Old Sun, Nov-07-2010, 11:03:55 PM   #1
warmwater
Reputation: 0 warmwater is on a distinguished road
Default Install PIcs of Alpine Type-R SPR-17S 6.5 Comp e46 m3
Here are some pics of an easy install
Alpine Type-R SPR-17S - Car speaker system - 110 Watt - 2-way - component - 6.5"
Remove Door Panel
Remove Factory Large Speaker, Leave Plastic Ring
Remove Factory Plug From Factor Speaker to Keep a quick disconnect
Remove Factory Ring From Factory Speaker
Mount New Alpine with Factory Adapters
Tighten Screws
Remove Tweeter
Remove Plastic Ring From Tweeter
Remove Tweeter from housing, two bolts
Install new Alpine Tweeter in new Home
Use Alpine Ring and Screw to tighten Tweeter
You can leave or remove the factory smallest speaker, I removed
Tighter Assembly
*****Do not user the Alpine Cross Over************
Take the Factory Speaker wire for the larger tweeter and wire to the new Alpine Tweeter- The wire with the Brown Stripe from Factory is Negative, the Alpine Negative is the Wire with the Black Stripe
Solder and Tape all wires to factory harness for quick remove if door plannel need to be removed
It sounded great after all this work, I do have a HK Factory AMP, with an Aftermarket Deck
Hope this helps I was surprised how easy this was
Jump to top warmwater is offline   Reply With Quote
Old Tue, Nov-09-2010, 04:28:59 AM   #2
E46M3FF
E46M3FF's Avatar
Reputation: 0 E46M3FF is on a distinguished road
thanks man it is great that you did this. i have the same speakers but i havent put them on cause i didnt think they will fit. how do they sound, do you here a difference while still using the same amp? can you post smaller picutures please.
Jump to top E46M3FF is offline   Reply With Quote
Old Tue, Nov-30-2010, 02:16:22 PM   #3
SmokeyDP
Reputation: 0 SmokeyDP is on a distinguished road
I'm curious how this sounds too. I tried to install a set of 6.5" MB Quart speakers in the same fashion but there was a huge lack of midbass because the front of the speaker didn't seal with the front of the grill very well. Plus there isn't a lot of space for air movement behind the door panel.
2004 Acura MDX
2001 Phoenix Yellow M3:
Schrick cams - AFE intake - Custom Tune - Supersprint full exhaust - Evosport pulleys - UUC Evo 3 short shift kit - Brembo 14" BBK brake kit - Euro rear floating rotors - TC Kline Double Adjustable coilovers - Vorshlag caster/camber plates - Adjustable rear camber arms - Black 2005 competition package interior - Vorsteiner CSL front bumper - 19" CSL wheels
Jump to top SmokeyDP is offline   Reply With Quote
Old Tue, Nov-30-2010, 02:32:35 PM   #4
Project E46M3
Go big or go home...
Project E46M3's Avatar
Reputation: 0 Project E46M3 is on a distinguished road
I would like to know how these sound as well. If everything was plug and play then these might be a great option! BTW...your pix are huge!!!!
2013 E92 M3 ZCP | AW | FR | DCT
Jump to top Project E46M3 is offline   Reply With Quote
Old Wed, Dec-01-2010, 03:04:13 PM   #5
SmokeyDP
I sent a PM to the OP and haven't heard anything back. His last visit date was the day he made this post too...
2004 Acura MDX
Old Wed, Dec-01-2010, 06:45:06 PM   #6
Gregs///M
Gregs///M's Avatar
Reputation: 0 Gregs///M is on a distinguished road
Italy
Try checking your polarity of the speakers. If you wire one backward, you will greatly reduce your mid bass output. Try fading your front speakers to one side and see if the bass increases or decreases as your return to center. If your bass decreases, you've wired one speaker out of phase.
I've replaced the door speakers on many e46's while using the OEM HK amp and most of the time you will notice a slight improvement in sound quality but rarely in output and mid bass.
Using any high wattage speakers will surely make your system sound worse unless you replace OEM amp.
If you're looking for more output and mid bass out of your doors, replace the OEM amp. Replacing the OEM head unit also yields increased output and SQ but not as much as amp replacement.
2003 Alpine White BMW M3 Coupe
Modifications:Dice Ipod Interface [] Focal Utopia 6.5in components speakers(front), Focal Utopia 5.25in component speakers (rear) []JL Audio W3V3 Sub Woofer []
Eclipse Xa5000 5 ch amplifier [] Clifford 50.7 two way pager [] Custom interior trim (OEM Alcantara) [] Dinan Stage I tune. []
Owner of Bavarian Restoration - www.BavRest.com
Jump to top Gregs///M is offline   Reply With Quote
Old Wed, Dec-01-2010, 06:48:16 PM   #7
SmokeyDP
I have a 75x4 RMS amp with an aftermarket head unit. I had 6.5" MB Quart speakers up front and couldn't get them to sound right because they just wouldn't seal right. Tried disconnecting one or the other too. I ended up putting them in the rear deck and they sound great.
2004 Acura MDX
Old Thu, Dec-09-2010, 05:27:58 PM   #8
E46M3FF
E46M3FF's Avatar
First of, this how to is a the best. all of it is 100 percent accurate. i just did my install yesterday and it came out super clean. Second it sucked for me because i dont have hk system so i had to fab my own rings so i can mount my speakers. my set up is alpin mrp m1000, mrp f300, spr 17c, and sps 600c. It sounds super clean.
Old Thu, Dec-09-2010, 06:28:34 PM   #9
SmokeyDP
I did the same install last weekend using a set of Alpine SPS-600C 6.5" components I had around. They were installed in a 1997 Tacoma with a Sony aftermarket deck and sounded pretty good.
In the car they are getting powered by a 75x4 Rockford amp. They sound decent but not as good as they did in the truck. I feel that I am loosing a lot of mid-bass just from the way they are installed into the door panel instead of the actual metal door frame. I made sure that the front of them is sealed with acoustical sealer into the OEM rings too. I might try to use some dynomat on the actual door panels. The reviews of the SPR-17S vs the SPS-600C do suggest that the SPR-17S gives off a lot more bass though.
If you really wanted to go all out then this would be the way to do it:
http://forum.e46fanatics.com/showthr...=443244&page=4
2004 Acura MDX
Old Fri, Dec-10-2010, 03:23:12 PM   #10
E46M3FF
E46M3FF's Avatar
spr 17c do give more bass but the sps 600c are more efficient speakers. what i notice is that the sps 600c in the rears are louder then the front, so i trun the gain down just a little bit and now they are equal loudness. Now when i compare them the spr are bassier
alpine, comp, e46, install, spr17s, typer
Discussing Install Alpine Type-R SPR-17S 6.5 Comp e46 m3 in the Audio/In Car Entertainment (I.C.E.) Forum - Place to discuss sights and sounds. at BMW M3 Forum.com (E30 M3 | E36 M3 | E46 M3 | E92 M3 | F80/X)
