Old Mon, Jul-16-2012, 08:05:43 PM   #181
SYT_Shadow
Piraña Powered
SYT_Shadow's Avatar
Spain
Default Re: DIY: Subframe reinforcement epoxy/foam method. e46
Originally Posted by Nervous View Post
Actually, this where I don't understand the logic. Can anybody explain why BMW TIS does not say anything about filling the right side? What is the rationale? I don't believe they think that only left side is prone to cracks/tears. Could it be because by filling through the hole on the left side you basically filling both sides (due to configuration of passages)?
Well, if it were already filled just through the left then the people who have also filled the right side wouldn't be able to.
They probably only require one side filled as that halves the amount of epoxy used and we know the front left side is the one that typically fails.
If you want to make it bulletproof it's probably a good idea to do it to both sides + TMS kit epoxied on
Vanos hub / bolts DIY
Oil Pan Removal DIY
Foam subframe reinforcement DIY
Plastics Renewal DIY
Spacer DIY
ESS NA Tune Review
Tools:
-Shim kit -Timing tool -Engine support -Grainger foam applicator gun
DIY stuff
-Available in the NY/MA/NH area
Jump to top SYT_Shadow is online now   Reply With Quote
Old Mon, Jul-16-2012, 08:06:13 PM   #182
Nervous
Reputation: 0 Nervous is on a distinguished road
Originally Posted by SYT_Shadow View Post
be careful as this one is done using the old BMW kit that was only 200 mL and that's why they're using the smaller applicator gun.
Weird, because the p/n on the cartridge (83190007361) is the 400ml one.... And:
Originally Posted by VALSBM3 View Post
The cartridges I received were 400ML each. The dispensing gun I have is for 400ML cartridges.
However, the gun model 3EPT4 is really 200ml one; 3EPT5 is 400ml. Probably, a typo, but seems to me this is the legit DIY.
Jump to top Nervous is offline   Reply With Quote
Old Tue, Jul-17-2012, 12:32:16 AM   #183
SYT_Shadow
Piraña Powered
SYT_Shadow's Avatar
Spain
so we're safe buying the 400mL one
Oil Pan Removal DIY
Spacer DIY
ESS NA Tune Review
Tools:
DIY stuff
Old Sat, Jul-21-2012, 12:53:06 AM   #184
GlobemasterMIII
GlobemasterMIII's Avatar
Reputation: 0 GlobemasterMIII is on a distinguished road
Okay...so slightly off the current topic, but still relevant to the thread:
Where exactly do these subframe reinforcements go? I guess, more specifically, where are the pictures in Post #1 taken from? Is that under the car? Under the back seat? I jacked up my car & crawled under & couldn't find anything that looked remotely like the pictures of the "subframe sanded down". Do I have to remove a bunch of stuff to have that clear of access to it?
...and bottom line: Where does a guy look to inspect for these infamous cracks?
2005 M3 SMG - aFe Stage II CAI, El Diablo muffler, 1/2 CF CSL Diffuser, CF CSL-style trunk, Angel eyes, Plasti-dipped gills, grilles, & ///M logo
Next - RTABs, FCABs, subframe reinforcement, Insp 2 stuff. Then back to the fun stuff.
Jump to top GlobemasterMIII is offline   Reply With Quote
Old Wed, Jul-25-2012, 12:04:30 AM   #185
SYT_Shadow
Piraña Powered
SYT_Shadow's Avatar
Spain
that's because you first have to remove the whole rear subframe.
You can only see the cracks without dismounting everything if they're huge.
Oil Pan Removal DIY
Spacer DIY
ESS NA Tune Review
Tools:
DIY stuff
Old Wed, Jul-25-2012, 05:00:55 AM   #186
OldFanatic
17 yr BMWCCA Member
OldFanatic's Avatar
Reputation: 0 OldFanatic is on a distinguished road
you don't have to remove it per se. you can however drop it a little to examine the area hidden by the bushings.
there are more often cracks around the sheet metal of the mounting block then there are directly underneath. so you can often see cracks or fractures that have started without having to drop the subframe.
but yes, to be thorough it's best to examine underneath the bushing.
2003 TiAg - OEM CSL WHEELS - OEM CSL BRAKES - AA SPORT TUNE - AA PULLEYS - AS 40% SSK- VCSL TRUNK - VCSL DIFFUSER - SUPERSPRINT EXHAUST
- BMW PERFORMANCE CF STRUT BRACE - BILSTEIN PSS9s - GROUP N MOTORMOUNTS - BW INTAKE ELBOW - CF RACE LIP - SUNROOF DELETE - 4.10 DIFF - CSL RACK
Jump to top OldFanatic is offline   Reply With Quote
Old Fri, Jul-27-2012, 02:03:48 PM   #187
nuc1
M-aholic
nuc1's Avatar
Reputation: 0 nuc1 is on a distinguished road
I did the epoxy/foam repair method about 10 months ago. Used the TMS reinforcements, ScotchWeld DP-420 epoxy and BMW OEM structural foam (driver's side only so far).
Prep time is extensive due to dropping the rear subframe (and I replaced all bushings while it was out), welding the one tiny crack I found and cleaning/prepping the surfaces. Installing the reinforcements with the epoxy was easy. I sprayed the reinforcements and entire area with primer and then painted for rust protection. Adding the structural foam was even easier (make sure the tube is hot and it literally took 2 minutes).
I have 5 track days on the car since and I just partially dropped the subframe for a visual inspection. No issues found. Note my car is supercharged so there are added stresses.
This may give folks some peace of mind with this reinforcement method.
Mike
02 TiAg/Black: Boosted street and occasional daily driver
95 Cosmos/Cosmos: S54-swapped track fun
Jump to top nuc1 is offline   Reply With Quote
Old Fri, Jul-27-2012, 02:09:51 PM   #188
SYT_Shadow
Piraña Powered
SYT_Shadow's Avatar
Spain
Mike
Thanks for the info.
Did you put a single 420mL tube into the drivers side?
Did you need any special tool for the bushing replacement?
Thanks
Oil Pan Removal DIY
Spacer DIY
ESS NA Tune Review
Tools:
DIY stuff
Old Fri, Jul-27-2012, 03:20:45 PM   #189
Nervous
Wow, great info, nyc1!
Old Sat, Jul-28-2012, 07:43:21 PM   #190
nuc1
M-aholic
nuc1's Avatar
Thanks
I used two of the twin-tube cartridges using a tool I purchased from Grainger.
All bushings except the actual subframe bushings I replaced in my garage. Had to take the subframe and new bushings to a machine shop to have them replaced. Broke my cheap Harbor Freight press trying to replace them....
Mike
diy, e46, epoxy or foam, method, reinforcement, subframe
Discussing DIY: Subframe reinforcement epoxy/foam method. e46 in the Faults, Fixes and DIY Forum - Please share your experience and knowledge with other members by contributing your own DIY, or by helping another member find the elusive fix! at BMW M3 Forum.com (E30 M3 | E36 M3 | E46 M3 | E92 M3 | F80/X)
