Old Tue, Apr-20-2010, 05:11:49 PM   #1
Gtfour
Gtfour's Avatar
Reputation: 0 Gtfour is on a distinguished road
Default Not another E46 M3 track car project ;)
So this is my BMW E46 M3 2002 for 2010 track season. I'm preparing the car for lapping & Time Attack purpose this year.
Starting with the modifications list:
Exterior
-Vorsteiner VRS vented race carbon fiber hood
-Sunroof glass replaced with carbon fiber insert
-Vorsteiner V-CSL carbon fiber trunk
-APR GTC-300 carbon fiber wing with custom mount bracket
-SPA GT/LeMans mirrors
-Rear bumper vents
-front fenders vents
-Matte black kidney grill & side grill
-Smoked turn signal lights
-Smoked side marker lights
-Custom BMW emblem
-AeroCatch racing hood fasteners
-Lexan rear windows
-Alumalite front splitter / undertray panel
-Bimmerworld canards / Front dive planes
Interior
-Recaro Pole Position black velour seats / aluminium side mounts / custom floor mounts
-OMP Corsica Superleggero 350mm suede steering wheel
- MOMO steering wheel hub adapter
-OMP 1010 pedals
-OMP Formula 6point harness / Racetech 5 point harness
-Jaffster shiftknob (long)
-Carbon fiber trims
-Wink multi-panel mirror (5)
-Kirk 4point roll-bar
-BMW radio blank plate
-Braille battery (11lbs)
Handling
-Moton Clubsport 2-way, coilovers rears
-Hyperco springs (900 front/500rear)
-Hyperco helper springs
-Ground Control racing front swaybars
-Ground Control adjustable swaybar end links
-Moton rear shock mounts
-Ground Control camber/caster plates
-Ground Control front control arms bushings
-Turner Motorsport adjustable rear camber arms
-Turner Motorsport front subframe reinforcement kit
-Turner Motorsport front strut tower reinforcement plates
-Turner Motorsport rear subframe reinforcement kit
-Turner Motorsport rear strut tower reinforcement kit
-BMW oem front strut brace
-BWsport 12mm spacers
-Turner Motorsport 75mm studs kit
-BMW Motorsport front control arms
-Ground Control adjustable tie rods
Braking
-Stoptech ST-40 4 pistons big brakes kit
-AeroRotors slotted 355mmx32mm floating discs
-Performance Friction PF01 race pads
-Stoptech stainless steel brakes lines
-Turner Motorsport carbon fiber brake backing plates
-Bimmerworld carbon fiber brake ducts
-3” brake duct hoses
Engine
-Shark injector race version performance software
-Turner Motorsport / Fluidyne oil cooler kit
-BMW Motorsport thermostat 55degrees
-Custom 3" exhaust line
-Catless stainless steel headers
-Evosport underdrive pulleys
-K&N typhoon cold air intake system
-Group N motor mounts
-Bimmerworld brass radiator bleeder screw
-Bimmerworld S54 EGR delete block-off plates
-Bimmerworld S54 Magnetic oil drain plug
-Bimmerworld Oil cooler diverter valve
-Spal 16” pusher type fan, straight blades
-Bimmerworld water pump shaft nut
-Custom stainless steel clutch stop
-Gulf 10w60
Wheels & Tires
-Champion/RAC Monolites RS110 18”X9.5” et35
-SSR Type C 18’’x9.5’’ et35
-TR MT1 18"x9.5" et35 18"x10" et25
-Pirelli P-ZERO Corsa 265/35r18
-Pirelli slicks 265/645r18
-Hoosier R6 275/35r18
Transmission/drivetrain
-UUC Short Shift Kit - Evo 3 with dual shear selector rod
-BMW Motorsport custom built 4.10 pinion/ring differential
-BMW Motorsport transmission mounts
-Redline D4 ATF
-Clutch Master stage 3 FX300 with JB aluminium lightweight flywheel
-Powerflex differential mounts
-Redline 75w140
Will put some pictures in the next hour, need to translate everything from french (my first language) from another forum where i did the same post.
Jump to top Gtfour is offline   Reply With Quote
Old Tue, Apr-20-2010, 05:23:17 PM   #2
Gtfour
Gtfour's Avatar
So here is the evolution of the project from january 2010:
01/18/2010
Looks like a thief recovery car!
02/01/2010
-I clean a bit the engine bay and removed things like the EGR air-pump, plastic trims, ducts,...
I installed a Vorsteiner carbon fiber hood
Also put a CSL carbon fiber trunk
Install Bimmerworld carbon fiber brake ducts and some CSL front splitters replica
I removed the sunroof and installed the carbon fiber sunroof from Ebay, fitment is not perfect but will live with that
Install a Kirk 4 point roll bar
Here is the Jaffster delrin shift knob
Also removed the sound deadning
02/15/2010
Playing with the wiring harness...
Old Tue, Apr-20-2010, 05:37:56 PM   #3
Gtfour
Gtfour's Avatar
I did some custom aluminium dash block off plate cause i removed the heater control, radio, ...
- Braille Battery 11Lbs VS Mini/CSL 36Lbs
-New Clutch Master FQ300 with lightweight flywheel
-Installing the CF sunroof delete skin
Here is my APR GTC-300, need to do some custom brackets to fit to the car and not to the trunk.
02/24/2010
Dash is back into the car
03/23/2010
Installed the Spal 16" pusher fan with customs brackets
Changed heim joints on the swaybars links and now need to put new 3" brake duct hose
Stoptech BBK 355mm all around will make a nice difference from oem setup, can't wait to try that mods.
Installing the new clutch and flywheel
Switch from Turner swaybars to Ground Control
Change the alternator also
And the kind of parts people put on my car when i'm not there...
Old Tue, Apr-20-2010, 05:48:10 PM   #4
Gtfour
Gtfour's Avatar
-Install UUC EVO 3 short shifter kit with double shear rod
-K&N typhooncold air intake
-Wink 4 panels mirrors
-Aerocatch hoods pins
-CF skin installed, what a pain in the ass
-Some CF fabrics on the aluminium plates
04/10/2010
Tranny is back in place
I changed my motor mount, the one on the passanger side was 1/2" shorter...
Playing with the clutch slave
Here is my custom Alumalite 6mm splitter, still under construction and not fix to the car on pictures.
SSR Type C 18''X9.5'' et35 in flat black.
Here is the street car on RAC Monolites RS110 18''X9.5'' et35 with Pirelli Corsa 265/35r18
Old Tue, Apr-20-2010, 06:47:39 PM   #5
APIindy
APIindy's Avatar
Reputation: 0 APIindy is on a distinguished road
Nice project, why not weld in the cage since you already have the car apart?
MODS: 03 M3, 6MT, PSS9, 18" OEM Square setup, El Diablo Exhaust, non-resonator section one, Turner Motorsports Rear Adjustable Camber Arms, Powerflex bushings, Stoptech slotted rotors, Hawk track pads, UUC stainless steel brake lines, AFE Cold Air Intake, Hamann front splitter
Driver that grins ear to ear everytime he drives it
NASA instructor
Jump to top APIindy is offline   Reply With Quote
Old Tue, Apr-20-2010, 07:06:52 PM   #6
BM-Power
BM-Power's Avatar
Reputation: 0 BM-Power is on a distinguished road
+1
Nice project though.
1994 E34 M5 Touring 3.8L Daytona Violet
2007 E60 M5 5.0L Alpine White
2010 E70 X5 3.0L TT Alpine White
2003 E46 M3 3.2L Silver Grey/Orange EVOSPORT - SPARCO - VORSTEINER - H&R - ROTORA - ENKEI - CONTINENTAL
Jump to top BM-Power is offline   Reply With Quote
Old Tue, Apr-20-2010, 08:45:15 PM   #7
PerkM3
PerkM3's Avatar
Reputation: 0 PerkM3 is on a distinguished road
Great project, I love seeing e46 M's go from daily to full track. A road that I will hopefully be going down soon.
One question I have though is how are you gonna mount the wing? Everyone I have spoke to says that the V CSL carbon fiber trunk is to thin to mount any wing to.
Cosmetic/Aero: BW splitter, BW canards, Brooks pro wing, V-CSL bootlid, Tekerbon CSL diffuser, V-GTR hood, CF moonroof delete, CF kidney grills, CF gills, and CF roundels
Suspension/Brakes: MOTON CS 850/450 (rear coilover), GC F/R race sways, RE FCAB/RTAB (track), TMS rear camber arms, GC race camber plates, TMS solid subframe bushings, ZCP F/R rotors, brass caliper guides, BW SS lines, PFC RH665, PFC-01, BW brake ducts/baking plates.
Performance: BW/EPIC Tune, aFe stg2 intake, SS V2 stepped headers, BW race exhaust, TMS pullies, JB Racing clutch/LW flywheel, TMS solid motor mounts, TMS solid trans mounts, BW solid diff mounts, RE shifter linkage, and BW race shifter.
Misc: TMS subframe reinforcement kit, Sparco PRO ADV seat, Sparco side mounts, VAC floor mounts, Kirk Comp. Roll Bar, Schroth Profi III 6-Point harnesses, Jafster shift knob, BimmerWorld 75mm wheel studs, and Enkei NT03+M.
Jump to top PerkM3 is online now   Reply With Quote
Old Tue, Apr-20-2010, 09:21:01 PM   #8
kaiv
SoCal vanos/valve specialist :D
France
Some great stuff!! I've been thinking about making a similar splitter/under tray.
AW S65 E92 6MT
past: AW S65 E90 6MT- LSB S54 E46 6MT- JB S52 E36 5MT
Kaiv's SoCal Feedback! [M3Forum] [iTrader] [Bimmerforum]
Old Tue, Apr-20-2010, 09:32:16 PM   #9
Gtfour
Gtfour's Avatar
I was supposed to do a full cage but time is missing. I taught i would have all winter long to prepare the car at the shop, finally i work at home till march...
Anyway, i will go with the roll cage next winter, it will be a nice project for 2011, and the shop might double size during the summer. So i will have some space to work
Old Tue, Apr-20-2010, 09:37:51 PM   #10
Gtfour
Gtfour's Avatar
The carbon fiber skin on the top of the trunk is so thin you can barely see throught... No way a wing would stay fix to it at 100mph.
I will make custom bracket to mount it similar to that car, i will have to remove the wing to open the trunk.
car, e46, project, track
Discussing Not another E46 M3 track car project ;) in the M3 Track: Racing and DE Forum - Best mod for speed is learning to get the most out of what you currently have. Tracks and DE's is the place to start! at BMW M3 Forum.com (E30 M3 | E36 M3 | E46 M3 | E92 M3 | F80/X)
