Go Back   BMW M3 Forum.com (E30 M3 | E36 M3 | E46 M3 | E92 M3) > BMW M3 Discussions > E90 M3 (Sedan) | E92 M3 (Coupe) | E93 M3 (Convert) (2008-200?)
E90 M3 (Sedan) | E92 M3 (Coupe) | E93 M3 (Convert) (2008-200?) {Engine: S65 - Max Hp: 414 hp (420 hp Euro) at 8,300 rpm / 295 lb/ft at 3,900 rpm}
Old Sun, Aug-16-2009, 03:29:12 PM   #1
RaceMX-M3
Adrenaline Junkie
RaceMX-M3's Avatar
Reputation: 0 RaceMX-M3 is a jewel in the rough
Default V1 Stealth Integration - E90 M3
I installed a V1 in a friend's new M3 this weekend and thought I'd share some pics of the build. The E90 rear center headrest is one of the best places I've seen for hiding the Valentine.
HPF Stage 2.5 #0001 - World's Fastest BMW from 60-130 @ 5.75 seconds
Jump to top RaceMX-M3 is offline   Reply With Quote
Old Sun, Aug-16-2009, 03:46:08 PM   #2
DevJ
DevJ's Avatar
Reputation: 0 DevJ is on a distinguished road
Scott, this is sick! Could you give me a price on something like this if you installed it..?
Jump to top DevJ is offline   Reply With Quote
Old Sun, Aug-16-2009, 04:02:20 PM   #3
RaceMX-M3
Adrenaline Junkie
RaceMX-M3's Avatar
I will send you a PM - do you own the coupe or sedan? The coupe doesn't have a rear center headrest, although it may work fine in the side headrest. Just can't have anything metal obstructing the radar sensors.
Old Sun, Aug-16-2009, 09:22:08 PM   #4
MuchMoore
Reputation: 0 MuchMoore is on a distinguished road
Wow, that is a really slick install. How did you remove the rear-center headrest?
| Andrew | M Technik | BMW Performance | 3M | V1 | LUX 5.0 | Bilstein PSS9 | Precision-Sport |
Jump to top MuchMoore is offline   Reply With Quote
Old Sun, Aug-16-2009, 10:59:09 PM   #5
DLSJ5
DLSJ5's Avatar
Reputation: 0 DLSJ5 is on a distinguished road
Looks great Scott!
Current - E92 08 M3 - DCT
Mods - Encore Innovation x-pipe w/HFC's - GIAC ECU Flash - Borla Exhaust - Rogue Engineering Pulley - VFE Filter
60-130MPH (3 shifts) 10.71 Best ET 11.88 @118.7 MPH Best Trap 119.8MPH
Previous - E46 05 ZCP M3 SMG
Best Boosted ET, VF-Engineering OTS Stage 2 11.58@ 122 MPH
Stage 2+ Best Trap124.8MPH
60-130MPH (2 shifts) @8.5 psi, OTS VFE Stage 2 8.67 seconds
Jump to top DLSJ5 is offline   Reply With Quote
Old Mon, Aug-17-2009, 01:31:22 AM   #6
RaceMX-M3
Adrenaline Junkie
RaceMX-M3's Avatar
Just pull up and it will come right out.
Originally Posted by DLSJ5 View Post
Looks great Scott!
Thanks Drew.
Old Mon, Aug-17-2009, 01:39:34 AM   #7
CarFanatic56
CarFanatic56's Avatar
Reputation: 0 CarFanatic56 is on a distinguished road
cool install
Imola Rot/Schwarzes SMG
Jump to top CarFanatic56 is offline   Reply With Quote
Old Mon, Aug-17-2009, 02:01:37 AM   #8
m3sparky
m3sparky's Avatar
Reputation: 0 m3sparky is on a distinguished road
indeed looks super sick. how much does that system cost?
03 bmw m3 sold---
07 toyota tacoma
06 bmw 325i
08 bmw m3 sd manual
Jump to top m3sparky is offline   Reply With Quote
Old Mon, Aug-17-2009, 02:18:28 AM   #9
rwfisher
Reputation: 0 rwfisher is on a distinguished road
how much space did you save by removing the V1 from its case? I'm wondering if it will fit into an E46 vert rear headrest....
Jump to top rwfisher is offline   Reply With Quote
Old Mon, Aug-17-2009, 02:47:47 AM   #10
RaceMX-M3
Adrenaline Junkie
RaceMX-M3's Avatar
Quite a bit, it would not have fit with the case on. Just stick your V1 next to the headrest and you should be able to tell if there's room. It's easy to take the cover off, just 4 torx screws.
e90, integration, stealth
Powered by vBulletin® Version 3.8.4
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
M3 Forum .com is in no way sponsored, endorsed or affiliated by or with BMW NA / BMW AG or any of it's subsidiaries or vendors.
Copyright ©1999-2010 M3Forum.com
