Old Mon, Mar-01-2010, 02:09:17 AM   #1
ospfbgp
Reputation: 0 ospfbgp is on a distinguished road
Default gm5 module issues
Problem: My passenger vent window would not close. I checked the switch with a meter and it was good. I then reversed the wires on the motor and now it would close but not open. So I then started doing some research and found that the gm5 module controls the doors and windows with relays. These relays are not serviceable without being able to solder in a new relay. Plus you must find a place to get these special little relays.
Resolution: I found a website called http://www.bmwgm5.com/ and Scott is the person who does the work on the gm5. I found all the information I need there to help me make sure I had the right problem. I then sent Scott an email and told him my problem and he agreed that it could be the relays. I then removed the gm5 from above the glove box and shipped it off. I shipped it via ups on Monday and Scott got it on Wednesday. Scott then soldered in new relays and sent it back same day via usps. I got the module back Saturday and installed. Now my vent window opens and closes. The cost was much cheaper than going to the stealer and getting a new gm5 and have it programmed.
I want to say thanks to Scott and thanks for all the information on http://www.bmwgm5.com/. This guy is top notch and did a great job. if any of you have problems with the relays on the gm5 then send it to Scott and he can fix it up.
Jump to top ospfbgp is offline   Reply With Quote
gm5, issues, module
Discussing gm5 module issues in the E46 M3 (2001-2006) Forum - Engine: S54 - Max Hp: 333 hp at 7,900 rpm / 262 lb/ft at 4,900 rpm
