Old Sun, Jan-11-2009, 05:47:12 AM   #1
SoCal_M3
Reputation: 0 SoCal_M3 is on a distinguished road
Default Broken Stereo Volume Knob
Looking for some advice. On my 2003 M3, the volume and on/off switch is broken. Volume part works but it's near impossible to turn on & off.
Any suggestions on whether a repair is an option?
Jump to top SoCal_M3 is offline   Reply With Quote
Old Sun, Jan-11-2009, 07:21:51 AM   #2
silber
Reputation: 0 silber is on a distinguished road
Same on my business unit, but I think it's the knob. If you pull the knob off, can you turn it off?
Edit: Just searched for the business unit on RealOEM and found the part number for the volume knob. Might be worth checking as it's only an $8 part at Tischer:
P/N: 65126923321
Link
Jump to top silber is offline   Reply With Quote
Old Sun, Jan-11-2009, 07:47:43 AM   #3
M3MurkU
Reputation: 0 M3MurkU is on a distinguished road
i got a mint unit if you want it let me know.
Jump to top M3MurkU is offline   Reply With Quote
Old Sun, Jan-11-2009, 07:49:51 AM   #4
Mobbin_PCH
Chuck Norris's Hero
Mobbin_PCH's Avatar
Reputation: 0 Mobbin_PCH is on a distinguished road
I have the same problem. It is not the knob that is broken, but the actual piece in the stereo which holds the knob.
I have just learned to live with it and turn the volume all the way down instead of trying to turn it off. I know it sounds lame but i don't want to but a whole new stereo
Jump to top Mobbin_PCH is offline   Reply With Quote
Old Mon, Jan-12-2009, 03:50:08 AM   #5
2002SilverM3
Reputation: 0 2002SilverM3 is on a distinguished road
Default Same thing happened to me, got it fixed for $45
Hey there,
Same issue about 6 months ago...the volume/power knob broke off of it's solder points inside the radio. Took it to a private car/radio repair shop, and the owner was able to pull the stereo, open it, resolder the knob back into position, and replace the head unit within 25minutes. He's in San Antonio, TX, though.
Good luck!
RCS
Jump to top 2002SilverM3 is offline   Reply With Quote
Old Mon, Jan-12-2009, 10:10:50 AM   #6
hifiguy
Mthusiast
Reputation: 0 hifiguy has disabled reputation
had the same issue on my '04 during the warranty period.
took it to the dealer and they just replaced the whole unit, said an internal piece was broken. you can try opening it or take it to a stereo shop as suggested.
clear bra, ceramic tint 60F/50R, rx65, pss9, dixis, volk le-37, stud conversion, yellow belts
Jump to top hifiguy is offline   Reply With Quote
Old Fri, Jan-16-2009, 12:25:29 AM   #7
M_Thrizzle
M_Thrizzle's Avatar
Reputation: 0 M_Thrizzle is an unknown quantity at this point
I have a different problem w/ my volume knob. I can turn it on/off, but when i spin the dial, it will be non-responsive or do weird things like lower the volume when I spin it the direction to go higher, jump up the volume by a lot, etc. any idea what my problem is?
2001 Jet Black ///M3 6MT rolling on 19" BBS CH's | PSS-9 suspension | OEM Strut Brace | UUC Swaybars | K&N CAI | Powerflex RTAB's | Rogue Engineering Rasp Pipe & RSM's | Cold Weather Pkg | Pwr Seats | HK Audio | Homelink
RIP: 2004 Infiniti G35 coupe 6MT | Diamond Graphite | OEM Brembo's | Z-tube, K&N, Plenum Spacer, Stillen Sway Bars
Jump to top M_Thrizzle is offline   Reply With Quote
Old Fri, Jan-16-2009, 12:51:23 AM   #8
Airbag79
Airbag79's Avatar
Reputation: 0 Airbag79 is on a distinguished road
All volume knobs are potentiometers (variable resistors). Most equipment nowadays employs the digital potentiometer, vs the old school analog potentiometer. It sounds like the linearity of your discrete potentiometer is poor, thus producing the erratic behavior of your volume. Old school analog potentiometers are much more reliable.
08 Porsche Cayman S Design Edition 1 #434/777
06 SGM/BL 6-spd Coupe SOLD
"I refuse to tip-toe through life to arrive safely at death"
Jump to top Airbag79 is offline   Reply With Quote
Old Fri, Jan-16-2009, 01:28:19 AM   #9
mugenh22a4
เป็นคนจีน
mugenh22a4's Avatar
Reputation: 0 mugenh22a4 is on a distinguished road
Hong Kong
pretty unacceptable for a $50k (when new) car...
2008 ISF, Smokey Granite Mica on Black
[IMG]http://img25.imageshack.us/img25/780/dsc3038mod.jpg[/IMG ][IMG]http://img641.imageshack.us/img641/6913/dsc2821edited.jpg[/IMG ]
Jump to top mugenh22a4 is offline   Reply With Quote
broken, knob, stereo, volume
Stereo Speed Volume Adjst with Navi System RumbleStrip E46 M3 (2001-2006) 7 Sun, Oct-05-2014 03:46:41 AM
Turning down Auto Volume on HK Stereo MPowerScott Audio/In Car Entertainment (I.C.E.) 17 Tue, Aug-14-2007 12:23:12 PM
Stereo Volume scottM3 E46 M3 (2001-2006) 14 Mon, Sep-18-2006 02:37:58 AM
how to turn off speed sensitive stereo volume? blacke36m3 E36 M3 (1992-1999) 14 Wed, Jun-14-2006 08:33:15 PM
Self Adjusting Volume Stereo on M3 Convertible? mw E46 M3 (2001-2006) 10 Tue, Dec-09-2003 08:24:35 PM
Discussing Broken Stereo Volume Knob in the E46 M3 (2001-2006) Forum - Engine: S54 - Max Hp: 333 hp at 7,900 rpm / 262 lb/ft at 4,900 rpm
