Currently doing some math
![]() Location: NY/NJ
Problem solved, thanks.
-Chauncey 2003 E46 M3 COUPE VF570 Build Journal The Official Supercharger Kit Maintenance/Replacement Parts Thread (VF, AA and ESS) ► ILLuSioNzX Garage Sale ◄ Last edited by ILLuSioNz X; Wed, Mar-03-2010 at 06:40:25 PM. |
1,2,6th
![]() Location: Ontario
Well sounds like you may have a wrong control arm or its different then OEM and for your lights that came on, sounds like you may have done something to the wheel speed sensor. Did you hit it or disconnect in the process? All the lights correspond with a wheel speed sensor.
![]() 02 M, Gloss black side gills, Tein S-Tech's, DBA brakes, 245/35/19 & 275/30/19. |
-Chauncey 2003 E46 M3 COUPE VF570 Build Journal The Official Supercharger Kit Maintenance/Replacement Parts Thread (VF, AA and ESS) ► ILLuSioNzX Garage Sale ◄ Last edited by ILLuSioNz X; Wed, Mar-03-2010 at 06:40:44 PM. |
#4 |
Supersprint North America
![]() Location: Austin, TX
Hmm...
Well here's my $.02 I'm thinking they sold you a standard E46 Control Arm and you have now bolted it to your M3. A quick check shows me that the E46 M3 control arms are 100% unique to the M3 and that there are no aftermarket arms available, only OE Lemfoerder arms. What this means is that there is going to very little aftermarket company support for building a supply a totally unique product for a, in relative numbers, low production car, thus the reason the OE arms are so expensive. Sooo what can you do to sort it out. Did you, or can you take any pictures of the new arm? Did you visually compare the two arms when you swapped them. Though both the standard E46 and E46 M3 arms are aluminum and "boomerang" shaped, the M3 arm's inner arc is noticeably different. If all of that matches up, I suggest pulling the arm off and actually comparing the measurements between the two ball joints on each arm. The E46 M3 arm is going to be wider, because the car itself has a wider track. Obviously with a standard E46 arm on one side this would severely alter the alignment and cause the issues you are having. Either way, an alignment is 100% required when R&R control arms. The rash of idiot lights sounds like a wheel speed sensor. All of the systems you listed use the information from a speed sensor in one way or another. Check to make sure you reconnected, if you disconnected it at all, or did not damage the wheel sensor. And lastly...if you cannot reattach the headlight adjustment rod...thats just icing on the cake that this is NOT the right part for the car.
~~~~~~~~~~~~~~~~~~~~~~~~~~ ![]() BMP Design PROMINI Supersprint NA Jared Bronson BMP Design Inc. Supersprint NA 3208 Park Center Drive Tyler, TX 75701 Toll Free: (800) 648-7278 ext. 221 Direct: (903) 262-9961 Fax: (903) 581-8206 j.bronson@supersprintna.com |
#5 |
The wheel speed sensor bolts to the back of the wheel hub/ strut assembly. It points directly to the back of the wheel bearing and gets the reading by measuring how fast the "teeth" go past. If you look from the back side of the rotor you should be able to trace the wiring fairly easily.
#6 |
-Chauncey 2003 E46 M3 COUPE VF570 Build Journal The Official Supercharger Kit Maintenance/Replacement Parts Thread (VF, AA and ESS) ► ILLuSioNzX Garage Sale ◄ Last edited by ILLuSioNz X; Wed, Mar-03-2010 at 06:41:00 PM. |
#7 |
![]() Location: Washington, DC
Lemfoerder makes the BMW arm. Check pricing at Turner Motorsport or Bimmerworld.
2006 GMC Sierra 2500HD 4WD Duramax LBZ/Allison 2002 BMW M3 Alpinweiß/Black - JBL MS-62C, IDQ-12v3, JBL MS-8 1999 323i KP/GTS2 Alpinweiß - Hood-in-the-windshield mod 1990 325is Brilliantrot/Tan - GC/Bilstein, Sway 1989 325is Alpinweiß/Black - S50B30, GC/Koni, Sways, BBS RX, Hybrid C61-2, Sundown SA-12, JBL MS-8 1989 M3 Alpinweiß/Black - S50B32. 321hp. ![]() Hers: 1996 Porsche 911 Turbo Black/Black Hers: 1988 325iX Coupe Diamondschwartz/Black 5spd - Korman lengthened front driveshaft, Cam, Bilstein, H&R Sport, snow chains.
#8 |
The only difference between the Lemfoerder arm and the Genuine BMW arm is....the Genuine BMW arm will have the BMW roundel on it. That's it. In fact, there's a good chance the Lemfoerder will too, it just depends on if they actually have a separate mold or not.
Either way, the OE Genuine arm IS a Lemfoerder arm, they make them for BMW.
#9 |
-Chauncey 2003 E46 M3 COUPE VF570 Build Journal The Official Supercharger Kit Maintenance/Replacement Parts Thread (VF, AA and ESS) ► ILLuSioNzX Garage Sale ◄ Last edited by ILLuSioNz X; Wed, Mar-03-2010 at 06:41:07 PM. |
#10 | |
![]() Location: Earth
NASA E46 M3 GTS3 #73 Race car![]() E92 M3 AW, 6MT, EDC, 19" 220M - race car for the daily commute |
| arm, control, front, major, problem |
