Old Fri, Apr-23-2010, 01:45:24 AM   #1
djtrini
Reputation: 0 djtrini is on a distinguished road
Default E46 HK Sub Amp diagram?
Hey guys.
IM trying to install a LOC in my 05 E46 330i Sedan has the HK system.
I want to tap off the Sub amp on the rear deck, I have used the full range method from BSW in my M3, and I found that I couldn't turn the volume up very loud without losing output with my subwoofer.
anyone have any ideas?
Jump to top djtrini is offline   Reply With Quote
Old Mon, Apr-26-2010, 09:00:36 PM   #2
Gregs///M
Gregs///M's Avatar
Reputation: 0 Gregs///M is on a distinguished road
Italy
It might be in this thread
http://bimmer.roadfly.com/bmw/forums...786337&page=10
2003 Alpine White BMW M3 Coupe
Modifications:Dice Ipod Interface [] Focal Utopia 6.5in components speakers(front), Focal Utopia 5.25in component speakers (rear) []JL Audio W3V3 Sub Woofer []
Eclipse Xa5000 5 ch amplifier [] Clifford 50.7 two way pager [] Custom interior trim (OEM Alcantara) [] Dinan Stage I tune. []
Owner of Bavarian Restoration - www.BavRest.com
Jump to top Gregs///M is offline   Reply With Quote
Old Sun, May-16-2010, 01:09:08 PM   #3
zhp43867
Reputation: 0 zhp43867 has disabled reputation
What I did was I actually tapped the subwoofer speaker outputs from the sub amp. I look for the sub amp wiring and it is very confusing, I'm not sure it's possible to directly tap the signal in between the main amp and sub amp. You could also tap the amp inputs from the head unit (main amp).
Originally Posted by Tock172
Yeah, we get it. Everyone has the inalienable right to be a total ****ing idiot.
Jump to top zhp43867 is offline   Reply With Quote
Old Sun, May-16-2010, 09:02:37 PM   #4
ILLuSioNz X
Built, not bought
ILLuSioNz X's Avatar
Reputation: 0 ILLuSioNz X is on a distinguished road
i found my stock subs to be tapped in right from the output from the sub amp.
-Chauncey
2003 E46 M3 COUPE
Engine/Transmission: "Bolt-on's"
Wheels/Tires: 18 TE37SL & Falken RT615K
Suspension: TRM Coilovers 780F/895R|OEM Front & Turner Rear Reinforcement Plates|RE Rear Spring Perch Reinforcement|GC Race FCABs|GC Monoball RTABs|Godspeed LCAs|Turner Monoball Upper CAB|Turner Sway Bars|Turner Subframe Reinforcement (installed by Coinage)|Turner Solid Subframe, Differential, Motor and Transmission Mounts
Braking: Rotora 4-Piston Calipers|S/S Lines|Ate Dot4|Powerslot Rotors|Ferodo DS2500 Brake Pads
The Official Supercharger Kit Maintenance/Replacement Parts Thread (VF, AA and ESS)
Jump to top ILLuSioNz X is offline   Reply With Quote
amp, diagram, e46
Discussing E46 HK Sub Amp diagram? in the Audio/In Car Entertainment (I.C.E.) Forum - Place to discuss sights and sounds. at BMW M3 Forum.com (E30 M3 | E36 M3 | E46 M3 | E92 M3 | F80/X)
