Old Wed, Feb-04-2009, 05:15:05 PM   #1
kosmickid
Reputation: 0 kosmickid is on a distinguished road
United Kingdom
Default OBD II Port Location
Had a quick search in the dark and on the forums and couldnt find anything conclusive. I know its probably a dumb question but where is the OBD II Diagnostic port located on/in the car? Bearing my car is a UK RHD vehicle.
Thanks all
Jump to top kosmickid is offline   Reply With Quote
Old Wed, Feb-04-2009, 05:54:29 PM   #2
kosmickid
United Kingdom
Anyone?
Old Wed, Feb-04-2009, 05:58:48 PM   #3
hossmp
Reputation: 0 hossmp is on a distinguished road
Scotland
The only place I know of to plug in is under the drivers side dash. Its basically above the clutch pedal there is a small door that comes down. I dont know if the UK car is different or not. I am assuming you are looking for a place to plug a code reader or some sort of software device like the shark injector.
Jump to top hossmp is offline   Reply With Quote
Old Wed, Feb-04-2009, 06:05:31 PM   #4
JeST
Old Skool
JeST's Avatar
Reputation: 0 JeST will become famous soon enough
China
LHD it's right where hossmp described. For you car since it's RHD it'll be around the same area but above the gas pedal. You'll tee the tab, just pull down and the access port for the OBD is behind that.
1994 Toyota Supra 6speed Red/Black
Big Single + Meth
Jump to top JeST is offline   Reply With Quote
Old Wed, Feb-04-2009, 09:14:41 PM   #5
kosmickid
United Kingdom
Thanks guys, ill have a look. Is it a rectangle 17 pin plug or a round plug?
Old Thu, Feb-05-2009, 12:22:31 AM   #6
JeST
Old Skool
JeST's Avatar
China
Rectangular
Originally Posted by PeakeResearch
2000 and later
16 pin socket
under dash
Big Single + Meth
Old Thu, Feb-05-2009, 12:26:03 AM   #7
Fury
Come and Take it
Fury's Avatar
Reputation: 0 Fury has a spectacular aura about
That would be it, just make sure when you close it you do it properly or you might bend some pins.
Jump to top Fury is offline   Reply With Quote
location, obd, port
OBD Port Question JamesR E46 M3 (2001-2006) 20 Wed, Nov-11-2009 01:54:14 AM
OBDII Port Location 4getR34 E46 M3 (2001-2006) 3 Thu, Mar-06-2008 08:47:38 PM
OBD 2 connector location!?!? Yav E36 M3 (1992-1999) 1 Tue, Sep-27-2005 02:22:11 PM
Time from port to dealer? Car is on Jupiter diamond, arrives 6/14 in port The Oregonian E46 M3 (2001-2006) 8 Mon, Jun-07-2004 09:46:47 PM
OBDII port location? M3Eddie E36 M3 (1992-1999) 3 Thu, Jan-08-2004 04:18:04 PM
Discussing OBD II Port Location in the E46 M3 (2001-2006) Forum - Engine: S54 - Max Hp: 333 hp at 7,900 rpm / 262 lb/ft at 4,900 rpm
