#1 | |||||||
![]() Location: SE PA
First some history on 10W-60 TWS. This is a quote (with his permission) from a PM discussion last week with Doug Hillary on BITOG. He worked for Castrol at the time and he's written at least one book on automotive lubricants:
![]() From Castrol's web site: Quote:
More technical info from BITOG: Quote:
Some thoughts by one of the M engineers: Quote:
Recently posted by YemThwee on why BMW's recommendations have changed, for those of you who claim this was not designed for the engine as it wasn't originally speced: Quote:
A PDF from Castrol, stating that the TWS formula is specific to M engines: http://www.lindvigs.com/obioban/EDGE_10W-60.pdf BMW SIB which was the official oil change over document and the official BMW reasoning: http://www.lindvigs.com/obioban/BMWEngineOils.pdf Some points I'd like to add. -As seen above, engine may have indeed been originally designed for castrol 10W-60, and marketing took it away... briefly -oil technology has indeed changed in the last 10 years. Fun fact: the TWS spec has not remained constant-- they have been updating it -the castrol engineers work on the TWS spec WITH BMW M engineers. M engineers have input on what goes into. Now, admittedly they're focusing most of that development effort on the newer M cars, but I'm sure they're not doing it at our expense -IMHO, redline products ARE HORRIBLE. Their fluids feel great at first, and then quickly degenerate. Even if I did venture from TWS, Redline would be my absolute last choice in aftermarket oils. (if you're wondering, I'd probably go with Motul). At the end of the day, I'm sticking with the TWS because there's no compelling reason to use anything else. It's plenty cheap, it provides good protection, and it works in every environment I drive the car. If I lived somewhere where it got absurdly cold I'd probably switch for the winter months, but other than that I just don't see any possible benefit to switching. What are you hoping to GAIN in exchange for the gamble you're making? (and yes, it certainly is a gamble, as it's absolutely more risk than the tested, proven, factory recommended TWS) How many cars get to have an oil specifically designed for them? Very few! In TWS, we are getting a very high quality oil that should cost MUCH more than it does, for a very reasonable price. ANYTHING you switch to is going to be for a more generic application, regardless of it's quality. Edit: Just found this on another site. I think people considering switching should have a good read over this and realize that was have an oil specifically tailored to our engine. That's not very common, and something I certainly want take advantage of: Quote:
Current Cars: 2005 IR/IR M3, 2003 TiAg M5, 1995 S50 B32 GT3 RS Green M3 Race Car _____Former Cars: 2004 TiAg/IR M3, 1996 TV/black M3, 1995 AW M3 shell Useful stuff: Objective suspension comparison, DIY suspension install VIDEOS (e36 version), Stick Driving Basics, e46 Climate Control, Better Fuel Economy 101, 10W-60 TWS Everything on the car: Mod List __________ HighRes M Wallpapers (Misc collected pics) <--- save target to desktop Selling: Suspensions, brakes, safety equipment, etc (ask away!) Renting: Valve shim adjustment kit, RTAB tool, Ball joint tool Last edited by Obioban; Tue, Dec-22-2009 at 04:44:50 PM. |
#2 | |
Shut Up and Drive
Which is a complicated way of saying...as Castrol improves the 10W60 for the newer M engines, those of us with S54's will only benefit- there will be no downside.
Just a clue to readers of this thread. If you have nothing useful to add - technical info, oil studies, worthwhile information, then don't add anything.
Inane comments will be deleted. And you may end up with an infraction.
#4 |
Thanks for posting this information in one thread.
#5 |
It would be interesting to understand the difference, if any, in TWS 10w60 and the other Castrol 10w60 offering - not sure it is available in the US anyway.
Personally I'll never believe an engine is designed around and oil spec (nobody said it was, just stating this), or that there is a difference significant enough to worry about between synthetics of the same weight and service spec. But, a LOT of smart, long-toothed mechanics agree that changing oils around with a variety of additive packages (normally very similar in a given manufacturers product line) doesn't serve you well, especially if you're getting good service out of a product you've been using. This, along with the point made in may other threads, that the cost-savings is a rounding error with any other quality synthetic of proper weight, make it hard for me to understand taking the much risk. I might do so if I can find the non TWS Castrol 10w60, get a better bulk price, and some intel on the additives being close or the same. I've got at least 2 blackstone samples left in my package deal, I'd send them both off to compare if I could get the alternative Castrol 10w60; curious mostly. At 100 hp/liter, the S54 is a fairly high-strung engine compared to a 3-400 hp 5 liter v8, for example, and it clearly had some problems early on with the original 5w30 spec. Despite the writings above about the S62, I still wonder if the change to 10w60 wasn't part of the several things they did with the S54 boom problem before they really knew what was wrong. Some engines had more than one bearing recall done, for example. Jason's archive on roadfly is probably the best source to find all that stuff for anyone interested. The S62 discussion talks about marketing pressure. Brand identity is an even bigger deal these days; there is no way they're going to reverse the statement that you have to use the special sauce and look inconsistent, not to mention it keeps folks coming back to BMW - now THAT, is marketing. Enthusiasts will maybe order online, but most folks go back to the dealer where they see the new cars - what a concept! A few years ago, some of the synthetics were noticeably cheaper than the TWS, today, not so much. So, the more I think about it, there seems to be little upside to trying much in the way of alternatives. Anybody have a current inside source at Castrol that can speak to the TWS versus the other 10w60 offering? ADS
98 M3/4, Supersprint catback, UUC red tranny mounts, Rogue SS w/UUC dual selector rod, wired V1. Sold to my son, still in the family! 06 SMG/ZCP - April 09, Dinan over Konis, RAC RG63, homelink with off-delay (working), multifunction steering wheel buttons, RacingBrake Front kit. |
#6 |
เป็นคนจีน
![]() Location: Seattle
Just more reasons I'm sticking with my 10W60....Thanks Obi, great write-up
2008 ISF, Smokey Granite Mica on Black ![]()
#7 |
![]() Location: Santa Barbara
anything in regards to oil life? I know the BWM spec is 15k but a lot on this board subscribe to a more regular 7.5k interval. I am doing 5k as I just find it easier to keep track of. I have also heard it floated that this oil actually performs better as it "ages" in the motor and that early 3k or less changes may actually be negatively impacting.
I am sure there is a legitimate reason BMW specs 15k, but if so why do so many enthusiasts choose to ignore it. Bottom line, I would hate to learn about some benefits of "aged" oil we early oil changers are not benefiting from.
05 ZCP AW Cinnamon |
#8 |
![]() Location: Saskatoon
I have only been part of this forum for maybe a year....maybe a little more. I am still dumbfounded by the constant questions posed in regards to this topic. Great write up. I live in an area of Canada where temps will dip down to mid -40 degrees celsius and go as high as +40 degrees celsius. I have never driven my M3 in the winter, but am trying it this year. I just had our BMW stealership put an oil pan warmer on my car for those stupendously cold stretches so my car does indeed fire up. I am sticking with the Castrol oil for this car and will see how it does this winter.
If people who are looking the way of buying an M3 are concerned about an oil that costs a little more than a generic 5w30 oil. Perhaps they should be driving something more generic as well. This is a very special car with a specific need for a specific oil. I hope this is the last post in regards to this topic.....but as i am NOT that nieve... i know it`ll pop back up within a few months. Again thanks for what i think should be the LAST OFFICIAL thread on Castrol Oil in the E46 M3! Extremely well written.
2007 Lexus RX350 (Light Blue Metallic) 2005 BMW E46 M3 Carbon Schwartz Metallic 1998 Camaro Z28 (LS1 ~500HP, red with T-Tops, over the winter, installing turbo kit to put the car at approx 550rwhp, already purchased...next up the M3!) |
#9 | |
The only way to make sure is to get a Blackstone report of your sample of TWS at certain intervals of 7.5k and 15k to see what properties it has left. That way, you can judge for yourself whether BMW's recommended 15k intervals is good to stick by. As for changing oil early at 3k, well your not doing any harm to the S54 but it'll just be a waste of TWS that's still in good condition. |
#10 | |
| 10w60, castrol, definitive, thread, tws |
