Quick question about replacing the OEM air filter. When I was trying to get everything seated down and clamped in place, I noticed that it was requiring a little more elbow grease than it should have. When I opened it back up, in the back corner nearest the engine, the airbox lid was pressing on the middle of the urethane seal/gasket instead of being on the sides of it. And because of this, it started to cut the seal on the outside edge. And now a small part of it (maybe 1/4-1/2'' long) is semi-loose. Imagine someone making a single cut with a pair of scissors, its still attached but cut. I corrected this and got it aligned correctly. My question is, is there any risk of the "loose" piece getting sucked into the motor, or is it secured within the seal channel?
Post photo. Can't tell by description.
Picture...
As you can see, the seal is now cut due to how I had the airbox originally set on it. I imagine that the airbox lid is designed with a channel that runs around the outside of it. So the seal (pink) would not be subject to any kind of suction. But then again... thats why I am asking. |
#4 |
You are gonna be fine.
#5 |
Drop a Streamline next time. You will feel an improvement.
#6 |
Streamline is on the "To-Do" list. And thanks for the response. I am just overly ana.... particular/paranoid about things. So I wanted to drop a post and check to be safe
![]() If you ask me, air filters being replaced only on inspection 2 seems long. My old filter was extremely dirty and I only have 44,000 on the car. Last edited by stolidog; Sat, May-09-2009 at 12:09:17 AM. |
#7 |
![]() Location: vancouver
it should be fine man as long as there is no hole on the filter itself.
Vendor Reviews @ reviewavendor.com |
#8 |
Yeah I know the filter is ok. My concern was whether or not there was a chance the cut portion could be ripped off from the suction of the intake and thrown into the motor. I went back and looked again. It seems like the foam seal is pretty well locked into the airbox lid. So I dont think its going anywhere.
#9 |
![]() Location: San Diego
You'll be fine. But if you're worried why not stick some quality glue in the cut and let it dry before replacing into your car.
#10 |
Because I've searched everywhere and I cant find my glue
![]() Oh and super/krazy glue says dont use on foam. Last edited by stolidog; Sat, May-09-2009 at 02:04:58 AM. |
| air, filter, installation |
| Macht Schnell Drop In Air Filter Installation pics + Review | PKumarM3 | E46 M3 (2001-2006) | 18 | Fri, Mar-19-2010 11:24:24 PM |
| Air con aftermarket installation? | joni5007 | E36 M3 (1992-1999) | 2 | Wed, Oct-01-2008 08:57:02 PM |
| Air Duct installation | ///Macht[030] | E36 M3 (1992-1999) | 11 | Fri, Oct-27-2006 07:29:47 PM |
| Air Vent Modification In Z1 Installation | elansinger | Audio/In Car Entertainment (I.C.E.) | 13 | Wed, May-17-2006 12:56:39 AM |
| You call that an air filter? THIS is an air filter! | jskene | E46 M3 (2001-2006) | 18 | Sun, Nov-14-2004 02:35:32 AM |
