Old Fri, Dec-12-2008, 01:18:49 AM   #1
FCars4Ever
FCars4Ever's Avatar
Reputation: 0 FCars4Ever is on a distinguished road
Default Need part number for driver side door actuator
Hey Guys,
So recently my car has been telling me that my driver side door is open (Interior lights come on, window goes down a little bit, and light on dash illuminates) when I am driving and the door is really closed. After doing some searching, it seems that my door actuator needs to be replaced. Since I have had nothing but horror stories dealing with dealerships, I figured I will just replace it myself. I just need to find the part number so I can order it from Tischer. Anyone know the part number?
Thanks guys, I appreciate it.
Dimitri
2008 Chevrolet Corvette Coupe
Arctic White/Two Tone Red/Black
2004 BMW ///M3 Coupe SMG (SOLD)
Laguna Seca Blue/Black
Jump to top FCars4Ever is offline   Reply With Quote
Old Fri, Dec-12-2008, 02:59:09 AM   #2
miljip
Reputation: 0 miljip is on a distinguished road
Find that here "realoem.com"
Jump to top miljip is offline   Reply With Quote
Old Fri, Dec-12-2008, 03:02:11 AM   #3
JeST
Old Skool
JeST's Avatar
Reputation: 0 JeST will become famous soon enough
China
51217011247 $151.78
http://www.realoem.com/bmw/showparts...54&hg=41&fg=40
Dimitri, this is kind of a involved job. Good luck.
1994 Toyota Supra 6speed Red/Black
Big Single + Meth
Jump to top JeST is offline   Reply With Quote
Old Fri, Dec-12-2008, 03:10:43 AM   #4
ohnoes
Reputation: 0 ohnoes is on a distinguished road
Originally Posted by JeST View Post
51217011247 $151.78
Yeah, it's a pain in the ass. Gotta remove the door panel, vapor barrier, airbag module, regulator and window (most likely, to get any room to work), disconnect both the interior and exterior door handle cables from the actuator, disconnect the locking pin thing, then there's probably a few bolts to get the actuator out.
That's just from memory from working in there a few times, but I'm probably off with a few things.
Jump to top ohnoes is offline   Reply With Quote
Old Fri, Dec-12-2008, 03:14:18 AM   #5
JeST
Old Skool
JeST's Avatar
China
Only other pain in the ass thing to mention is if you decide to do the shortcut method you can slip it passed the window regulator with force but if you decide to do it the standard way you'll have to remove the window and the window regulator.
ps. if you decide to remove window regulator and window you'll need to adjust the window afterwards with BMW's special tool.
Big Single + Meth
Old Fri, Dec-12-2008, 03:18:45 AM   #6
ohnoes
You need to adjust it even if you put it back in the exact same position?
Old Fri, Dec-12-2008, 04:58:30 AM   #7
BlackOnBlack
2005 M3 ZCP 6MT*
BlackOnBlack's Avatar
Reputation: 0 BlackOnBlack is on a distinguished road
$104.....
http://www.trademotion.com/partlocat...&siteid=214672
part number 51217011247
i have the same problem......
My 2005 M3 ZCP Journal
Current:
2005
///M3 ZCP 6MT
2011 Ducati Monster
Previous:
2003
///M3 SMG
2007 650i
2004 CBR 600RR
-> Love the E46 M3? Check Out my E46 M3 Video! <-
Jump to top BlackOnBlack is online now   Reply With Quote
Old Fri, Dec-12-2008, 05:20:45 AM   #8
JeST
Old Skool
JeST's Avatar
China
If you remove the window and window regulator from the car it's really unlikely you can position the window back to the spot it needs to be (there's 4 different adjustments).
Big Single + Meth
Old Sat, Dec-13-2008, 06:58:08 AM   #9
FCars4Ever
FCars4Ever's Avatar
Well, now my car is REALLY going crazy. Had to disconnect the battery for the night because my car keeps thinking the door is opened and turns on the lights while it is just sitting locked in the garage.
Ordered the part from Tischer just now. Anyone have a link to a DIY? I would really rather not have to take it to the dealership.
actuator, door, driver, number, part, side
Brand New Driver Side Door Actuator babydevilj Parts for Sale/Wanted 1 Fri, Feb-27-2009 03:25:52 PM
Door lock actuator pic/part #?? LagunaE46 E46 M3 (2001-2006) 10 Sun, Nov-05-2006 04:28:57 PM
Does anybody the part number for the driver side/front PSS9? JakeM3 E46 M3 (2001-2006) 0 Thu, Jul-27-2006 09:39:59 PM
Need the part number for Driver side led tail light !!! Paul_88 E46 M3 (2001-2006) 2 Tue, Apr-18-2006 08:36:32 PM
Passenger Side Door Clip Part Number (HK Rattle) Caz E46 M3 (2001-2006) 4 Tue, Nov-08-2005 10:41:31 PM
Discussing Need part number for driver side door actuator in the E46 M3 (2001-2006) Forum - Engine: S54 - Max Hp: 333 hp at 7,900 rpm / 262 lb/ft at 4,900 rpm
