Old Sat, Feb-28-2009, 12:28:34 PM   #1
BAV_M_PWR
BAV_M_PWR's Avatar
Reputation: 0 BAV_M_PWR has a reputation beyond reputeBAV_M_PWR has a reputation beyond reputeBAV_M_PWR has a reputation beyond repute
Default Which O2 sensor in the pics is the Bank 1/2?
Please take a look at the pictures below. Which O2 sensor goes to bank 1, and
which O2 sensor goes to bank 2? As I am installing new O2 sensors, assume that
they are currently connected improperly, or I otherwise do not know if they are or
aren't connected properly
Now a follow-up question...Does the connection for the rear O2 sensors matter?
In other words, can either post-cat O2 sensor be connected to either side? If not,
which sensor goes to which side in the pic below? Thanks!
2003 JET BLACK ///M3 SMG
Originally Posted by //Ali View Post
What's lesson #2, oh Lord of Ridiculous Posts
Jump to top BAV_M_PWR is offline   Reply With Quote
Old Sun, Mar-01-2009, 02:38:42 AM   #2
kmurph
Reputation: 0 kmurph will become famous soon enough
With regards to the rear O2s, it's my understanding that they need to replaced in the correct order, however, as you probably know, it would not affect performance either way since they only monitor emissions - you might just throw a SES light.
Also, I think they both have different cord lengths, so they might only reach to correct plug at the valve cover...I would think that the best thing to do is to tag them or remove them one at a time to verify which one goes where...
I've tried to replace the pre-cat O2 sensors on my car from underneath, but have had no luck...one sensor is easy to get to while the other is not. I tried a 22mm o2 sensor crows foot socket with an extension, but it was too tall and didn't work in the tight space. I plan on trying a lower profile crows foot socket.
From where did you replace the pre-cat O2s? From above or below? I haven't removed the heat shield from the top, but don't want to if I'm wasting my time. Any help would be apprecited...btw, I have stock headers.
2007 Audi RS4 / GMG Exhaust
2001 BMW M3 - sold
Jump to top kmurph is offline   Reply With Quote
Old Sun, Mar-01-2009, 03:02:49 AM   #3
ohnoes
Reputation: 0 ohnoes is on a distinguished road
Pre-cat O2s, especially for cars that have headers, are a bit of a b*tch. Much easier with a lift.
As for the rear O2s, yes, it matters, but only from a monitoring standpoint; i.e., it will say "bank 2 catalytic efficiency poor" or whatever when it's really bank 1, because you have the sensors reversed. However, as mentioned above, I don't think it's possible/easy to swap them, since the wire lengths differ.
Jump to top ohnoes is offline   Reply With Quote
Old Tue, Mar-03-2009, 11:08:58 PM   #4
nikleplated357
nikleplated357's Avatar
Reputation: 0 nikleplated357 is on a distinguished road
r u installing 4 new ones
Jump to top nikleplated357 is offline   Reply With Quote
1 or 2, bank, pics, sensor
Bank 2 Post-Cat O2 sensor. How do i get there? kkamakasi E46 M3 (2001-2006) 5 Tue, Aug-12-2014 09:11:18 PM
DIY Wideband O2 Sensor Replacing Stock O2 Sensor (E46 M3) Finally Done.... jmciver Forced Induction (F/I) 2 Thu, Oct-25-2007 04:11:14 PM
P3890 Oxygen Sensor Control, Bank 1 nova-silver E46 M3 (2001-2006) 10 Thu, Apr-19-2007 02:00:30 AM
O2 sensor Bank 1. drivers or passenger side? Dreams190 E36 M3 (1992-1999) 6 Mon, Jan-22-2007 03:28:18 AM
bank 2 O2 sensor Flexia E36 M3 (1992-1999) 0 Sat, Jun-11-2005 06:01:18 PM
Discussing Which O2 sensor in the pics is the Bank 1/2? in the E46 M3 (2001-2006) Forum - Engine: S54 - Max Hp: 333 hp at 7,900 rpm / 262 lb/ft at 4,900 rpm
