Old Wed, Dec-30-2009, 02:13:23 AM   #1
RaceMX-M3
Scott@Radar-Mirror.com
RaceMX-M3's Avatar
Reputation: 0 RaceMX-M3 is a jewel in the rough
Default DIY: S54 Cylinder Compression Test
DISCLAIMER - I am posting this DIY for informational purposes only. If you are not comfortable doing this yourself or do not own the correct tools then I suggest you take your car to a qualified professional to perform the test. I am simply sharing my personal method for conducting the test and assume no liability for damage to your car. For reference I have included a copy of the instructions from the Bentley Manual. My instructions differ slightly from the Bentley Manual.
Remove the four (13mm) nuts indicated and remove the strut brace
Remove the cover attached to the front of the rain tray
Remove the two cables from the front of the rain tray
Release the 3 clips indicated by pushing down gently and turning counter-clockwise and remove the cover on top of the rain tray and the cabin filter
Remove the 4 torx bolts indicated (T-30) and remove the rain tray
Remove the two clips as indicated and remove the plastic cover from the front of the engine
Push the cover forward and then pull up
Remove the 6 nuts (10 mm) securing the engine cover
Remove the oil filler cap and engine vent hose, remove the engine cover by pulling up gently at the front and rear of the cover
Re-install the oil vent hose and oil filler cap and remove the plastic cover on top of the ignition coils
Start the car and allow the motor to warm up to normal operating temperature and then shut the motor off and take the key out of the ignition
Remove the four torx bolts (T-25) from the ECU cover
There are 5 black connectors plugged into the factory ECU. Disconnect the connectors labeled by the RED NUMBERS 1, 2 and 3... RECONNECT connectors 1 and 2 and leave connector 3 unplugged until the compression test has been concluded.
***NOTE Turning the ignition key on with the connector unplugged will throw a EML light. The EML light will go away after the ignition is cycled on/off twice, however codes may remain and need to be cleared by an authorized BMW service center or using a handheld scan tool.
*Optional - I connect an automotive battery charger to the pos/neg connections on the passenger side of the engine bay during the compression testing.
Remove all six ignition coils and spark plugs
Press the throttle linkage downward to open all of the throttle bodies and prop it open for the duration of the testing
You may now carry out compression testing for each of the cylinders. Attach your compression gauge to cylinder 1, turn the ignition key on and hold in the start position long enough for the engine to turn over 6-8 times (or until the pressure gauge stops advancing). Record the results and test the remaining cylinders.
Re-install the parts on your car - torque specs and compression specs/acceptable margin of error (for a stock S54) are indicated on the pages from the Bentley manual. Good luck and hope this test confirms a healthy S54 for you.
Jump to top RaceMX-M3 is offline   Reply With Quote
Old Wed, Dec-30-2009, 02:16:33 AM   #2
imapimp
imapimp's Avatar
Reputation: 0 imapimp is on a distinguished road
Thanks for the DIY Scott. What were your compression #s? And what Compression ratio is your motor at?
Jump to top imapimp is offline   Reply With Quote
Old Wed, Dec-30-2009, 02:39:51 AM   #3
darkcrash21
///Mike
darkcrash21's Avatar
Reputation: 0 darkcrash21 is on a distinguished road
South Korea
that was quick! this should go to DIY section as well! Nice job!
2002 ///M3 Carbon Black / CF interior
VF-Engineering Stage 2 ● Tial Q BOV ● Okada Projects ● AEM Water/Meth ● Stoptech BBK ST60/ST40 ● HPF Stage 1 Feramic Clutch ● HPF/Walbro Fuel Pump ● Mason Engineering F/R Strut Bar and Clutch Pedal ● Ground Control SuperStreet Double Adj Coilovers w/ Hyperco 600F/700R ● Treehouse FCAB ● UUC Rear Lower Control Arms ● Eibach F/R Adj Sway Bars ● Agency Power Headers ● CPI section 1 w/ 400cell cats ● RE X-pipe with EVC ● RE El Diablo Ti ● Platte Forme AG Rear Subframe Reinforcement ● lots and lots of other crap...
Jump to top darkcrash21 is offline   Reply With Quote
Old Wed, Dec-30-2009, 03:14:26 AM   #4
Red Baron
ZOOM-ZOOM
Red Baron's Avatar
Reputation: 0 Red Baron is on a distinguished road
Puerto Rico
Cool
I would suggest taking everything off first, so as to work on a cold engine.
And then, when you are ready to perform the test, bring the engine up to normal operating temps, do the ECU connectors and perform the test.
If I missed the reason for working around a hot engine, then disregard my post.
2005 M3 Comp Pkg., Silver Gray/Porno red interior
Jump to top Red Baron is offline   Reply With Quote
Old Wed, Dec-30-2009, 03:49:19 AM   #5
RaceMX-M3
RaceMX-M3's Avatar
You're welcome. I actually do not know what the CR of my motor is - HPF does not disclose that info (at least not to me) and has requested not to post results of compression tests, hope you understand.
Good advice Robert. Wear gloves when you pull the coils/plugs, that shiz gets hot.
Old Wed, Dec-30-2009, 06:22:03 AM   #6
leletyM3
640rwhp
leletyM3's Avatar
Reputation: 0 leletyM3 is on a distinguished road
Italy
Great DIY!!!
05 BMW ///M3 SMG -->now 6MT - Jet Black/Gray
08 BMW ///M5 6MT - Sapphire Black/Gray
HPF Stg2 Turbo Kit 640rwhp, HPF Stg2 Feramic Clutch, HPF Carbon Fiber Stg3-4 Intake,HPF Catch Can, HPF Carbon Fiber Air Duct, HPF Methanol Switch, HPF Under Brace, HPF Subframe Kit, Custom AEM UEGO and AEM Boost Gauge in the OEM Mirror, Okada Plasma Coils, Eisenmann Race 83x4, Bilstein PSS9, Volk TE37 Time Attack, Toyo 275/30/19 & 245/35/19, Brembo BBK 380mm 6 pots & 345mm, Hardwired V1, 6K HID bulbs, 6K HID Fog Lights, 6K Umnitza Orion V2, Depo Smoked Corners, Solaris Bulbs, Full LEDs interiors,Umnitza LED licence plate lights, 30% Tint All Around, V-CSL V2Front Bumper with Race Lip, OEM CSL Bootlid, V-CSL Diffuser, ///M3 Monochrome, Flat Black Kidneys & Side Grills, Carbon Fiber BMW Emblems, Powerflex RTABs, Dension Ipod ICE>Link Plus, AudioControl unit, Phoenix Gold 600Ti, JL Audio 12W6v2
Jump to top leletyM3 is offline   Reply With Quote
Old Wed, Dec-30-2009, 08:39:59 PM   #7
MSpired
Reputation: 0 MSpired is on a distinguished road
Very nice and detailed write Scott, I'm sure many members will appreciate this.
I did another one yesterday on a warm motor and got 145-147psi. We have the same pistons, so you should be right there too.
I agree. A) It lets you take work on removing things while the motor is cold and B) Less time taking that stuff off and letting the motor cool so you get a more accurate result.
Jump to top MSpired is offline   Reply With Quote
Old Wed, Dec-30-2009, 11:37:47 PM   #8
RaceMX-M3
RaceMX-M3's Avatar
Thanks Mike, glad your motor compression checked out.
Old Thu, Dec-31-2009, 07:39:15 AM   #9
Beowoulf
Grumpy
Beowoulf's Avatar
Reputation: 0 Beowoulf has disabled reputation
United Nations
Nicely done. I will move this thread to the DIY section in a while so it doesn't get lost.
Alex
Jump to top Beowoulf is offline   Reply With Quote
Old Thu, Dec-31-2009, 08:09:04 AM   #10
nawM3
Reputation: 0 nawM3 is on a distinguished road
Kuwait
thats bro for this
2002 6spd Fire Orange E46 ///M3
HPF stg 2,HPF Feramic Stage 2 Clutch kit,HPF traction control
Vorsteiner V-CSL Front Bumper
Vorsteiner V-CSL GTR Vented CF Race Hood
Vorsteiner V-CSL CF Bootlid
Vorsteiner GTS3 Rear Diffuser
Apex wheels hyper black 18x10
Stoptech 4pistons front bbk
K-sport coilovers
Blacked Out Grills/Gills/Depo
Jump to top nawM3 is offline   Reply With Quote
compression, cylinder, diy, s54, test
Discussing DIY: S54 Cylinder Compression Test in the Faults, Fixes and DIY Forum - Please share your experience and knowledge with other members by contributing your own DIY, or by helping another member find the elusive fix! at BMW M3 Forum.com (E30 M3 | E36 M3 | E46 M3 | E92 M3 | F80/X)
