEM. My car had 98k on it when I got it, bone stock, and I had a torn threaded insert. Pissed me off when I went to replace the RTABs (which I might add, were still in perfect shape)
Jump to top shaeff is offline   Reply With Quote
Old Sun, Nov-14-2010, 02:32:00 AM   #4
Z3MCOUPE
Gort! Klaatu barada nikto.
Z3MCOUPE's Avatar
Reputation: 0 Z3MCOUPE is on a distinguished road
Nick - you are the man. Thanks for posting.
2000 Z3 MCoupe, '01 LSB E46 M3, '99 VW GTI VR6, '06 Audi A4 2.0T,
Andrew (camdinans3) '95 M3 Avus
Jump to top Z3MCOUPE is offline   Reply With Quote
Old Mon, Nov-15-2010, 12:43:38 AM   #5
M3_ATW
Reputation: 0 M3_ATW is on a distinguished road
thank you for the info!!
scared to say that i think i might have this going on with my M
all new bushings coming in soon, but i will either need to have the pocket reinforced or fixed for sure
Jump to top M3_ATW is offline   Reply With Quote
Old Mon, Nov-15-2010, 02:08:52 AM   #6
Cawhite78
TFM
Cawhite78's Avatar
Reputation: 0 Cawhite78 is on a distinguished road
Nick - thanks for the help here. I was thinking about it on the way home, and it HAS to be the pocket separation causing the clunk. The noise is 100% coming from the passenger rear where we suspected. That said, I just ordered the bimmerworld kit, and will do the ball joints at the same time, because the play that was present was enough to justify it .
Good to see you as always bro
It's mine Bobby. I want to say I was shocked when we discovered it, but i had a strange feeling.. My car's closet is full of skeletons..
Just my two cents, this definitely is not a Track Car/Auto X/Poly RTAB only issue. Under body rust is something that over time (especially if your car has seen winter use) WILL eventually attack the weak points of the under carriage. Aggressive driving or not, the e36 is 11+ years old at it's newest. If you are under the car - it's worth taking a look at.
Casey
Jump to top Cawhite78 is offline   Reply With Quote
Old Mon, Nov-15-2010, 02:35:20 AM   #7
PurduinaM3
It's more common than you think; don't get too down on the car. Mine were starting to tear out with zero rust at all... just a very weak area there
Old Mon, Nov-15-2010, 11:49:49 AM   #8
284Shooter
Reputation: 0 284Shooter is on a distinguished road
Seems we are seeing more and more of this as these cars age. A few years ago, this was a very uncommon post. Now, even removing cross posts, it seems we see better than a dozen of these a year.
These are on my winter to-do list.(as well as a new battery tray with hoops for track tie downs) I may have the front subframe re-enforced as well. I needed an excuse to regrease my RTABS and put the camber plates in, so this is as good as any to get it all done and get lined back up before the spring track days start.
I have to wonder if the newer tire and brake compounds are accelerating these failures? Tire and brake pad technology is FAR ahead of where it was back in the mid and late 90's. Not that fat, sticky tires or agressive brake compounds will cause this, but the extra strain on the chassis could certainly help things along....
Jump to top 284Shooter is offline   Reply With Quote
Old Mon, Nov-15-2010, 12:26:46 PM   #9
PurduinaM3
The newer stickier tires along with new R compounds are definitely helping to speed up the failure of most of the weak metal used in chassis points around this car. Grip levels like that just weren't around in the 90's...
Old Mon, Nov-15-2010, 10:10:30 PM   #10
Cawhite78
TFM
Cawhite78's Avatar
I hear ya bro.. It's just one of those things, ya know? It's a good winter project though.
I have to wonder if the newer tire and brake compounds are accelerating these failures? Tire and brake pad technology is FAR ahead of where it was back in the mid and late 90's. Not that fat, sticky tires or aggressive brake compounds will cause this, but the extra strain on the chassis could certainly help things along....
I hadn't thought of this, and I think it's a great observation. There are certainly variables that are present now within this aging chassis that were not around back when the car was designed.
Casey
diagnosing, failure, info, inside, pocket, quick, rtab, video
Discussing RTAB pocket failure quick video inside and some info on diagnosing in the E36 M3 (1992-1999) Forum - {Euro - S50 B32 321hp @ 7400 rpm} {U.S. - S52 B32 240 hp @ 6000 rpm}
