Old Thu, Mar-18-2010, 03:28:16 PM   #1
405
405's Avatar
Reputation: 0 405 is on a distinguished road
Ireland
Default how accurate are the generic 03.5+ reverse lights to OEM reverse lights?
i want to upgrade my 02 tailights to the 03.5+ LED look. i found an OEM set for sale but they do not include the reverse lights, only the tailight. i know the actual OEM tailight compared to the generic brand (EE, umnitza) is different with the black line that goes around the inner part of the light, etc, so thats why i want to stick with oem besides the quality.
i found a generic set of ebay 03.5+ reverse lights that i could pair up with the OEM tailights and im wondering if there is any differences between the generic reverse light and the oem reverse light?
http://cgi.ebay.com/ebaymotors/99-00...item45f18bb7cc
thanks
-2012 Tornado Red/Interlagos Golf GTI
-2012 Ducati 848 EVO Corse SE
-2011 Triumph Bonneville T100 Cafe
Jump to top 405 is offline   Reply With Quote
Old Thu, Mar-18-2010, 04:12:39 PM   #2
e46fanatic...
e46fanatic...'s Avatar
Reputation: 0 e46fanatic... is on a distinguished road
The only thing I can think of it's fitment not being as good as OEM. As far as light quality it's probably the same since they both use regular light bulbs and IIRC the lower red part doesn't even light up on OEM.
Jump to top e46fanatic... is offline   Reply With Quote
Old Thu, Mar-18-2010, 05:25:16 PM   #3
405
405's Avatar
Ireland
right
thats what i thought too. my buddy has the smoked LED EE's and his reverse lights look the exact same to the oem's ive seen.
any other info would be great
thanks!
chase
Old Thu, Mar-18-2010, 05:35:34 PM   #4
100degrees
Reputation: 0 100degrees is on a distinguished road
China
I have a set of EE Tails and the fitment on the trunk lights are perfectly fine. I would say they fit as well as OEM.
Jump to top 100degrees is offline   Reply With Quote
Old Thu, Mar-18-2010, 05:53:05 PM   #5
405
405's Avatar
Ireland
sounds good
thanks
since fitment seems not to be an issue..
the off-brand reverse lights will work in conjunction with the OEM tailights correct? are they linked together at all even?
Old Thu, Mar-18-2010, 10:29:02 PM   #6
e46fanatic...
The trunk lights use a different connector than the main rear ones since they are only needed during reverse.
To get to the connector you're going to need to undo some clips on the inner carpet of the trunk to gain access.
Also make sure you have the retrofit cables for the main rear ones since they are OEM they use a different connector than pre-03.5 and they won't connect directly as after market taillights. Tischer has them.
035, accurate, generic, lights, oem, reverse
Discussing how accurate are the generic 03.5+ reverse lights to OEM reverse lights? in the E46 M3 (2001-2006) Forum - Engine: S54 - Max Hp: 333 hp at 7,900 rpm / 262 lb/ft at 4,900 rpm
