Old Fri, Oct-08-2010, 06:12:41 PM   #1
M302_IMOLA
"Just Six"
M302_IMOLA's Avatar
Reputation: 0 M302_IMOLA is on a distinguished road
Default Whistling sound upon cold start up
The past few mornings I have been hearing a faint whistling sound when I first start my car up (have to mute the radio to hear). The sound seems to last about 3-5 minutes and then disappears as the car warms up. The best way to describe the sound is it sounds like a very faint table saw...you know that high pitch sound you hear when you start up a table saw. The sound seems to get a little louder as the accelerator is pressed. Anybody else ever heard this before on their M? I can't help to be paranoid and think bad thoughts (i.e. vanos, cam gear bolts).
02' IR/IR
Current Mods: Painted front reflectors, matte black fender gills, carbon fiber roundels, Depo smoked corners, 19" Ruff Racing wheels wrapped in Hankook Ventus V12's (245/35F & 275/30R), Status Gruppe coilovers (7K/8K), RE RSM's, Powerflex RTAB's & FCAB's, DICE, CSL Rep Diffuser, CF Hamann Rep Lip, Magnaflow exhaust, Ebay headers, Streamline filter, Afe elbow, RPI scoops, ZHP knob, and EE LED tails.
WTB: OEM Front strut bar, Evolve stage II tune, 4.10's, and CF CSL rep Bootlid
Jump to top M302_IMOLA is offline   Reply With Quote
Old Fri, Oct-08-2010, 07:42:22 PM   #2
PenguinQX
Reputation: 0 PenguinQX is on a distinguished road
Yes, but on my car it's the supercharger
In all seriousness though, I never encountered this before when I was NA. Ever pop the hood to figure out where exactly it's coming from? Belts maybe? Bad belts can be noisey on startup and go silent after the engine warms up.
2004 M3 - Carbon Black
AA Stage 2 Supercharger|AA Coated Headers |AA Exhaust|FMIC|Alcohol/Water Injection Kit|etc.
Jump to top PenguinQX is offline   Reply With Quote
Old Fri, Oct-08-2010, 08:08:27 PM   #3
ShafferMD
M3 Enthusiast
Reputation: 0 ShafferMD is on a distinguished road
Default Air Leak
I would lean closer to a possible idle air intake or vacuum leak. Check around, it is likely that you have a crack or split in one of your lines. A small leak will not generate a code as the computer is able to correct the lean condition (if it is pre-MAF) or your not out of range yet on your O2 sensor readings (post-MAF). Our cars are getting older and the constant heat cycling of the engine compartment causes premature failure on the rubber connections in the air circuit.
My daughter's car ('03 325i) had the same condition but eventually threw a code for Bank1 / Bank2 lean.
Can be difficult to find, but easy to fix...
- Good Luck -
2003 6MT ///Carbonschwartz Metallic : Black Nappa : Premium Package : Cold Weather Package
PERFORMANCE: 245/275 PS || CDV Delete || Clutch Stop || BMW SSK || RE RTAB's || APPEARANCE: Invisibulbs || AC Schnitzer Pedals || Custom Toolkit w/ M3Forum Decal || Painted Reflectors || 55W Xenon Matched Fogs CONVENIENCE: Eurotray || Dynavin V4 DVD/NAV
Ask me anything about Powdercoating!
PM me for Metric Clutch Stop sourcing
Jump to top ShafferMD is offline   Reply With Quote
Old Fri, Oct-08-2010, 09:45:40 PM   #4
E-solo
E-solo's Avatar
Reputation: 0 E-solo is on a distinguished road
Im so glad you brought this up. I have 2 years experience with this whistling deal and I gave up on it. Here is some background on my experience with this:
Started with a faint whistle, which became more noticeable with time. It seemed to be louder when the weather was cold. Then it started happening while I was driving, so it sounded like canaries under my hood. It went away a bit during the summer, when the weather was warm. It comes back each winter when it gets cold out. Just started this week, as here in California is got a bit chilly.
I have taken the car to the dealer various time for this and had to show the dealer how to recreate the sound. They took apart my SMG and put it back together because the extended warranty would not pay for a repair. I decided to just leave it alone. The whistling went away for a while and comes back periodically. Not the dealer, not any indy shop has been able to tell me the problem.
BTW, I thought it was the SMG, but later realized it wasn't. Its obviously something else because my SMG is fine.
Jump to top E-solo is offline   Reply With Quote
Old Fri, Oct-08-2010, 09:49:28 PM   #5
chris9
Reputation: 0 chris9 is on a distinguished road
I had a similar sound that was prominent at start up but would go away as the car warmed up. Turned out to be the alternator, you may look into that.
Jump to top chris9 is offline   Reply With Quote
Old Fri, Oct-08-2010, 10:55:35 PM   #6
MPOWERD
Mod Hound!
MPOWERD's Avatar
Reputation: 0 MPOWERD is on a distinguished road
I have heard this as well, comes and goes. My shop could not track it down either...
http://www.m3forum.net/m3forum/image.php?type=sigpic&userid=91859&dateline=123241  4897
2003.5 e46 ///M 3 TiAg Cabriolet SMG II...
<> CSL Carbon Fiber Intake w/MAF, Brembo Gran Turismo, Euro Headers & Cats, K&N 69, Radenergie Carbon Fiber Strutbar
<> EAS Carbon Fiber Kidney Grills, Carbon Fiber Fender Grills, SMG Carbon Fiber Paddles, Vorsteiner 2 Sided CF VCSL Boot
<> EAS Slvr Carbon Fiber Interior Trim, Blk Carbon Fiber SMG Dome, Carbon Fiber Console, & Blk/Slvr Steering Wheel Trim
<> EAS Carbon Fiber Engine Bay, Vorsteiner Carbon Fiber Valve Cover, RPI Intake Scoops, CarPC w/Nav/MP3/HD Radio/TV
<> Eisenmann Race Exhaust, Supersprint X-Pipe with Resonator, Ekarbon 1/2 Carbon Fiber Diffuser, DEPO Smoked Corners
<> 19x8.5 19x9.5 VMR V710s in HyperSilver, Painted Corner Reflectors, EAS Carbon Fiber Emblems, Carbon Fiber Hood Vent
<> Slvr CF Pedals, OEM 2-Tone Hardtop, Windscreen, & Alarm, 6K Headlights & HID Fogs, Blk Carbon Fiber Headlight Trim
Jump to top MPOWERD is offline   Reply With Quote
Old Sat, Oct-09-2010, 03:25:05 PM   #7
M302_IMOLA
"Just Six"
M302_IMOLA's Avatar
Lol, I figured I would get some snide remarks regarding a supercharger. Good points on the belts, I will have to check them out.
- Good Luck -
I did recently install a streamline panel air filter and Afe elbow...I have checked them out for leaks but didn't see any.
Good info, thanks for sharing. It has been getting colder down south now which confirms your thoughts on it being louder during cooler weather. I swear the sound doesn't sound normal though...I have been loosing sleep over it.
Could be...my car has a little over 105K miles and is on the original alternator as far as I know. At what mileage did yours go out?
Since you're in Texas and it has been getting cooler, have you been hearing it more lately?
02' IR/IR
Old Sat, Oct-09-2010, 03:47:29 PM   #8
FLBMWM3
FLBMWM3's Avatar
Reputation: 0 FLBMWM3 is on a distinguished road
I would lean towards the alternator or possibly the tensioners.
Jump to top FLBMWM3 is offline   Reply With Quote
Old Sat, Oct-09-2010, 04:12:31 PM   #9
E46er4Life
Reputation: 0 E46er4Life is on a distinguished road
To me it sounds like it may be secondary air pump. Maybe a vid would help.
Jump to top E46er4Life is offline   Reply With Quote
Old Sat, Oct-09-2010, 11:30:05 PM   #10
chris9
Car is a 2004, alternator went out at 95,000 miles, red battery light came on.
We were seeing 100+ outside temperatures which I believe expedited the failure.
Car is garaged and majority of miles were highway.
cold, sound, start, whistling
Discussing Whistling sound upon cold start up in the E46 M3 (2001-2006) Forum - Engine: S54 - Max Hp: 333 hp at 7,900 rpm / 262 lb/ft at 4,900 rpm
