Old Fri, Aug-07-2009, 08:23:52 AM   #1
Rslomski08
Reputation: 0 Rslomski08 is on a distinguished road
Default E36 M3 "pppppp" odometer reading
I'm looking into a car that has had this problem. The odometer apparently had a reading error and said "pppppppp" where the milage should have been. Does anyone know about this? Should I stay away from getting this car?
Jump to top Rslomski08 is offline   Reply With Quote
Old Fri, Aug-07-2009, 09:41:10 AM   #2
KWorker17
Brett Favre of M3's
KWorker17's Avatar
Reputation: 0 KWorker17 is on a distinguished road
Yes
/thread
Kevin
Jump to top KWorker17 is offline   Reply With Quote
Old Fri, Aug-07-2009, 02:59:09 PM   #3
M3Blurr
Turd bro S54 retard!
M3Blurr's Avatar
Reputation: 0 M3Blurr is on a distinguished road
ppppp-problems!
Jump to top M3Blurr is offline   Reply With Quote
Old Fri, Aug-07-2009, 09:26:22 PM   #4
mtechnica
Reputation: 0 mtechnica is on a distinguished road
It means the previous owner won.
Jump to top mtechnica is offline   Reply With Quote
Old Sat, Aug-08-2009, 03:58:40 AM   #5
bigneil
bigneil's Avatar
Reputation: 0 bigneil is on a distinguished road
Run the VIN to get the real story.
Jump to top bigneil is offline   Reply With Quote
Old Sat, Aug-08-2009, 09:40:14 PM   #6
Oldman MZ3
Oldman MZ3's Avatar
Reputation: 0 Oldman MZ3 is on a distinguished road
Car has a new instrument cluster, needs to be coded.
Jump to top Oldman MZ3 is offline   Reply With Quote
Old Sun, Aug-09-2009, 02:21:57 AM   #7
Anubis
Dr. Awesomesauce
Anubis's Avatar
That indicates a failing/failed cluster more than a cluster that needs to be coded - an uncoded cluster will display "CODE", not PPPPPP. Check all the connections on the back of the cluster, check the fuses, and if all fails, the cluster will need replacement.
Stay away from the car. You don't want to be dealing with odometer issues like this.
1999 Estoril Blue/Dove Grey M3
Old Sun, Aug-09-2009, 02:22:56 AM   #8
Porschetech
Cocky Brit
Porschetech's Avatar
Reputation: 125 Porschetech is a name known to allPorschetech is a name known to all
England
like jeffy said......dead cluster
I love all gingers 'n Plambers
Jump to top Porschetech is offline   Reply With Quote
Old Sun, Aug-09-2009, 02:32:00 AM   #9
Anubis
Dr. Awesomesauce
Anubis's Avatar
Oh, also, if the car is a '96+ then BMW can just swap the coding plug from the dead cluster into the new cluster and the mileage data and the vehicle VIN and SI (service interval) data will be transferred over.
If it's a '95, you're out of luck and you will have a mileage reading stamped into the sheet metal in the driver's door jamb and CARFAX reports with inconsistent odometer readings.
Either way, it's a pain in the ass - stay away. There are plenty of cars out there.
Old Sun, Aug-09-2009, 07:46:18 AM   #10
Rslomski08
Do you know of any E36 M3s that are 7,000 and under?
e36, odometer, pppppp, reading
Discussing E36 M3 "pppppp" odometer reading in the E36 M3 (1992-1999) Forum - {Euro - S50 B32 321hp @ 7400 rpm} {U.S. - S52 B32 240 hp @ 6000 rpm}
