Old Sun, Nov-30-2008, 03:12:32 PM   #1
FDJon
FDJon's Avatar
Reputation: 0 FDJon is on a distinguished road
Germany
Default Help! car starts, then dies
Guten Tag!
I've tried searching, but it seems everyone else's "start problem" has different symptoms than mine..
Here's my dilemma. After cranking and starting the car, it idles fine for a second, then dies.
I should also note that I am in Berlin on business, and the ball n' chain is caring for the car back in LA, until I ship it over to Germany in a couple months after I get settled in.. Last week the battery died, so she changed it and now I have this problem.
A good friend of mine (retired independent shop owner, worked on Bimmers for decades) is convinced it's either the fuel pump or MAF sensor. I searched on here for problems related to the MAF or fuel pump, but similar problems involve cranking and initial startup- mine starts fine, then dies..
I'm thinking it's the alternator?
Any Ideas from the Gurus? Don E?
Help!!
Vielen Dank!!
jon
02 LSB 6MT Coupe (sold!)
93 RX7 5MT
07 E86 M Coupe
Jump to top FDJon is offline   Reply With Quote
Old Sun, Nov-30-2008, 03:31:59 PM   #2
deilenberger
deilenberger's Avatar
I would tend to agree with your friend.. although the reason for it being the fuel pump may not be so obvious.
If the M3 system works like other BMW systems do - the pump is powered up when the starter is activated, and the power to it only remains on after the engine is started and running. If the engine doesn't start, or the engine stalls for some reason the system is supposed to turn the pump off.
It sounds as if the ECU isn't seeing the "keep-running" signal. It powers up the pump during cranking for long enough to have the engine start for a moment - but then shuts the pump down thinking the engine isn't running. As the pressure in the system drops - the engine dies.
So - what to do? Someone has to listen to the pump and try to hear if this is what's happening. Runs during startup, then shuts down and the engine stalls.
If that's the case - I'd suggest checking all the fuses (it's possible the two circuits/functions are seperately fused). If there is nothing obvious - it may be time to call in a pro who can monitor engine sensors in real time. If I had to guess - it might be the crankshaft sensor that provides the keep-alive signal.. but that's strictly a WAG.
The MAF could be checked by simply unplugging it - the ECU will go into a default map mode and the engine should run. I'm doubtful that it's the MAF, but easy to test.
Old Sun, Nov-30-2008, 03:49:53 PM   #3
FDJon
FDJon's Avatar
Germany
That was quick. damn.
Thanks for the advice, Don- I was hoping you'd see my bat-signal! haha.
Interestingly, my friend said the exact same thing about unplugging the MAF to rule that out...
Does this seem to be a common s54 problem? I've never heard of this from anyone else..
jon
93 RX7 5MT
07 E86 M Coupe
Old Sun, Nov-30-2008, 04:00:49 PM   #4
deilenberger
Two questions - I see the battery was replaced. Why? And has it run at all since the battery replacement?
Old Sun, Nov-30-2008, 05:38:14 PM   #5
FDJon
FDJon's Avatar
Germany
1. The battery hadn't been replaced since new (6 years), and it finally died and had to be jumped 3 times during the past week.
2. Apparently the car hasn't run at all since the battery replacement. Even while still connected to the jumper car with the old battery, it would start then die- which leads me to think it may not be the battery?
jon
93 RX7 5MT
07 E86 M Coupe
Old Sun, Nov-30-2008, 06:22:49 PM   #6
deilenberger
Ah - not a good thing.
Jumping a car always has the risk of causing other damage to the electronics in the car. I'm gonna guess this is what happened.
The spark you see when you connect the jumper cables causes an inductive high-voltage spike in the car's electrical system that can damage electronic components. It's recommended that when connecting a car for jumping - heavy load devices be turned ON (oddly enough) to help absorb the spike (things like the headlights, the rear-window defroster) before doing the connection.
At this point - I'd guess it has to be flatbedded to a dealer who will be able to tell more when it's hooked up to diagnostics.
Good luck..
Old Tue, Dec-02-2008, 08:50:45 PM   #7
FDJon
FDJon's Avatar
Germany
update-
1. checked the MAF by unplugging it- car still dies. Maf ruled out.
2. Fuel pump runs for a couple seconds after car dies, then shuts off. Fuel pump also ruled out.
Next step is to flatbed it to a shop- heard anything of Marina BMW Motors in Marina Del Rey, CA? Or is it necessary to bring it to the stealer?
Uh oh.
jon
93 RX7 5MT
07 E86 M Coupe
Old Tue, Dec-02-2008, 08:51:23 PM   #8
FDJon
FDJon's Avatar
Germany
Updates will be posted...
jon
93 RX7 5MT
07 E86 M Coupe
Old Tue, Dec-02-2008, 08:53:37 PM   #9
FDJon
FDJon's Avatar
Germany
..and still haven't checked the fuses yet, either. That, then the shop.
jon
93 RX7 5MT
07 E86 M Coupe
Old Tue, Dec-02-2008, 09:37:37 PM   #10
FDJon
FDJon's Avatar
Germany
maybe just to be 110% sure- i'd like to swap out the MAF with someone else's to be completely sure?
Anyone in LA (venice area) wanna help out?
jon
93 RX7 5MT
07 E86 M Coupe
car, dies, starts
Please help: car dies while driving! shardm3 E46 M3 (2001-2006) 3 Tue, Aug-26-2008 05:49:38 AM
2002 M3 Starts then dies 1 second later. Hybred Faults, Fixes and DIY 1 Wed, Jan-09-2008 07:21:44 PM
a/c? car almost dies....... Bliz33 E46 M3 (2001-2006) 0 Sat, Feb-03-2007 07:07:47 AM
car dies out of park pmexaminer Faults, Fixes and DIY 1 Tue, Sep-20-2005 07:51:31 PM
Car Dies 3 Days After Purchase! tb151 E46 M3 (2001-2006) 12 Mon, Sep-22-2003 07:32:27 PM
Discussing Help! car starts, then dies in the E46 M3 (2001-2006) Forum - Engine: S54 - Max Hp: 333 hp at 7,900 rpm / 262 lb/ft at 4,900 rpm
