Member Journals Do you have a long term project you would like to share with the community? Use this forum to create a single thread which you can update over time to document the progress. |
ARM Powered
![]() Location: Bay Area
chasis has approx 175K on the clock. the car already came with
'95 euro e36 m3 motor (approx 70k miles) zf 5 speed tranny brake cooling ducts feeding into the center of the rotors Bilstein shocks Vorshlag camber plates Sparco front strut bar Ireland swaybar a/c heater core delete custom cat-less exhaust with e36 m3 eisenmann muffler K&N intake SPAL electric fan Z3 shifter kit ![]() ![]() ![]() my initial plan was to strip out the whole interior, remove the sunroof, and install a custom welded roll cage. someone had expressed interest in my car, so i decided to keep it somewhat street friendly for now.
2016 Porsche Cayman GT4 2015 Porsche Cayman GTS (Gone) 1968 Porsche 912 2011 Porsche GT3 RS (Gone ![]() 2006 Interlago blue OEM CSL Dinan S3-R M3 (Gone) 1988 E30 Henna M3 S50B32 (Gone) 2006 Ducati Burnt Yellow SportClassic Sport1000 Last edited by edwin814; Mon, Mar-18-2013 at 08:05:55 PM. |
Sponsored Links |
ARM Powered
to make it an official HPDE car, the first mod came from the DMV
2016 Porsche Cayman GT4 2015 Porsche Cayman GTS (Gone) 1968 Porsche 912 2011 Porsche GT3 RS (Gone ![]() 2006 Interlago blue OEM CSL Dinan S3-R M3 (Gone) 1988 E30 Henna M3 S50B32 (Gone) 2006 Ducati Burnt Yellow SportClassic Sport1000 |
ARM Powered
received an aftermarket evo3 spoiler with flap from germany the same day i took delivery of the car. very high quality, but no oem of course. just couldn't cough out $1400 for oem piece (the oem flap is not even CF)
![]() ![]() ![]() got it back from the paint shop the night before the first track day. so had to install it half way through the track day ![]() ![]()
#4 |
ARM Powered
Nitto NT01, my first r comp...on 17" kosei e36 spec...so i have to run 18mm spacers. coming from tracking street tires, these r comps got awfully good grip
#5 |
![]() Location: Brooklyn
Love the car and the color. How does it feel with the Euro motor. Any In car footage?
S.O.H. |
#6 | |
ARM Powered
![]() Quote:
it's a beast! it has about the same power to weight ratio as my s/c e46. except the e30 has stock 2.93 diff, so it "felt" slow accelerating out of a corner. i had a 3.73 LSD diff, but it was way too aggressive. i'm in a search for a 3.25 LSD diff. no footage so far. i've only took it to track once. i discovered i had a PS hose leak and SS brake line leak on the track, so it wasn't that good of a run anyway. my new roll bar should be here soon then i can paint it and install it and fit it with IO camera mount ![]()
#7 |
Established 1998....
![]() Location: Al Manama, Bahrain
Dude that car looks awesome! I am looking for one as we speak but im gona keep it stock
#8 |
ARM Powered
with that much power on such light car, more powerful brakes are needed. problem is most bbk makers (brembo, stoptech, ap, etc) only make front kit for the e30. i wanted bolt-on kit for all 4 corners, and didnt' want to scavenge parts from other cars for the rear. so i got Lee's Massive Brake kit (www.massivebrakes.com). Lee has his shop build the custom caliper brackets and rotor hat, and uses wilwood rotor and caliper.
also fitted with vorshlag 90mm competition wheel studs front: 6pot SL6R caliper 300mm x 32mm slotted rotors rear: 4pot SL4R caliper 300mm x 32mm slotted rotors ![]() ![]() ![]() ![]()
2016 Porsche Cayman GT4 2015 Porsche Cayman GTS (Gone) 1968 Porsche 912 2011 Porsche GT3 RS (Gone ![]() 2006 Interlago blue OEM CSL Dinan S3-R M3 (Gone) 1988 E30 Henna M3 S50B32 (Gone) 2006 Ducati Burnt Yellow SportClassic Sport1000 Last edited by edwin814; Sun, May-17-2009 at 06:17:26 AM. |
#9 |
ARM Powered
cool. what color you getting?
#10 |
ARM Powered
just finished this latest mod yesterday...somewhat. i replaced recaro srd (came with the car) with recaro profi spg (bought from forum member ninekrpm, thanks again, buddy!). so i ended up buy the whole seat mounting kit from VAC motorsports.
i order the kit with floor mount, side mount and sliders, but the kit came without the sliders ![]() from this: ![]() ![]() to this: ![]() ![]() ![]() ![]() ![]() ![]() also installed NRG quick release hub, thin version. was gonna get the black one, but ordered the blue one by mistake ![]()
Bookmarks |
Tags |
car, e30, edwin, hpde, s50b32 |
Thread Tools | |
Display Modes | |
