Old Sat, Jan-09-2010, 06:22:18 PM   #1
Daydrea///M
Reputation: 0 Daydrea///M is on a distinguished road
Default Adjusting Factory Alarm Sensitivity
As much knowledge as I've been able to collect thought these forums, I haven't been able to find any info on how to adjust the sensitivity of the factory alarm system. It is waaay to sensitive and everytime I park it on the street all it takes i a bus or truck to roll by to set it off. I've had neighbors complain and my main worry now is someone messing with my car when it goes off...
Is this something that can be done DIY or am I gonna have to go to the stealer to fix this?
Thanks!
Jump to top Daydrea///M is offline   Reply With Quote
Old Sat, Jan-09-2010, 07:33:06 PM   #2
e46fanatic...
e46fanatic...'s Avatar
Reputation: 0 e46fanatic... is on a distinguished road
I don't know about adjusting the sensitivity, but if you press the alarm button twice when you arm it instead of once you take out one sensor, but I forgot which one. You can try that first.
Jump to top e46fanatic... is offline   Reply With Quote
Old Sat, Jan-09-2010, 07:39:12 PM   #3
roobe16
Certified Naysayer
roobe16's Avatar
Reputation: 0 roobe16 is on a distinguished road
Antarctica
That would be the interior motion sensor that is disabled with pressing the key fob lock twice. I'm guessing it's the tilt sensor that is causing your false alarms with vibrations. OP you might want to make sure the tilt sensor in the trunk is firmly secured.
Jump to top roobe16 is offline   Reply With Quote
Old Sat, Jan-09-2010, 09:36:09 PM   #4
Cutlass476
Cutlass476's Avatar
Reputation: 0 Cutlass476 is on a distinguished road
I thought when you push the lock button a second time it disables the "tilt" sensor so you can have the vehicle towed while being locked. I didn't think you could disable the interior motion sensor.
SOLD2006 Blk/Blk M3, 6spd, Nav, Premium & Cold Wx pkgs., HK, Park Distance, SS Race w/black chrome tips, Autosolutions SSK, CDV delete, Rogue Xmsn mounts, GSB Clutch pedal, HRE 441's/Gloss Black centers w/polished lip-9.5" front with 245/35-19 & 10" rear with 285/30-19
Jump to top Cutlass476 is offline   Reply With Quote
Old Sun, Jan-10-2010, 04:32:18 AM   #5
ILLuSioNz X
Built, not bought
ILLuSioNz X's Avatar
Reputation: 0 ILLuSioNz X is on a distinguished road
subscribed-would like to know this as well.
-Chauncey
2003 E46 M3 COUPE
Engine/Transmission: "Bolt-on's"
Wheels/Tires: 18 TE37SL & Falken RT615K
Suspension: TRM Coilovers 780F/895R|OEM Front & Turner Rear Reinforcement Plates|RE Rear Spring Perch Reinforcement|GC Race FCABs|GC Monoball RTABs|Godspeed LCAs|Turner Monoball Upper CAB|Turner Sway Bars|Turner Subframe Reinforcement (installed by Coinage)|Turner Solid Subframe, Differential, Motor and Transmission Mounts
Braking: Rotora 4-Piston Calipers|S/S Lines|Ate Dot4|Powerslot Rotors|Ferodo DS2500 Brake Pads
The Official Supercharger Kit Maintenance/Replacement Parts Thread (VF, AA and ESS)
Jump to top ILLuSioNz X is offline   Reply With Quote
Old Sun, Jan-10-2010, 05:43:12 AM   #6
TheArchitect
TheArchitect's Avatar
Reputation: 0 TheArchitect is on a distinguished road
It has gotten so bad for me that now I lock the car with the key so the alarm doesnt arm... It so sensitive now that its cold out that it goes off all the time.... I would really wanna know how to do this, its just embarrazing, and locking the car by hand just sucks....
Jump to top TheArchitect is offline   Reply With Quote
Old Sun, Jan-10-2010, 04:29:06 PM   #7
roobe16
Certified Naysayer
roobe16's Avatar
Antarctica
Sorry you were right too, when pressing the lock button a second time it disables the interior motion sensor (useful if you lock the car with the windows open or a pet/child inside) and the trunk tilt sensor (useful if having the vehicle towed, like you said).
Reference Page 29 of the owner's manual.
A common problem with the OEM alarm system is the hood sensor switch malfunctioning or getting stuck. Near the positive battery terminal under the hood there is a pin that is pushed down when the hood is down. If the pin is stuck or broken, while the car is locked the alarm system thinks someone is opening the hood and the alarm goes off. Try disconnecting or fiddling with the hood sensor switch - if that fixes your false alarm problem, the switch is a cheap thing to replace.
Old Sun, Jan-10-2010, 06:34:24 PM   #8
TheArchitect
Thanks man, I'll def check that out... Also, now that I've been reading about the trunk sensor and stuff made me think that maybe putting trunk bike rack on my car might have something to do with it ... It's one one of the best trunk racks and the bike is only 15 lbs... Do u think that that might have something to do with it??? Thanks once again
Old Sun, Jan-10-2010, 07:14:43 PM   #9
franklin
Reputation: 0 franklin is on a distinguished road
+1 on "A common problem with the OEM alarm system is the hood sensor switch malfunctioning or getting stuck" I almost had my M lit on fire as the folks living around me had torches and pitchforks as my alarm was going off for no reason... it WAS the hood sensor...
Jump to top franklin is offline   Reply With Quote
Old Sun, Jan-10-2010, 10:26:44 PM   #10
Daydrea///M
Took a look at my hood sensor switch as well..... Looks to be ok (i unplugged and re-plugged it a few times)
Gently nugged my bumper, no alarm... so far so good.
Problem is I can't bring myself to hit it any harder than a light tap to really test it out...
adjusting, alarm, factory, sensitivity
Discussing Adjusting Factory Alarm Sensitivity in the E46 M3 (2001-2006) Forum - Engine: S54 - Max Hp: 333 hp at 7,900 rpm / 262 lb/ft at 4,900 rpm
