Dr. Awesomesauce
![]() Location: Boston
I tackled the auto dimming mirror w/HomeLink (garage door opener, called UGDO by BMW) retrofit today. I didn't plan to make this a DIY, so sorry for the lack of pictures. I did this on my 04/99 coupe with a sunroof. The wire colors may be different in your car.
You should be able to do this on a car without a sunroof, but I'm not sure how to access the map light wiring harness (required) on a car like that, so you're on your own. I don't have an alarm, so I did not bother looking for the wiring harness with the provision for the alarm LED wire(s). The part number for the mirror I bought is 51167028444. The part number for the retrofit kit is 51160001231. It's ~$25, and includes the wiring harness, 3 BMW wire taps (I found these useless), and a grommet. The part number for the end caps is 51167133655. It's ~$10 for the pair of covers. Mirror: ![]() HomeLink buttons: ![]() Wiring harness, grommet, and the BMW wire taps that I didn't use: ![]() End caps: ![]() First, remove your existing rear view mirror. Tilt the mirror downwards, and grab the base, where it connects to the windshield. Gently turn it counter-clockwise, until you get to approximately 45 degrees. The entire mirror should now pop off the windshield, easily. The next step is to remove the sunroof motor cover / panel. It just pries out (gently) from the top with a flat-head screwdriver. Disconnect the sunroof up/down switch. The next step is to remove the map light assembly. You'll see some black clips at the top of it. Push those, and push the map light assembly down and out. It will fall. Let it dangle. Then, insert the wires through the provided grommet (small end of the grommet is pointing towards the bare end of the wiring harness), and run the grommet all the way to the mirror connector. Plug the cable into the mirror. Put the end caps in position, put the grommet at the top (making sure it is all snug), and clip on the end caps. This might take a few minutes of fidgeting, but you'll get it eventually. Now, take the bare wires from the harness, and while pushing down against the trim behind where the map light assembly normally sits, you should be able to feed the wires over it and into the map light assembly/sunroof motor area. Pull the harness all the way through. Make sure the grommet and end caps are snug, and then, with the base of the mirror at a 45 degree angle to the windshield, push it onto the base cap on the windshield (it should pop on) and then rotate it 45 degrees clockwise to lock it position. It should look OEM at this point. Now, back to the map light assembly. It is connected with a wiring harness, which you will need to find and remove. It's clipped on, to the left of the sunroof. Take it off, pull it towards you, and disconnect the map light assembly from the connector. The map light assembly connector (it's the white connector on the left in this picture): ![]() At this point, you need to locate two crucial wires. One is violet with a white stripe, and one is just plain brown (there is another with a stripe, this is not the correct wire). The VIO/WHT wire is hot with igntion in ON. The BRN wire is for ground. Going from left to right, you should have a Violet/White wire, a Red/White wire, a Red/Black wire, a Brown wire, and a Brown/Red wire. The 1st and the 4th wires are the ones you are going to need to cut and/or splice into. You may want to cut off most of the wiring harness at this point (you only need 6-12 inches of slack at most), and peel/cut back the BMW black tape. Splice the brown wire from the dangling mirror harness into the brown wire on this harness. Splice the green/white wire (homelink/autodim power) from the mirror harness into the violet/white wire. If you want to hook up the autodim-cancel when the car is in reverse, run the blue/yellow wire down the a-pillar to a reverse light indicator source. I didn't bother with this, because I'm lazy. Reconnect the map light assembly to the harness, tuck it back into position, and reinstall the map light assembly. Plug the harness for the sunroof open/close switch back in, and insert the sunroof trim panel back on. It's not easy (I had to do some major bending/fidgeting to get it back on). The HomeLink and autodim should now be operational. They should only function with the ignition in ON. To program the HomeLink, first, hold down the 1 and 3 button until the orange LED flashes quickly and constantly. Let go of the buttons. Get your garage door opener, and hold down the button on the mirror that you want to program. The LED should turn on and stay on (or it might turn off, I'm not sure). Either way, keep holding down the button. Then, press and hold your garage door opener button. After 3-4 seconds, the LED should begin to flash quickly. Let go of all the buttons. Your HomeLink should open/close the door, now. Rinse and repeat for the other side. Finished product: ![]() ![]() ![]() Last edited by Anubis; Fri, Mar-27-2009 at 02:29:44 AM. |
Sinner
![]() Location: Ventura, CA
Very cool mod.
-Jason
"The warrior above all others prays for peace, because it is the warrior who must suffer and bear the deepest wounds and scars of war." ![]() '97 arktissilber-metallic///M3 |
eh
![]() Location: Gilbert
nice diy Jeff...been thinking of this, now I'll probably do it as it does not seem so bad.
Robert 1998 m3 Cosmos/Grey |
#4 |
:FACEPALM:
![]() Location: San Diego
good stuff Jeff..
#5 |
![]() Location: Goshen, NY
Nice job, it is a big improvement
#6 |
Unregistered User
![]() Location: Atlanta
Sweet! If I had not turned the ASC button into the garage door opener, I would do this upgrade.
#7 |
Ka-chow!
![]() Location: SF Bay
Wow Jeff...good stuff.
Can we get rid of that red thing below the mirror? what is that? Thanks!
#8 |
The Snozberries Taste Like Snozberries!
![]() Location: East Bay (925), California
+1 Looks great, I'm also interested whether you can take the red thing off aswell.
![]() BF.C: NorcaL M |
#9 |
Hi there!
![]() Location: Memphis, TN
Well now you've got me wanting to buy a new mirror...there goes some $$$.
Matt
Team Mercedes |
#10 |
The Anti-Poser
![]() Location: Ft. Worth
I double sided taped my garage remote to the front side of my review mirror...DIY to come...does this count?
T2 - www.thedriversedge.net "I'm just a caveman. I fell on some ice and later got thawed out by some of your scientists. Your world frightens and confuses me! Sometimes the honking horns of your traffic make me want to get out of my BMW and run off into the hills, or wherever. Sometimes when I get a message on my fax machine, I wonder: "Did little demons get inside and type it?" I don't know! My primitive mind can't grasp these concepts."
| auto, auto dimming, autodim, dimming, diy, homelink, mirror, rear, retrofit, view |
| oval dimming rear view mirror!!! | huichoval | Parts for Sale/Wanted | 12 | Mon, May-21-2012 04:44:15 PM |
| Self-Dimming Rear View Mirror | RidinBimmerz | E46 M3 (2001-2006) | 38 | Wed, Nov-17-2010 01:32:55 PM |
| Auto dimming rear view mirror | M3SMG04 | E46 M3 (2001-2006) | 28 | Fri, Jun-26-2009 07:10:05 PM |
| Bmw Auto Dimming Motorsport Rear View Mirror | cr22145 | Parts for Sale/Wanted | 14 | Thu, Jun-12-2008 07:39:32 AM |
| Rear View Mirror Dimming Question..... | avi8tir | E46 M3 (2001-2006) | 7 | Thu, Sep-07-2006 08:30:39 PM |
