Old Sun, Apr-12-2009, 07:52:49 PM   #1
Mr. Vapor
Mr. Vapor's Avatar
Reputation: 0 Mr. Vapor is on a distinguished road
Default Just turned 60,0000 on my '06 ZCP
Edit: 60,000 not 60,0000
Just turned over 60k on my '06 ZCP. i am the second owner, first owner had this car from showrooom floor. Car saw an average of about 17k per year, 90% of that being highway miles (thus the high average
I have inspection II on the horizon, and other that im looking at:
RTABs
Spark plugs (not dealt with in Inspection II?)
Subframe issues? (pretty sure this was corrected in '03.5+?)
what else?....
2006 M3 - Competition Package - Carbon black [Nav] [M-DSC] [HK] [ZPP] [ZCP]
[Evolve-R] [Supersprint Race] [Evosport SS headers] [CPI Euro200R] [Powerflex RTABs] [RE RSMs] [FK Silverline Plus X coilovers] [AFE Intake Arm] [Black kidneys/grilles] [Smoked corner lights] [Powdercoated 19" CSL ] [235/265 CSL spec Potenza Pole Positions] [Smoked reflectors] [30% tint] [Iconz CF 1-piece race lip] [RPI Scoops]
Jump to top Mr. Vapor is offline   Reply With Quote
Old Sun, Apr-12-2009, 07:56:27 PM   #2
djm3
CSL (finished) inside
djm3's Avatar
Reputation: 0 djm3 is on a distinguished road
Oilchange, valve inspection/adjustment, sparkplugs.
Jump to top djm3 is offline   Reply With Quote
Old Sun, Apr-12-2009, 08:01:05 PM   #3
Mr. Vapor
Mr. Vapor's Avatar
isnt a valve adjust included in inspection II?
Old Sun, Apr-12-2009, 08:08:48 PM   #4
djm3
djm3's Avatar
I thought that was what you were asking...
Old Sun, Apr-12-2009, 09:46:19 PM   #5
Quicksilv3r
Quicksilv3r's Avatar
Reputation: 0 Quicksilv3r is on a distinguished road
Subframe issues were not corrected in '03.5. It affects ALL E46 M3's; however, no convertible has seen the issue turn up so far. If the car hasn't been tracked, and given it is still fairly new being an '06 model, I would be fairly certain that your M doesn't have any subframe issues at this point. Reinforced RSMs or the Turner subframe kit are good, relatively inexpensive precautions to the problem, though. Having a vert, I went the reinforced RSM route from Ground Control.
They generally will ask you if you want to change the plugs when they perform a valve adjustment, which saves you a bit of labor versus doing it at an interval where you don't do the valve adjustment. Plugs are cheap anyway, even the really good ones.
Jump to top Quicksilv3r is offline   Reply With Quote
0000, turned, zcp
Turned 40 today... bimmer777 E46 M3 (2001-2006) 36 Sun, Feb-28-2010 01:55:11 AM
F1 turned upside down?????> King Luis Off Topic 29 Mon, Mar-30-2009 04:37:15 PM
Turned in the M3 today... Vegas E46 M3 (2001-2006) 4 Tue, Mar-06-2007 06:28:22 AM
0000 Cleveland Test Forum 2 Tue, Dec-12-2006 07:59:42 PM
new m5 came up, turned it down... m3mofo General BMW Discussion 9 Sat, Mar-04-2006 02:13:32 AM
Discussing Just turned 60,0000 on my '06 ZCP in the E46 M3 (2001-2006) Forum - Engine: S54 - Max Hp: 333 hp at 7,900 rpm / 262 lb/ft at 4,900 rpm
