Old Mon, May-25-2009, 10:40:24 PM   #1
JordanButters
Reputation: 0 JordanButters is on a distinguished road
Default Engine Temp Running at Little Over Half
So just recently the car has started operating at just a needle width over half on the temp gauge. So I changed to coolant to straight water and 2 things of water wetter, bled the system over and over and its still doing it. I believe the fan clutch to be a little bit bad because if i put some thick cardboard it will stop after about 3 revolutions. Will that cause it to still run that temp during driving though? Isn't the fan disengaged after 20ish mph? The only thing I can think of is that it is running in safe mode right now because I pulled the baffles out of the airbox and it threw a cel and now gets 20mpg. Would being in safe mode cause it to run a bit hot? Thanks guys, any thoughts or confirmations will be appreciated.
Jump to top JordanButters is offline   Reply With Quote
Old Mon, May-25-2009, 10:54:41 PM   #2
OahuMPower
:FACEPALM:
OahuMPower's Avatar
safe mode
if the needle has moved from middle, then it's already gotten too hot.. the BMW water temp gauge is an "idiot" gauge.. it stays in the middle within a certain range....
I would check to make sure the water pump is still good and that the radiator isnt clogged.. also possible the thermostat is bad...
how many miles on the car, when was the last cooling system maintenance done?
what year, build date would also help
Old Mon, May-25-2009, 10:55:10 PM   #3
falciott
falciott's Avatar
Reputation: 0 falciott is on a distinguished road
When you say straight water, do you mean faucet water? That's besides the point, why run the cooling system with only water and water wetter? Only because of the water wetter claims? I think that's the problem.
1997 Glaciersilber M3.
Clear lights, Corsa RSC36, DJ Auto with TFX retrofit, Blind spot monitoring system, Illuminated ZHP knob,Brushed aluminum look console and bits,Flat bottom MTechnic steering wheel, Becker Grand Prix with bluetooth, Motion sensor HD dash cam, BMW Homelink, Keyless entry, RE short shifter,CSL reps, Mason strutbar,Reverse sensors, Automatic rain sensing wipers, everything else? Stock!
Jump to top falciott is offline   Reply With Quote
Old Mon, May-25-2009, 11:12:30 PM   #4
OahuMPower
:FACEPALM:
OahuMPower's Avatar
straight water is a better conduit to transfer heat... and water wetter DOES help...
most race cars that only see "warm" weather run ONLY h20 and water wetter. because it keeps the motor cooler
the issue is, people live in cold climates and coolant is required to keep the water from freezing, thus the "usual" 50/50 mix h20 and coolant
Old Mon, May-25-2009, 11:18:36 PM   #5
falciott
falciott's Avatar
Hey, what's up Cal?!! Straight water= cheap!! ......nahh I keed I keed, but I shall look into that then
Old Mon, May-25-2009, 11:21:15 PM   #6
JordanButters
Yeah I had to go look it up. The cooling system was done by the dealership just about a year ago, new t-stat, system flush, new coolant, and water pump. This was with the previous owner. Would that stuff fail within a year?
It is distilled water. Trust me I read all about it.
It is a 1997, built in May. No mods other than the airbox baffle removal and yes just because it sounds nicer.
Another thing I just noticed, it never says full cold anymore, i.e. how when you start the car it will be a little below full cold now it is just at the end. Is it possible the needle has shifted some how? Thanks.
Old Mon, May-25-2009, 11:22:42 PM   #7
OahuMPower
:FACEPALM:
OahuMPower's Avatar
whats up man... hawaii you COULD run straight h20... but I would still recommend a mix of coolant...
when I was in HI.. I ran like a 70/30 mix of distilled water to coolant and 2 bottles of water wetter...
actually what I'm STILL running right now
possible... has anyone taken apart the gauge cluster for gauge faces or anything of the sort?
Old Mon, May-25-2009, 11:25:16 PM   #8
JordanButters
No it looks completely untouched and it only started doing this a few days ago.
Old Mon, May-25-2009, 11:27:31 PM   #9
ArBrnSnpr
Likes M118LR
Reputation: 0 ArBrnSnpr is on a distinguished road
Sounds like the calibration on the temp gauge is off - not sure what would have caused that if you havent messed with the cluster but it certainly sounds that way if it wont sit at full cold as well as rides a bit above half normally...
Jump to top ArBrnSnpr is offline   Reply With Quote
Old Mon, May-25-2009, 11:30:25 PM   #10
baltimoreM3
baltimoreM3's Avatar
Reputation: 0 baltimoreM3 is on a distinguished road
What CEL code is being thrown? I'd find this out first and don't drive the car anymore until you figure out the overheating issue.
Also possible the "new" t-stat is bad or wasn't actually replaced but someone was charged for it.
Generally speaking this situation is commonly related to a bad thermostat. Have you tried lightly tapping on the t-stat housing while it was running.
Mine:
1999 M3 Coupe
Fern Green,Dinan Stage 3 Suspension,X-brace,AA-Tower Brace,AA CAI,AA Gen 3,AA Performance Software,S.S. Brakelines,UUC Red/TME,VDOs...
Hers:
2006 X5 3.0
Black Sapphire, Xenons, Leather
Jump to top baltimoreM3 is offline   Reply With Quote
engine, half, running, temp
Discussing Engine Temp Running at Little Over Half in the E36 M3 (1992-1999) Forum - {Euro - S50 B32 321hp @ 7400 rpm} {U.S. - S52 B32 240 hp @ 6000 rpm}
