Old Wed, Jul-14-2010, 12:34:50 AM   #1
e36bmw96
e36bmw96's Avatar
Reputation: 0 e36bmw96 is on a distinguished road
Default p0135 ..cel
Hey Guys
So it's been about a week of trail and error type methods to fix this problem. The code is p0135 which is o2 sensor heater circut malfunction bank 1 sensor 1 I believe. I think the final step is just to buy new o2 sensor and replace it hope it works.
My questions are I guess is that where is the best place to buy OEM sensors, tischer gives them for about 180$ and I think realoem is similar maybe even a bit higher. Is there a good place to go for these?
And lastly is there anyone that knows what the problem could be and how its worthwhile to be fixed besides new o2 sensors. I have looked here and alot on bf.c and some say this fixes the problem while others don't. I have checked all the fuses and relays so this is really my last option. I guess I'm due for new o2 sensors soon so mine as well fix it
2- 96 Hellrot's 1 Modena 1 Schwartz
-Connor
Jump to top e36bmw96 is offline   Reply With Quote
Old Wed, Jul-14-2010, 12:51:40 AM   #2
Maginnovision
Got stock love?
Reputation: 0 Maginnovision is on a distinguished road
If you have a scope you could check the heater for proper operation, or just check the resistance, though I'm not sure of the spec, I'd just check for any resistance, probably 3-8 ohms. Probably just need to replace the sensor though, those heaters don't last forever.
My cars:
1995 BMW M3
1984 Toyota Supra
2007 Honda Civic SI
Jump to top Maginnovision is offline   Reply With Quote
Old Thu, Jul-15-2010, 03:36:00 AM   #3
cnotesdip
Reputation: 0 cnotesdip is on a distinguished road
any updates im getting the same code on my car but an use ebay sensor and still got the same code
Causes
A code P0135 may mean that one or more of the following has happened:
* O2 Heater element resistance is high
* Internal short or open in the heater element
* O2 heater circuit wiring high resistance
* open or short to ground in the wiring harness
Possible Solutions
* Repair short or open or high resistance in wiring harness or harness connectors
* Replace oxygen sensor (cannot repair open or short that occurs internally to sensor)
Jump to top cnotesdip is offline   Reply With Quote
Old Thu, Jul-15-2010, 03:46:11 AM   #4
WRXEATR
The Frugal and Outspoken One
Reputation: 0 WRXEATR is on a distinguished road
The heater circuit is bad in teh sensor. Swap to opposing bank to confirm then replace. o2 sensors are only 70$ @ www.oxygensensors.com
The OEM on these is NTK.
Jump to top WRXEATR is offline   Reply With Quote
Old Thu, Jul-15-2010, 04:25:45 AM   #5
cnotesdip
my lines were torched burned melted together could the new wiring be causing resistance?
Old Thu, Jul-15-2010, 01:19:23 PM   #6
e36bmw96
e36bmw96's Avatar
This is what I am doing.
-Connor
Old Tue, Dec-04-2012, 08:25:05 PM   #7
GunNam
Reputation: 0 GunNam is on a distinguished road
Default Re: p0135 ..cel
I know I'm bringing this thread back from the dead... but I went to the website and it shows different sensors for Cylinders 1-3 vs Cyl 4-6. Are they actually different sensors?
Which side is Cyl 1-3 and 4-6?
Jump to top GunNam is offline   Reply With Quote
Old Wed, Dec-05-2012, 01:37:35 AM   #8
zoti
Reputation: 0 zoti is on a distinguished road
The pre cat and post cat sensors are different and you have two of each.
Jump to top zoti is offline   Reply With Quote
Old Wed, Dec-05-2012, 01:45:34 AM   #9
GunNam
4 sensors! OMG. lol that sounds like $$$$$
cel, p0135
Discussing p0135 ..cel in the E36 M3 (1992-1999) Forum - {Euro - S50 B32 321hp @ 7400 rpm} {U.S. - S52 B32 240 hp @ 6000 rpm}
