Old Mon, Apr-05-2010, 02:48:01 PM   #1
Surk///M
Reputation: 0 Surk///M is on a distinguished road
Default Front whl bearing hub nut size
My RF front wheel bearing is starting to hum..so time to change soon--What size is the front hub nut socket .. is this a DIY if I have the proper torque wrench and is 214ft\Ibs correct torque??
Jump to top Surk///M is offline   Reply With Quote
Old Mon, Apr-05-2010, 03:47:28 PM   #2
APIindy
APIindy's Avatar
Reputation: 0 APIindy is on a distinguished road
You will need a 46mm socket to remove the nut. I think there are DIY instructions on e46fanatics. It is very straight forward.
Here is a video on how to do it. http://www.youtube.com/watch?v=OU2xS...eature=related
If you have any issues, PM me and I can help you out.
MODS: 03 M3, 6MT, PSS9, 18" OEM Square setup, El Diablo Exhaust, non-resonator section one, Turner Motorsports Rear Adjustable Camber Arms, Powerflex bushings, Stoptech slotted rotors, Hawk track pads, UUC stainless steel brake lines, AFE Cold Air Intake, Hamann front splitter
Driver that grins ear to ear everytime he drives it
Jump to top APIindy is offline   Reply With Quote
Old Mon, Apr-05-2010, 04:54:15 PM   #3
Surk///M
I'm getting conflicting info on the size..some say 36mm others 46mm..need to know what socket size I'll need as I have access to a shop-hoist-impact etc..
Old Sun, May-15-2011, 03:52:39 PM   #4
chalaka
Reputation: 0 chalaka is on a distinguished road
Taiwan
Default Re: Front whl bearing hub nut size
i would like to know too .. keep seeing conflict information .. anyone? 36mm or 46mm??
Jump to top chalaka is offline   Reply With Quote
Old Sun, May-15-2011, 04:16:55 PM   #5
kidrobot
Reputation: 0 kidrobot is on a distinguished road
It's definitely 46mm
Oh, and I highly recommend a jaw puller. The inner race WILL stick onto the shaft as shown in that video.
The video is correct in that you should NOT push the new hub on by the outside hub. This will ruin your new hub bearing because it will knock out the inner race as you push it on. You essentially want to push the new hub on using the inner bearing-race as your point of impact.
The video suggest using a bearing push tool. You can simply use the old inner race that you used the jaw puller on matched with your 46mm socket and bang it on.
Jump to top kidrobot is offline   Reply With Quote
Old Sun, May-15-2011, 05:45:20 PM   #6
WheezyM3
Reputation: 0 WheezyM3 is on a distinguished road
I just ordered a new front wheel bearing as well since mine is completely shot. I've seen some say to replace both fronts at the same time, is this the case or should I just wait until the other side goes to replace it? (2003 80k miles)
And check out e46fanatics for a very good DIY as well.
Jump to top WheezyM3 is offline   Reply With Quote
Old Sun, May-15-2011, 05:50:18 PM   #7
chalaka
Taiwan
thanks for the great info and confirmation ..
planning to do a DIY on the bearing soon too .. pocket is going empty soon .. sigh ..
bearing, front, hub, nut, size, whl
Discussing Front whl bearing hub nut size in the E46 M3 (2001-2006) Forum - Engine: S54 - Max Hp: 333 hp at 7,900 rpm / 262 lb/ft at 4,900 rpm
