Old Sat, Mar-21-2009, 05:49:21 AM   #1
wally828
Reputation: 0 wally828 is on a distinguished road
Default Power Steering Noise
When I took my car in to the dealership for an oil service back in January, I told the rep to check out my power steering because I was hearing the infamous whinny noise coming from it. He ended up telling me that there was a leak in the power steering hose, and when I asked him where the leak was coming from (if there was a tear in the hose somewhere or if the leak was coming from the seal), he said, "I'm not sure, but the technician said it was leaking." I told them to just fill it up to where it needed to be filled, and I'd keep an eye on it. I've been checking it ever since, and the level stays the same, which sounds to me like there is no leak. I never see any spots on the ground under my car where a leak occurs either. I've searched the forums and found people talking about replacing the reservoir because the filter inside it will make noise when clogged. I know that the M3 having a high pressure power steering hose entitles it to making a little more noise than the standard hose, but I know it's making an abnormal amount. It gets louder with the rpm increase, and it gets pretty bad when turning the wheels. Does anyone have any ideas what the problem could be? I don't want to replace the hose if I don't have to, but I also don't want to replace the hose and continue to hear the same noise. Thanks for any help.
Jump to top wally828 is offline   Reply With Quote
Old Mon, Mar-23-2009, 05:06:43 AM   #2
wally828
nothing? hmmm
Old Mon, Mar-23-2009, 05:33:34 AM   #3
Str8///Left
Leave the others behind.
Str8///Left's Avatar
Reputation: 0 Str8///Left is on a distinguished road
most likely the pump is going bad.
Jump to top Str8///Left is offline   Reply With Quote
Old Mon, Mar-23-2009, 05:42:05 AM   #4
Sman139
wheel wh*re in the making
Sman139's Avatar
Reputation: 0 Sman139 is on a distinguished road
i am having the same issue.....would LOVE to get this figured out
2003 ///M3 6sp. CB/Cinnamon
Gone
/// TC Kline /// Rogue Engineering /// Vorsteiner /// DICE /// Depo ///
"This is the best car and always will be and there is no point in thinking otherwise"
-Jeremy Clarkson
Jump to top Sman139 is offline   Reply With Quote
Old Mon, Mar-23-2009, 05:50:41 AM   #5
PKumarM3
Reputation: 0 PKumarM3 is on a distinguished road
undo the splash guard and see if any fluid has collected there.
also, when ur down there look for any evidence of fluid.
im a noob when it comes to the m3, but that seems like a pretty good step.
Jump to top PKumarM3 is offline   Reply With Quote
Old Mon, Mar-23-2009, 05:58:14 AM   #6
HattoriHanzo
HattoriHanzo's Avatar
Reputation: 0 HattoriHanzo is on a distinguished road
You sure its the power steering? The differential makes a similar noise during low speed turns, like a U-turn if it does not have the correct fluid with FM booster. I thought it was my power steering also, but I could hear it from the rear. Got the fluid in there and problem solved.
E46 M3 |Topaz Blue Metallic/Cinnamon
K7 GSX-R1000 |Candy Max Orange/Space Black
10.1@142 | 165.5rwhp
Jump to top HattoriHanzo is offline   Reply With Quote
Old Mon, Mar-23-2009, 06:22:05 AM   #7
justinliu
justinliu's Avatar
Reputation: 0 justinliu is on a distinguished road
I have that whiny noise as well with my power steering...
my steering column also makes a squeeking noise as well..does anyone else have this problem? It's a seperate sound that I hear in the cabin of my car.
Jump to top justinliu is offline   Reply With Quote
Old Mon, Mar-23-2009, 08:43:33 AM   #8
mymIII
Reputation: 0 mymIII is on a distinguished road
http://www.m3forum.net/m3forum/showt...Power+steering
I did this when my power steering was making whinning noise. It seems to help, but alittle whinning is still there. I'm pretty sure my power steerig pump is going. I'll prob replace it when the weather gets warmer.
Jump to top mymIII is offline   Reply With Quote
Old Mon, Mar-23-2009, 02:40:58 PM   #9
deilenberger
deilenberger's Avatar
- ALL BMWs eventually get weeping power steering hoses. It's tradition. The leak never gets all that bad, but it can make a bit of mess.
- If the filter clogs (in the bottom of the fluid reservior) - the system will get noisy since the pump doesn't like trying to pull against a plugged filter
The time to fix the leak is also a good time to replace the reservoir (about $40/part) - since you have to disconnect it anyway, and drain the system. It's actually quite rare for the power steering pump to go bad.
Old Mon, Mar-23-2009, 07:53:28 PM   #10
Volox69
Service Manager - Stealership Questions Here
Volox69's Avatar
Reputation: 0 Volox69 is on a distinguished road
Mine was noisy. I flushed the power steering system. Now it's not.
How's the fluid look. P.S. pumps don't like dirty fluid either.
01 LSB M3
6spd Manual, CF CSL style Diffuser, 19" SSR GT10's, Smoked LED Tails from Umnitza, Angel Eyes, K&N CAI, Rogue El Diablo.
Jump to top Volox69 is offline   Reply With Quote
noise, power, steering
Delete AC, power steering, power brakes? imaverb E36 M3 (1992-1999) 8 Mon, Dec-22-2008 12:10:51 PM
Manual steering rack-removed power steering ///M3*Snow22 E36 M3 (1992-1999) 14 Mon, Aug-06-2007 11:12:58 PM
Steering Noise flagger E46 M3 (2001-2006) 0 Sat, May-27-2006 12:58:35 AM
Steering Column, Steering Wheel Noise!! Dooly E46 M3 (2001-2006) 2 Wed, Jun-15-2005 04:27:34 PM
Wierd noise from M3 ?.. Power steering magas E36 M3 (1992-1999) 3 Tue, Nov-16-2004 06:19:06 AM
Discussing Power Steering Noise in the E46 M3 (2001-2006) Forum - Engine: S54 - Max Hp: 333 hp at 7,900 rpm / 262 lb/ft at 4,900 rpm
