Old Thu, May-13-2010, 11:47:45 PM   #1
camlacen
camlacen's Avatar
Reputation: 0 camlacen is on a distinguished road
Default Standard to Harmon Kardon
I just bought a '95 m3 that I've been fixing up a little and the first thing on my list is audio. It has an alpine hu and standard stock speakers. Anyways, it just sounded like every speaker was blown, but I hooked them up to a different stereo and they sounded fine. I tried putting the stock hu back in and it sounded horrible still. So, I went ahead and pulled the amp out since that's the only thing I believe could be causing it. I was wandering if I could put and aftermarket or Harmon Kardon amp in to maybe get a little better sound quality when I do get better speakers.
Jump to top camlacen is offline   Reply With Quote
Old Fri, May-14-2010, 07:58:20 AM   #2
fitchesbass
I couldn't find the sports car of my dreams, so I built it
fitchesbass's Avatar
Reputation: 0 fitchesbass is on a distinguished road
HK sound system was OK for back in the day.
Cheapest oem fitting alternative, with decent support is probably the the BSW speakers and packages.
I am sure there are people on here that have install their system. I installed their mid-range speakers and liked them a lot.
-Derek
Prior BMWs:
E36 M3
E86 Z4MC
E92 M3
Jump to top fitchesbass is offline   Reply With Quote
Old Fri, May-14-2010, 11:29:37 AM   #3
das borgen
Off-Topic King
das borgen's Avatar
Reputation: 0 das borgen is on a distinguished road
OP, check out the sound forums on bimmerforums. BSW is too expensive for what it is IMO but it is pretty well OEM fitting
Jump to top das borgen is offline   Reply With Quote
Old Fri, May-14-2010, 11:32:32 AM   #4
Richardsperry
95 SC M3
Richardsperry's Avatar
No, you can't use a HK amp.
Your best bet is to replace the HU, and the crappy amp.
While the HK is better than the total pos that came in the 95, it's a pos too. Any Best Buy, Buy More, or Walmart sourced stereo will be way better.
If the amp isn't the culpret, (it probably isn't), just getting a CD43, (or any other newer HU), will make things a lot better. Not great, but way better.
Old Fri, May-14-2010, 05:44:04 PM   #5
roundel88
roundel88's Avatar
Reputation: 0 roundel88 is on a distinguished road
As some of the folks already mentioned, you may want to check out Bavarian Soundwerks (BSW). I worked with them recently to get ideas and suggestions on how to solve my problems and found them to be very knowledgeable without pushing their products too hard. I talked to Halston and he diagnosed the issues with my system pretty quickly. My preference is to keep the OEM look and their Stage 1 does just that - it replaces all of the speakers but keeps the stock headunit and amp (~$500 but you can sometimes find a 10% discount code). They also suggested the CD43 to replace my old headunit with the cassette tape, but that will have to wait for a bit.
FYI - the BSW Stage 1 kit is different for HK vs non-HK equipped cars. From what I've read the improvement in bass is much more noticeable when upgrading a non-HK system,
1996 E36 M3
2004 E46 M3 SMG - Sold
1996 328iS - Sold
Jump to top roundel88 is offline   Reply With Quote
Old Fri, May-14-2010, 09:43:22 PM   #6
kingchris
kingchris's Avatar
Reputation: 0 kingchris is on a distinguished road
This is completely wrong as far as the quality of the HK system. I have a HK system with all new speakers (Bav Sound) except the rears with a sub an an oem cd43 w/dice unit and it is stunning. It has very good clarity allowing you to distinguish all the instruments in a song. The sub hits without overpowering. Unless you have experienced a correct operating oem HK system, please don't comment on them. There is enough bad information out there.
98 BMW M3: Cosmos Black w/Magma int.
87 Buick Grand National: Black w/Grey int.
Jump to top kingchris is offline   Reply With Quote
Old Fri, May-14-2010, 09:51:24 PM   #7
Synenergy52
Reputation: 0 Synenergy52 is on a distinguished road
When you say HK system, you mean OE HK amp with BSW stage 1 speakers? I've heard new HK systems even in a new E46 M3. It's garbage. What i'd do is use an aftermarket headunit + BSW stage 1 + BSW amp (AFAIK, they're working on a replacement amp for the factory HK unit)
Jump to top Synenergy52 is offline   Reply With Quote
Old Fri, May-14-2010, 09:57:32 PM   #8
kingchris
kingchris's Avatar
So what do you have? Garbage??? And please don't tell me some walmart set up with a blue headunit.
Old Fri, May-14-2010, 10:37:46 PM   #9
Synenergy52
Actually, yes. I still have the OE HK system. And indeed, it is garbage. And I won't even create a response to your walmart statement.
Old Fri, May-14-2010, 11:32:28 PM   #10
slickfast
Ginger engineer. Gingineer.
slickfast's Avatar
Reputation: 0 slickfast is on a distinguished road
Frown. Maybe I'm just easy to please, but I have a CD43 with the HK amp and BSW Stage 1 kit and I think it sounds absolutely fantastic. I'm not one to like a real thumpy system though, so maybe that's it. I have turned it up as loud as I can stand and I didn't get a hint of distortion... that combined with the extremely clear sound and OEM look is really all I can ask for.
EDIT: On second thought, I'd love for it to have an aux in port. I've heard awful things about the DICE kits.
Jump to top slickfast is offline   Reply With Quote
harmon, kardon, standard
Discussing Standard to Harmon Kardon in the E36 M3 (1992-1999) Forum - {Euro - S50 B32 321hp @ 7400 rpm} {U.S. - S52 B32 240 hp @ 6000 rpm}
