Old Sun, Oct-03-2010, 06:29:36 PM   #1
flipm3
E46 M3 | E90 M3
flipm3's Avatar
Reputation: 0 flipm3 is on a distinguished road
Default flipm3: 2002 Jet Black M3
I've been a member of M3Forum since November, 2001. I figure it's probably about time I start my own Member Journal. My goal with this thread is to simply document the history and progress of my own E46 M3. Everything from the day it first arrived from the dealer to the all around performer that I hope for it to be. I hope to share with all of you my own thought process on the modifications I choose for this car, as well as, proven feedback on every modification I do. This car serves as a real all year daily driver, with track days on the weekends.
Car History
We ordered the M3 during the summer of 2001. After being set on picking up a used E36 M3, we decided to take the plunge on an E46 M3 without ever test driving one and only seeing one in person. Several months later, the car finally arrived at our driveway in October, 2001. For the past almost near decade, the car never had an mechanical problems or mishaps. It was a true testament to BMW's amazing engineering. It has gone through countless array of weather conditions, yet still is in amazing shape. It wasn't until recently the car began to show it's age. With the car being babied and well maintained all these years, it was finally time to start replacing worn parts. The car has been left 100% stock since October 2001, and finally saw it's first modification once the OE suspension decided to call it quits. And so the modification list began to grow...
Vehicle Specifications
2002 BMW E46 M3
Build Date: 09.03.01
Delivery Date: 10.23.01
Jet Black . Black Nappa Leather
6 Speed Manual
Bi-Xenon Headlights . CD Player . Manual Seats . No Sunroof
Engine . Exhaust
Evolve Automotive Alpha-N Tune
Karbonius Composites CF Airbox
Karbonius Composites Cabin Air Filter Cover
Supersprint V1 Stepped Headers
Supersprint V1 S Pipe
Supersprint X Pipe w/o Resonator
Supersprint Sport Muffler
Schrick 280/272 Camshafts
Dinan High Flow Throttle Bodies
Beisan Systems S54 VANOS Solenoid Coil Pack
Beisan Systems S54 VANOS Solenoid Plate O-Rings
Beisan Systems S54 VANOS Seals Repair Kit
Beisan Systems S54 VANOS Rattle Repair Kit
Beisan Systems S54 VANOS Oil Pump Disk
TurboToy S54 VANOS Cam Bolts
SPAL 16" Electric Fan - Curved/Pull
Vibra Technic Motor Mounts
BMW Motorsport P54B32 Air Filter
BMW Motorsport VANOS Line
BMW E46 M3 CSL Cabin Air Filter
BMW E46 M3 CSL Battery
BMW E36 M3 EGR Block Off Plate
Viton Fluoroelastomer CPV O-Ring
SAP Delete
Suspension
JRZ Suspension RS Pro - Performance Eurowerks Street/Track Spec
JRZ Suspension Clevis Rear Mount
JRZ Suspension Front Quick Disconnect
Ground Control Street Camber/Caster Plates - Custom Anodized JRZ Red
Ground Control Front Sway Bar End Links - Custom Anodized JRZ Red
AKG Motorsport Front Control Arm Bushings (90A)
AKG Motorsport Rear Trail Arm Bushings (90A)
AKG Motorsport Rear Shock Tower Reinforcement Plate
BMW Front Strut Tower Bar
Transmission . Driveline
Rogue Engineering OCTANE Short Shift Kit
Rogue Engineering Clutch Stop
Turner Motorsport Front Subframe Reinforcement
Turner Motorsport Rear Subframe Reinforcement
AKG Motorsport Rear Subframe Bushings (75D)
AKG Motorsport Differential Mount and Bushings (95A)
AKG Motorsport Clutch Pedal Bushing (Delrin)
AKG Motorsport Shifter Housing Bushing (Delrin)
AKG Motorsport Reinforced E21 Transmission Mounts
CDV Delete
Brakes
Performance Friction ZRated Brake Pads (Street)
Performance Friction 08 Brake Pads (Track)
Bimmerworld Stainless Steel Brake Lines
ATE Gold Type 200 Brake Fluid
AKG Motorsport Brake Pedal Bushing (Delrin)
Wheels . Tires
Volk Racing TE37SL 18x9.5 +22 Hyper Silver
Dunlop Direzza ZII 265/35/18 (Track)
BMW Style 67 18x9 +26
Michelin Pilot Super Sport 265/35/18 (Street)
Michelin Pilot Alpin PA4 245/40/18 (Winter)
Bimmerworld Premium Race 82mm Wheel Stud Conversion
Bimmerworld Black 17mm Lug Nuts
Exterior . Interior
Karbonius Composites CSL Rear Diffuser - Full 1x1 CF
Karbonius Composites Dashboard Trim - 1x1 CF
Karbonius Composites Shifter Console Trim - 1x1 CF w/ Rear Window Switch Delete
Karbonius Composites Steering Wheel Lower Trim - 1x1 CF
Coby Wheel Steering Wheel
Coby Wheel 6MT Shift Boot
Coby Wheel EBrake Knob
Coby Wheel EBrake Boot
Ground Control Baby Tether Eliminator Kit
Ultimate Pedals Deluxe Pedal Set
WeatherTech FloorLiner Weather Mats
Lighting
Lightwerkz FXR 3.0 Retrofit
Philips D2S 85122+ Bulbs
Cree LED Reverse Lights
BMW LED Tail Light Retrofit
Service and Maintenance History
MileageDateService PerformedServiced By
120802.27.02Break In ServiceKnauz BMW
732512.28.02Oil ServiceKnauz BMW
1255807.18.03Oil ServiceKnauz BMW
1958204.03.4Oil ServiceKnauz BMW
2282707.19.04Turn Signal ReplacementKnauz BMW
2544210.20.04Rod Bearing RecallKnauz BMW
2544210.20.04Inspection IKnauz BMW
3016204.04.05Rear Spring ReplacementKnauz BMW
3140706.02.05Rear Spring ReplacementKnauz BMW
3294708.03.05Turn Signal ReplacementKnauz BMW
3318308.13.05Oil ServiceKnauz BMW
3785205.18.06Oil ServiceKnauz BMW
3785205.18.06Door Inner Trim ReplacementKnauz BMW
3974006.29.06Continental ContiSport TiresKnauz BMW
4321111.20.06DME UpdateKnauz BMW
4464401.03.07Oil ServiceKnauz BMW
4568111.17.07Oil ServiceKnauz BMW
5124805.27.08Inspection IIKnauz BMW
5187707.30.08Door Inner Trim ReplacementKnauz BMW
5370611.28.08Fuel Injector RebuildKnauz BMW
5370611.28.08Brake Fluid FlushKnauz BMW
5370611.28.08Coolant FlushKnauz BMW
5370611.28.08Power Steering Fluid FlushKnauz BMW
5555006.08.09DME UpdateKnauz BMW
5555006.08.09Drive Belt ReplacementKnauz BMW
6470811.30.09Oil ServiceKnauz BMW
6638912.30.09Trunk Handle ReplacementKnauz BMW
7309912.21.10Oil ServiceKnauz BMW
2004 E46 M3 6MT | Silver Grey . Cloth | My E46 M3 Build Thread
2009 E90 M3 DCT | Melbourne Red . Speed Cloth | My E90 M3 Build Thread
2002 E46 M3 6MT | Jet Black . Black Nappa | My E46 M3 Build Thread
2016 981 Cayman 6MT | White . Black | Coming Soon
POST YOUR DYNO GRAPH HERE: The Official Dyno Thread
Jump to top flipm3 is offline   Reply With Quote
Old Sun, Oct-03-2010, 07:56:00 PM   #2
405
Reputation: 0 405 is on a distinguished road
M3 looks great..
never knew you were the original owner.. thats really cool..
look forward to whats to come and hopefully checking it out in person!!
-2007 Porsche 997.1 GT3 - Carrara White / Black (Current)
-2002 Porsche 996 Turbo X50 RUF RTurbo Clone - Carrara White / Natural Brown (Gone)
-1996 Porsche 993 RS Clone - Guards Red / Black (Gone)
-2002 BMW E46 M3 - Laguna Seca Blue / Black (Gone)
-2002 BMW E46 M3 - Imola Red / Imola Red (Gone)
Jump to top 405 is offline   Reply With Quote
Old Sun, Oct-03-2010, 08:56:54 PM   #3
flipm3
E46 M3 | E90 M3
flipm3's Avatar
Originally Posted by 405 View Post
M3 looks great..
thanks! hehe yup, original owner
ill try to post up some pics from A LONG time ago later this week.
currently trying to decide further what stuff to do to prep it for the next track season. the past tracks days i went to, i was just too paranoid about a list of things. on the bright side, i was able to safely diagnose problems that need to be addressed.
Old Wed, Nov-10-2010, 04:23:27 AM   #4
vman
vman's Avatar
Reputation: 0 vman is on a distinguished road
Thailand
subscribed!!
2004 TiAg E46 M3 coupe w/ SMG
AP V2 header | Supersprint Section 1 | Supersprint Resonated X-Pipe | Dixis Spirit Exhaust | Evolve-R Stage 2 Tune | Ground Control Camber Plates | Ground Control Street / School Coilovers w/ Sway Bar and Endlinks |Volk TE SL Double Pressed Black - 18x9.5 & 18x10.5 or Apex ARC-8 Hyper Black 18x9.5 ET 35 & 18x10 ET 25 | Turbotoy V3 Hub | Challenge 1x1 CF roof | SGT 1x1 diffuser | SGT FRP CSL trunk | SGT Dual Hole Bumper w/ 1x1 One Piece Lip | FX-R 3.0 w/ Osram CBI bulbs (by LightWerkz) | Evolve Eventuri CAI | Recaro Pole Position seats | Storm Motorwerks V4 Titanium Plated E-Brake w/ Black Alcantara | Storm Motorwerks PVD Titanium Coated and Illuminated SMG Paddles w/ Neoprene Layer | Karbonius Carbon Fiber (1x1) lower steering wheel trim | Karbonius Carbon Fiber (1x1) Dashboard trim | Subframe reinforced with Redish plates
Jump to top vman is offline   Reply With Quote
Old Sat, Jan-01-2011, 11:42:53 PM   #5
williemandowa
Reputation: 0 williemandowa is on a distinguished road
Default Re: flipm3: 2002 Jet Black M3
white volks on black sick
Jump to top williemandowa is offline   Reply With Quote
Old Sun, Jan-02-2011, 07:37:52 AM   #6
flipm3
E46 M3 | E90 M3
flipm3's Avatar
Originally Posted by vman View Post
subscribed!!
thanks for the support! i apologize for no new content nor updates. there's a ton i want to post in here, but i've been so busy with other work. definitely stay tuned
thanks!! i definitely tried to take a more unconventional approach with the aesthetics of the car and so far i love it!
Old Sun, Jan-02-2011, 12:28:49 PM   #7
M3_Aaron
Reputation: 0 M3_Aaron is on a distinguished road
Italy
Looking forward to more pics and updates
E46 M3 Journal
Jump to top M3_Aaron is offline   Reply With Quote
Old Mon, Jan-17-2011, 07:48:30 AM   #8
rome_rod
Reputation: 0 rome_rod is on a distinguished road
Car History
2002 BMW E46 M3
Build Date: 09/01
6 Speed Manual
Bi-Xenon Headlights
CD Player (yes, it was an option back in the day, haha)
Manual Seats
No Sunroof
73,000 Miles as of October 2010
Suspension
Stance GR+ Plus Coilovers
Rogue Engineering Adjustable Rear Control Arms
Rogue Engineering Rear Trail Arm Bushings (Street)
Rogue Engineering Front Control Arm Bushings (Street)
Rogue Engineering Transmission Mounts
Rogue Engineering Engine Mounts
Turner Motorsports Rear Subframe Reinforcement
Turner Motorsports Front Subframe Reinforcement
CDV Removal...
Look at that--she looks awesome. Props to you for a great picture. I am no expert but I think it's great. The lighting, the background--very dramatic.
Jump to top rome_rod is offline   Reply With Quote
Old Sat, Mar-05-2011, 09:29:41 PM   #9
flipm3
E46 M3 | E90 M3
flipm3's Avatar
Default 100% Stock
*reserved*
Old Sat, Mar-05-2011, 09:37:22 PM   #10
flipm3
E46 M3 | E90 M3
flipm3's Avatar
Default Volk Racing CE28N Limited 08' Formula Silver
August 2009
A local shop helped me sell the Mag Blue CE28N's from my past G35, so I decided to use the money on CE28Ns for the M3
Modification:
Volk Racing CE28N 08' Formula Silver
19x8.5 +30mm & 19x10.5 +25mm
Toyo Tires T1R
255/35/19 & 275/35/19
Pros:
1. Lightweight for 19" wheels
2. Forged wheels
3. Look freaking hot!
4. I'm Volks #1 fan boy
Cons:
1. Not cheap
2. 8.5" and 30mm front was not very aggressive, nor wide
3. I didn't have proper tire sizing for the E46 M3, since these were left over tires from my G35. Rear tires were too tall and fronts were too wide for an 8.5"
Sold in March 2010 to save money for my upcoming wheels
2002, black, flipm3, jet
Discussing flipm3: 2002 Jet Black M3 in the Member Journals Forum - Do you have a long term project you would like to share with the community? Use this forum to create a single thread which you can update over time to document the progress. at BMW M3 Forum.com (E30 M3 | E36 M3 | E46 M3 | E92 M3 | F80/X)
