Go Back   BMW M3 Forum.com (E30 M3 | E36 M3 | E46 M3 | E92 M3) > BMW M3 Discussions > E90 M3 (Sedan) | E92 M3 (Coupe) | E93 M3 (Convert) (2008-200?)
Notices
E90 M3 (Sedan) | E92 M3 (Coupe) | E93 M3 (Convert) (2008-200?) {Engine: S65 - Max Hp: 414 hp (420 hp Euro) at 8,300 rpm / 295 lb/ft at 3,900 rpm}
Old Wed, Oct-22-2008, 01:25:10 AM   #1
eric9
Reputation: 0 eric9 is on a distinguished road
Arrow 5 Week old 2008 M3 Stalling
Has anybody had this problem yet. I've driven this car with no problems in Drive Logic 4 on Auto Trans mode for the first 4 weeks. When I changed it to number 5 last Friday, the engine dies on me when I stop gently. I just switched it back to 4 on Sunday and am keeping my fingers crossed.
I called the dealer and they said there was a software update to fix the problem on my car and about 1000 others in the united states. I am scheduled it get it fixed in 2 weeks.
If anyone has had a similar problem, please respond
Eric
Jump to top eric9 is offline   Reply With Quote
Old Wed, Oct-22-2008, 01:50:14 AM   #2
Rez
Rez's Avatar
Reputation: 75 Rez is a jewel in the rough
There is a specific recall about this, take your car to the dealer with this info:
SI B28 06 08
Double-clutch Transmission with Drivelogic October 2008
Technical Service
PERFORM THE PROCEDURE OUTLINED IN THIS SERVICE INFORMATION ON ALL AFFECTED VEHICLES PRIOR TO CUSTOMER DELIVERY OR THE NEXT TIME THEY ARE IN THE SHOP FOR MAINTENANCE OR REPAIRS.
SUBJECT
Service Action: M3 with M DCT – Reprogramming for Incorrect DCT Clutch Operation
MODEL
E90, E92, E93 M3 with S65 and M DCT transmission produced up to 09/10/08
SITUATION
Due to the M DCT software error, the customer may experience a sudden loss of engine power when decelerating to a complete stop with light brake application, or when performing a multistage downshift (e.g. from 5th to 2nd gear, or from 6th to 3rd gear). At the same time, the transmission will shift into neutral, and reduced power steering assist will be detected.
In order to correct this situation, BMW is conducting a Service Action to reprogram the M DCT transmission control module on all affected vehicles. With the completion of this Service Action, the software of the complete vehicle will be updated as described in SI B09 05 01 (Coding, Individualization, Programming), Procedure B.
AFFECTED VEHICLES
This Service Action involves M3 vehicles with the S65 engine and M DCT (dual clutch) transmissions, produced from series introduction up to 09/10/08.
In order to determine whether a specific vehicle is affected by this Service Action, it will be necessary to utilize the "Service Menu" of DCSnet (Dealer Communication System) or the Key Reader. Based on the response of the system, either proceed with the corrective action or take no further action.
The chassis number ranges listed below are only for informational purposes, and are not to be considered as the only deciding factor.
Model
Chassis Number Range
M3 Sedan
E201016 – E201024
E216016 – E216265
M3 Coupe
PY40477 – PY43362
M3 Convertible
P330455 – P331741
PROCEDURE
Reprogram and recode the complete vehicle using Progman V31.1 or higher (target integration level of E89x-08-09-520 or higher).
SI B 28 05 08
Technical Service
SUBJECT
M3 with DCT with Drivelogic – Gearbox Emergency Program with FC 5060
MODEL
E90, E92, E93 M3 with S65 and Double-clutch Transmission produced up to 09/08
SITUATION
The customer may complain that intermittently the red "Gearbox Emergency Program" indicator is displayed in the cluster or in the CC. The fault code 5060 ("Parking lock – electrical fault at the parking lock magnet") is stored in the DCT transmission control module, in conjunction with the CAS fault A0B1 (Input selector lever position – implausible).
CAUSE
DCT software error
SOLUTION
On a customer complaint basis only, check the vehicle's integration level.
If the integration level is E89x-08-03-540 or lower, then reprogram and/or recode the complete vehicle with a current Progman version (target integration level is E89x-08-09-515 or higher, available since the release of Progman V31).
WARRANTY INFORMATION
Covered under the terms of the BMW New Vehicle Limited Warranty or the Certified Pre-Owned Program.
Defect Code:
28 00 02 98 00
Labor Operation:
Labor Allowance:
Description:
61 00 801
7 FRU
Programming coding modules without CAS
61 00 811
8 FRU
Programming coding modules including CAS
Old Wed, Oct-22-2008, 02:02:17 AM   #3
RONIN009
Reputation: 11 RONIN009 has disabled reputation
good stuff Rez
Jump to top RONIN009 is offline   Reply With Quote
Old Wed, Oct-22-2008, 02:47:37 AM   #4
mahatma inc
mahatma inc's Avatar
Reputation: 0 mahatma inc is on a distinguished road
got the same problem. im going to the dealer asap.
Jump to top mahatma inc is offline   Reply With Quote
Old Wed, Oct-22-2008, 02:45:54 PM   #5
Doru in Romania
Doru in Romania's Avatar
Reputation: 0 Doru in Romania is on a distinguished road
Romania
don' worry, peformed a full software update and it's cured. had same issue.
2009 X6
2009 118
2008 M3 - sold the damn thing
2008 K1200GT (bike)
Jump to top Doru in Romania is offline   Reply With Quote
Old Wed, Oct-22-2008, 09:53:42 PM   #6
SteDevote
Recovered M3 User
SteDevote's Avatar
Reputation: 0 SteDevote is on a distinguished road
Cool
Originally Posted by ronin009 View Post
good stuff Rez
If guns kill people,
pencils cause spelling errors.
Jump to top SteDevote is offline   Reply With Quote
Old Thu, Oct-23-2008, 09:23:21 AM   #7
alian
alian's Avatar
Reputation: 0 alian is on a distinguished road
Had similar issues. Car had sleep over at local dealer getting re-programmed.
Feels like a different vehicle - but still with all the awesome attributes.
Get the update..........
Jump to top alian is offline   Reply With Quote
2008, stalling, week
Marv800's Week 5 NFL Lock of the Week! marv800 Off Topic 8 Mon, Oct-08-2007 05:40:36 PM
Marv800's Week 3 NFL Lock of the Week! marv800 Off Topic 11 Mon, Sep-24-2007 02:26:22 AM
Marv800's Week 2 NFL Lock of the Week! marv800 Off Topic 16 Sat, Sep-22-2007 08:52:19 PM
Week of Sept 24, 2007... Ungodly, epic, incredible week coming up!!! marv800 Off Topic 13 Sat, Sep-08-2007 03:02:30 AM
Marv800's NFL Week 15 Lock of the Week marv800 Off Topic 8 Mon, Dec-18-2006 02:43:51 AM
Powered by vBulletin® Version 3.8.4
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
Copyright ©1999-2010 M3Forum.com
