Old Wed, Sep-08-2010, 07:35:19 PM   #1
bimmerboy12
Reputation: 0 bimmerboy12 is on a distinguished road
Default Codes P0102 and P0113... Help
Car has been running amazing, then I cleaned the MAF with CRC and the next day these codes popped up with a definite reduction in power. Have no idea if they are related or not. They are Mass Air Flow Circuit Low Input and Intake Air Temp Circuit High Input. Any ideas before I drop two bills on a MAF?
1988 325iC Project - Exterior Finished, Interior WIP
Build Thread: http://www.r3vlimited.com/board/show...ht=325iC+paint
2001 X5 3.0 - 2001 M3Ci - 1988 325iC
Jump to top bimmerboy12 is offline   Reply With Quote
Old Thu, Sep-09-2010, 12:46:02 AM   #2
bimmerboy12
Any expert advice would be very much appreciated!!
Old Thu, Sep-09-2010, 12:56:37 AM   #3
daytonaviolet
OEM CSL Whoore
daytonaviolet's Avatar
OBD II Code P0102
Mass or Volume Air Flow Circuit Low Input
Our emissions expert has put together the following information about the P0102 fault code. We have also included diagnostic procedures you can take to your repair shop if the mechanic is having difficulty analyzing the code.
OBD II Fault Code
OBD II P0102
Fault Code Definition
The Mass Airflow Sensor (MAF) measures the amount of air entering the engine and the Engine Control Module (ECM) uses the information to determine the proper amount of fuel quantity and ignition timing. The Mass Airflow Sensor P0102 trouble code is set when the ECM detects a low voltage output from the Mass Air flow Sensor.
Symptoms
Check Engine Light will illuminate
In many cases, no abnormal symptoms may be noticed
In some cases, the vehicle may get poor fuel mileage
Common Problems That Trigger the P0102 Code
The MAF Sensor is unplugged or the wiring is damaged
Loose or corroded electrical terminals in the MAF Sensor circuit
Faulty MAF Sensor
Common Misdiagnoses
MAF Sensor Replaced when the wiring is bad
Torn Intake Boot or vacuum leak is the real problem
OBD II Code
Intake Air Temperature Circuit High Input
Our emissions expert has put together the following information about the P0113 fault code. We have also included diagnostic procedures you can take to your repair shop if the mechanic is having difficulty analyzing the code.
OBD II Fault Code
OBD II P0113
The Intake Air Temperature Sensor converts the air temperature into a voltage that is high when the Intake Air is cold and low as the engine warms up. P0113 indicates a high voltage input from the Intake Air Temperature to the Power Train Control Module.
Symptoms
In some cases, the engine may be hard starting and/or get poor fuel economy
Common Problems That Trigger the P0113 Code
Defective Intake Air Temperature Sensor
Dirty air filter
Defective Mass Air Flow Sensor
Faulty or corroded Intake Air Temperature wiring or connections
Common Misdiagnoses
Intake Air Temperature Sensor is replaced when the real cause is a dirty air filter
Intake Air Temperature Sensor is replaced when the real cause is a poor connection or chafed wiring
Tischer aka GetBmwParts
Old Thu, Sep-09-2010, 02:38:35 AM   #4
deilenberger
deilenberger's Avatar
Sounds like you fixed it until it's broken.
There are MAF's on Ebay - OEM - well less then $100. (I seem to recall around $75..)
Old Thu, Sep-09-2010, 02:52:31 PM   #5
bimmerboy12
Thanks guys! I looked into it further, and embarrassingly enough, the connector was not fully clipped in after my MAF clean. Wow I can't believe I just admitted that.
No more codes, runs a lot better with it plugged in lol.
codes, p0102, p0113
Discussing Codes P0102 and P0113... Help in the E46 M3 (2001-2006) Forum - Engine: S54 - Max Hp: 333 hp at 7,900 rpm / 262 lb/ft at 4,900 rpm
