![]() Location: Bellaire
Ok. Did numerous searches. Tried all these suggestions: http://www.m3forum.net/m3forum/showt...ar+view+mirror
Most are saying, remove the plastic cover. Done. The thread then states "twist the mirror counter clockwise, then disconnect the electrical" When I twist the mirror (rectangular with rain sensor) it hits the roof and no further twisting can happen. Tried pulling slightly hard at this proint and I'm afraid I'm going to rip the mirror mount off the glass. What in the idiot heck am I doing wrong? |
Greenhill Zone Act 1
![]() Location: Seattle
I can't even get the plastic cover off my oval mirror
![]() Location: Atlanta
The plastic housing snaps together. It is a little tricky to remove for the first time, but all you have to do is try to separate the two halves. Start at the bottom of the mirror and push in (towards top of the car) on the center where the two halves meet, while at the same time pulling the two halves apart (toward the left and right side of the car).
With the pastic off, now you just have to twist the mounting arm (not the mirror itself) counter-clockwise (although either direction should work, twist about 75 to 90 degrees) and the mirror will come off. Keep in mind, this was my procedure for the oval mirror--not sure if the mounts are different for the square mirrors. |
#4 |
![]() Location: Coral Springs, FL USA
There is a service bulletin around somewhere that says not to twist the mirror. After removing the cover, press on the mirror so it snaps off the mount. Insert and twist to reinstall only. I'll try to find the document.
Edit - here it is: http://www.bigpatsfans.com/mirror/pi..._%2016_060.pdf
2011 M3 Coupe, Jerez Black/Black, DCT 2002 330Ci, Sapphire Black/Black, 5-speed |
#5 |
Get yourself an 8 year old child and he/she should be able to get it right off. It's like a child-proof cap on a pill bottle.
![]() Don't know what to tell you otherwise. Mine came right off with just a twist.
2004 Mystic Blue, 6MT |
#6 |
I finally figured it out. One has to twist the MOUNT not the mirror. I figured the mount post was glued in place. It came right off (mirror + mount) after I finnally understood!
#7 |
yeah everything clicked for me too, good info guys
| mirror, rear, stubborn, view |
