Old Mon, Feb-09-2009, 02:21:09 PM   #1
Default Mayday: Obioban/Surge709 e36 M3 track car
Sergei (Surge709) and I just split and picked up this euro engined e36 M3
Drove down to TN this weekend (600 miles each way in a suburban ) and picked this up. Looks like the LS1 conversion project is canceled as this car was cheap enough that we just couldn't say no
Loaded onto the trailer:
And back at home in the garage:
edit: more pics:
upcoming projects for this car (before spring):
replace bumper with stock e36 bumper
get black trim
sticker delete
clutch replacement
front and rear brake ducting
add a second seat (as well as relocate the fire suppression tank and cool suit box to the back seat so there's space for it)
probably fender flares and bigger wheels/tires
maybe paint GT3 RS green
Incomplete mod list (pulled directly from the ad we bought it from ):
euro s50b32 w/Schrick cams (only 1 race on new setup)
Alpha N DME
Roughly 310 rwhp
Homemade 4 inch intake
Moton/JRZ Triple Adj. Motorsport Suspension true coilover front/back (completely rebuilt both front and rear)
HyperCoil springs on all four corners
Custom Cage by Piper Motorsport
Reinforced rear subframe by Piper Motorsports using TMS parts
Front subframe was also reinforced by Piper Motorsports
Rear cage was specifically designed for coilover suspension.
Subframe tied into the cage
Bimmerworld Dual Fuel Pumps
Brembo GT 332mm front brakes
Lightweight Flywheel
M5 clutch (needs to be replaced)
5 speed transmission
3.91 diff built with 40% lockup. Only 1 race weekend on diff.
TC Kline diff cooler
All aluminum radiator
Euro oil cooler
Euro electric fan with on/off switch
Lexan front/rear and sides
Crawford rear wing
TMS solid aluminum motor mounts
TMS solid tranny mounts
TMS solid subframe mounts
TMS Adj. rear trailing arms
TMS fiberglass headlight intake and TMS fiberglass solid passenger headlight cover
New front control arms
New tie rods
Most if not all bushings have been replaced for race application
New front wheel bearings
Skinned front doors
Skinned trunk lid
E46 style front bumper cover (fiberglass...lightweight) Needs fresh paint due to track debris
3 inch exhaust with cat delete and no resonators (race muffler)
Fresh paint in 2007
Front splitter made from lightweight alumalite.
Ground Control Front swaybar (hollow...lightweight)
1 set of OZ Superleggera's 18x9 (weigh roughly 20 lbs per rim)
1 set of H&R 15mm spacers
Vorshlag camber plates
euro gauge cluster
AutoMeter Water temp, Oil temp and Oil pressure gauges
Functioning ABS with on/off switch
Cool Suit cooler and lines with mount
Push start ignition button
Rebuilt Starter with 1 race weekend
Battery replaced within the last 18 months...lighter than stock @ roughly 20 lbs
Parking brake delete for weight savings
Aluminum panel for covering sunroof hole. Work performed by Piper Motorsport. Really nice work!
Significant wiring delete. Practically down to only the essentials. BMW wiring retained for reliability.
Car weighs roughly 2550 dry
Vehicle was professionally setup and gone over this past spring.
A lot of work was completed just prior to the May event at Mid Ohio
Sparco Evo L seat (red)
Sparco steering wheel
Schroth 6 point harness belts...shoulder belts accomodate Hans
Old Mon, Feb-09-2009, 02:22:18 PM   #2
get black trim
sticker delete
clutch replacement
Old Mon, Feb-09-2009, 02:30:40 PM   #3
Did the clutch and flywheel this weekend (and the fuel filter while we were in there). Sergei's wife also helped us a LOT by peeling off a good number of the stickers, including the satan sticker (UUC). Pics:
Car on the lift, with many less stickers:
Tranny out:
new RE stuff:
Old UUC garbage parts (by old I mean <5000 miles. 100% failed, though):
Drive shaft and a random shift lever
One piece exhaust from the headers back, so it all comes out
Diff minus drive shaft:
Nice new fly wheel bolted in place:
random suspension shot
Sergei and I are happy about a successful install
contemplating:
Matt, looking like he's doing something real:
Sergei, looking busy (fuel filter?)
Bolting the tranny back in on the mount end
Test drive, in the snow. This is what r comps are made for, right?
Back on the ground, driving well
Old Mon, Feb-09-2009, 02:38:14 PM   #4
RE stg 2 clutch/flywheel is great so far, btw. Feels like stock despite the vastly increased clamping power, and (at least as of yet) no noise from the flywheel. Color me impressed .
Old Mon, Feb-09-2009, 02:40:56 PM   #5
mikeygar
S50B32 Power!!!
Reputation: 0 mikeygar is on a distinguished road
congrats!!! Subscribing! Curious to what you guys will use to reprogram the DME. I have a S50B32 M3 evo and want to do AlphaN also.
Jump to top mikeygar is offline   Reply With Quote
Old Mon, Feb-09-2009, 02:45:53 PM   #6
It came tuned, so not going to worry about it. Sorry
Old Mon, Feb-09-2009, 03:09:21 PM   #7
HaroldC
Yes, it's stock.....
HaroldC's Avatar
Reputation: 0 HaroldC is on a distinguished road
Nice work Ian. Looking forward to seeing you out at the track with the beast this season. What's your first event?
Jump to top HaroldC is offline   Reply With Quote
Old Mon, Feb-09-2009, 03:48:12 PM   #8
Not sure yet... trying not to sign up for anything till the car is 100% ready to drive...
Old Mon, Feb-09-2009, 04:01:12 PM   #9
LightWerkz
Automotive Lighting Innovations
LightWerkz's Avatar
Reputation: 0 LightWerkz is on a distinguished road
Nice work Ian.
Caesar Rowinski - LIGHTWERKZ
2001 BMW M5 - Alpine White on Caramel
Jump to top LightWerkz is offline   Reply With Quote
Old Mon, Feb-09-2009, 05:03:16 PM   #10
HaroldC
HaroldC's Avatar
Makes sense, pretty logical.
Me, not so much. I'm signed up for comp school at the end of March. I guess the deadline forces me to finish the car in time.
car, e36, mayday, obioban or surge709, track
Obioban/Surge709: LS1 powered e36 widebody track car Obioban Member Journals 60 Fri, Jan-09-2009 10:22:27 PM
E36 M3 for a Track Car...? Junger E36 M3 (1992-1999) 21 Wed, Dec-03-2008 08:18:44 AM
which E36 M3 for track car? attbimmer E36 M3 (1992-1999) 11 Tue, Jul-10-2007 05:44:27 AM
E36 M3 vs Spec E36 for a Track Car? gel M3 Track: Racing and DE 6 Sun, Mar-04-2007 02:21:38 AM
E36 M3 as a track car.... tomwac E36 M3 (1992-1999) 20 Sun, May-14-2006 07:44:27 PM
Discussing Mayday: Obioban/Surge709 e36 M3 track car in the Member Journals Forum - Do you have a long term project you would like to share with the community? Use this forum to create a single thread which you can update over time to document the progress. at BMW M3 Forum.com (E30 M3 | E36 M3 | E46 M3 | E92 M3 | F80/X)
