Old Sun, May-30-2004, 03:20:54 AM   #1
Sirius
How many licks..
Sirius's Avatar
Default HOWTO: M-Tec (4 Spoke to 3 Spoke) Steering Wheel Install
This is a how-to I decided to write up on how to install an upgraded wheel.
This mainly pretains to the 96+ models of the E36, but the install on the earlier modles is pretty much the same, except for the wiring part.
This is what I could recall from memory. I think it'll do.
Enjoy!
**** NOTE ****
Disconnect your battery's negative terminal before you begin this to avoid an air-bag light, and to prevent the airbag from accidently deploying. Let the car sit for 10-12 minutes to let all caps discharge.
I will not be held liable for any damage you may cause to your car durring this install.
I didn't get as many pics as I would have liked, so I'll be using several of the same ones with different edits on them. I'll get more later, and add them.
With that garbage out of the way, lets begin!
I am going to be showing you how to install the M-Tech 3-spoke steering wheel, US version.
You will need three parts for this:
Wheel: 32-34-2-228-230
Airbag: 32-34-2-229-030
Steering wheel switch bracket: 32-31-1-162-088
Part numbers and some info taken from here.
Tools you'll need:
  • T-27 Torx Bit
  • Socket set
  • Heat-shrink
  • Quick connect wire connectors
  • Phillips head screwdriver
  • Pocket-sized flathead screwdriver
  • Regular-sized flathead screwdriver
  • About 1-2 hours of your time
Further note: There are attached pictures in this write up that are used as a visual guide. If you are viewing this thread as a guest, you will NOT be able to see them. You will need to register to gain the full benefit of this write up.
Torque specs: Thanks to Hankdoll!
Originally Posted by Hankdoll
This is the best write-up I've found on the 3 spoke swap...easily got me through it. Thanks Trevor! The only thing I'd add are the torque specs for those that'll use this thread in the future:
Originally Posted by Sirius
Put the steering wheel bolt back into place and tighten it, hand tightened.
46 ft-lbs
Re-connect the airbag and horn and resecure it to the wheel using the torx bit. Hand tighten.
71 INCH-lbs
♪♫♪♪♫♪ Trevor ♪♫♪♪♫♪
97' M3. '10 R6.
Old Sun, May-30-2004, 03:26:23 AM   #2
Sirius
How many licks..
Sirius's Avatar
The first thing you need to do is extract your airbag from your current wheel.
Put the key in the ignition and turn it to the second position so you're wheel unlocks and can move freely.
Turn the wheel 90 degrees, this makes it easier to access the screws to the airbag.
On the back of the wheel, there are two holes that give you access to the screws that hold the airbag to the wheel. One hole on each side of the column. These screws take the T-27 bit, they are on really tight, and it would be helpful if your torx bit can attach to a 1/4 in. socket driver.
Undo both until the airbag becomes free. Lift the airbag out, disconnect it and set it aside, face up.
You should now have something similar to the pic.
97' M3. '10 R6.
Old Sun, May-30-2004, 03:32:00 AM   #3
Sirius
How many licks..
Sirius's Avatar
The next step is to remove the steering wheel.
Center the wheel as much as possible.
Grab a 16mm socket, driver and extention.
Undo the wheel from the center bolt. Its on tight, takes some effort.
Once the bolt is out, the wheel slides off. Don't pull too hard because the wheel is still connected via some wires.
The next thing you'll have to do is seperate and remove the bottom plastic trim of the column.
The two peices are snaped together, and have a small plastic retaining clip with a plastic screw in them to hold them into place. They seperate somewhat easily, but they almost sound as if you're breaking them. Should look similar to the pic.
**Note** The pic below has the wheel removed already, but its an example.
97' M3. '10 R6.
Old Sun, May-30-2004, 03:34:21 AM   #4
Sirius
How many licks..
Sirius's Avatar
On the bottom of the lower plastic trim, towards the knee-panal, theres a small plastic screw which is screwed into the retaining clip, and holds the plastic peice into place. You need to remove that.
Unscrew the screw, pop out the clip, set them aside.
Remove the lower plastic trim peice and set it aside also.
You can do all this with the wheel in your lap, or hanging from the wire, as you need to remove that lower peice to get to the connector for the wheel.
97' M3. '10 R6.
Old Sun, May-30-2004, 03:37:00 AM   #5
Sirius
How many licks..
Sirius's Avatar
Once you get the lower peice out and away, you can finally disconnect the wheel and set that aside also.
Follow the wire to the connector. The actual connector is held into place by a small plastic tab, take the connector, rotate it some and it'll pop free, allowing you to disconnect the wires easier.
97' M3. '10 R6.
Old Sun, May-30-2004, 03:39:53 AM   #6
Sirius
How many licks..
Sirius's Avatar
Now its time to remove that upper trim peice. This can be a PITA, and it will amost feel as though you're going to break it, but if you're careful you can extract it without a problem.
The peice is held on by some sticky stuff, for lack of a better term, and another small retaining clip with that plastic screw. The clip/screw is located on the upper portion of the peice.
You can see in the pic below there the clip is. The red is where its connected to the column, and the green is where you want to look on the outside to remove it.
Once you unclip it, you need to remove the peice. Lift up on the front part of it, while pulling out. You'll have to worm it out of its place from under the dashboard, as it has a plastic filler that stick up in the back. This is where it'll feel like you're going to break it. Be patient and it'll come out.
97' M3. '10 R6.
Old Sun, May-30-2004, 03:48:02 AM   #7
Sirius
How many licks..
Sirius's Avatar
Once you get the upper peice out. You'll be left with an exposed column.
Now its time to remove the old switch bracket, and install the new one. But before you can do that, you need to remove all the componets connected to the bracket.
These are your turn signal lever, wiper lever, and if you have it, your cruise control lever.
The nice thing about BMW is that alot of it is snap together.
The switches all slide into place and lock on the bracket.
The turn signal and wiper arms both have two tabs that allow you to 'release' them and slide them out. They are roughly marked by the green arrows.
The cruse control arm has one tab, which you push down while you pull the switch out. Its marked by the pink arrow.
97' M3. '10 R6.
Old Sun, May-30-2004, 03:57:49 AM   #8
Sirius
How many licks..
Sirius's Avatar
Once you get the switches out of the way, its time to put in the new switch bracket. You need a new one for this wheel by where it connects to the wheel physically.
You'll see that on the 4-spoke wheel, theres no horn contact switch. I don't have a pic of that so I'll have to explain it. On the bottom of the switch bracket, theres a small white round thing, with a metal peice sticking out of it. Thats your horn contact switch. For the time being, disconnect that from its connecter underneath the coloumn. (The location of where the horn contact switch will be is marked by the yellow arrow)
Time to remove that bracket. Its held on by another plastic clip with a plastic screw underneath and by clips up top. Undo the plastic screw and clip and put them aside. The bottom clip is marked by the green arrow.
97' M3. '10 R6.
Old Sun, May-30-2004, 04:06:20 AM   #9
Sirius
How many licks..
Sirius's Avatar
Now its time to remove the bracket. On the top of the coloum, is where the bracket is attached by some clips. They are marked by the green arrows.
What you need to do is take the larger flathead screw driver, and push the clips towards the center of the column, while pulling down on the bracket. This will free the bracket and it'll slide right off.
97' M3. '10 R6.
Old Sun, May-30-2004, 04:08:09 AM   #10
Sirius
How many licks..
Sirius's Avatar
Install the new bracket. Slide it up into place until it locks. Reinstall the lower clip and screw.
Slide the arms back into place again. They should lock into place also.
Should now look like this.
97' M3. '10 R6.
4 spoke steering wheel to 3 spoke slipmo E36 M3 (1992-1999) 6 Mon, Jun-30-2008 11:50:53 AM
For Sale: 99 E36 M3 3 spoke M-Tec steering wheel w/ Air Ba gprotein E36 / E30 - Parts for Sale/Wanted 3 Wed, Apr-30-2008 12:08:15 AM
For Sale: 99 E36 M3 3 spoke M-Tec steering wheel with air bag gprotein E36 / E30 - Parts for Sale/Wanted 10 Wed, Feb-20-2008 07:01:26 AM
Anyone install a 3-spoke M steering wheel into a 98 M3/4? gprotein E36 M3 (1992-1999) 2 Fri, Sep-28-2007 05:53:32 AM
Three spoke steering wheel legrena Parts for Sale/Wanted 0 Tue, Mar-01-2005 12:12:26 PM
Discussing HOWTO: M-Tec (4 Spoke to 3 Spoke) Steering Wheel Install in the Faults, Fixes and DIY Forum - Please share your experience and knowledge with other members by contributing your own DIY, or by helping another member find the elusive fix! at BMW M3 Forum.com (E30 M3 | E36 M3 | E46 M3 | E92 M3 | F80/X)
