Old Wed, Oct-15-2008, 01:28:13 AM   #1
Surk///M
Reputation: 0 Surk///M is on a distinguished road
Default DIY--E46 M3 Thermostat & W\Pump Replacement
Since my car started overheating recently..what I thought was just a thermostat, became a W\pump replacement also..so I thought I'd add this DIY for the E46 M3 T-stat and W\pump replacement. My car is a 2001 with 88k miles, so preventatively I would suggest owners consider doing this DIY anywhere from 75-100k miles.
TOOLS:
VARIOUS--3/8 ratchet, 8-10-13mm sockets, T50 Torx socket, Pliers,
32mm wrench for clutch fan removal, BMW antifreeze x2, distilled water x2,
Thermostat Replacement ONLY >> Difficulty=4\10
BMW Parts req'd--
11531318274 x1--Thermostat
11531318402 x1--Thermostat O-ring
11537830709 x2 --O-ring for water pipe
BMW Antifreeze & distilled water, 1 bottle Redline Water Wetter (if in hot climates)
Jack the front of car up and support properly
1) Remove airbox completely and fan shroud, clutch fan removal (easier)
2) remove 3 top 10mm bolts where engine hook is located at thermostat, have catch pail cans avail as their will be coolant spillage.
3) remove both hose clamps to the thermostat housing (once shroud is removed for access)
4 Remove the 3 long 10mm bolts securing the thermostat housing and pull towards front of car to dislodge sealing O-ring in back pipe.. Remove housing along with T-stat.. I marked the location of the original T-stat being it was in a 1:35 pm "clocked" location on the housing..
4) Fit new T-stat and T-stat O-ring seal into housing, clock according to your markings.. replace rear pipe O-ring(s) lube with dish soap, re-install pushing fwd, and sequence torque 3 bolts to 11 Ft\Ibs or 15Nm.
5) SLOWLY refill system through reservoir using your 50/50 mixture of BMW coolant, bleed according to this helpful link http://home.kc.rr.com/blankpages/M3/...hange_DIY.html and monitor temp guage RECHECK after car has cooled\warmed over several few days. (3 drive cycles of overnight cooling)
WATER PUMP Replacement >> Difficulty level=5\10
PARTS:
11517838159 x1 W\Pump
11517831099 x1 Gskt
11537830712 x2 O-rings at w\pump sides
1) Follow above T-stat removal that will expose the W\Pump.. Remove the 4x 10mm w\pump pulley bolts, relieve the belt and tension by disconnecting the belt at the tensioner..After you remove the belt pulley, you will see 5 x10mm bolts that secure the w\pump (1 is hidden directly under the shaft) pull the w\pump fwd, while pulling the leftside water pipe feed outwards (Left side) with your free hand.
2) Now is a good time to consider a Complete Coolant Flush especially if like me I had leftovers from my impeller in my old coolant, also examine the condition of your idler & tensioner pulleys and belts..it's a good time to replace them also since you have things apart. Replace all the O-rings I noted in my pic, and pre-lube with liquid dish soap to aid in re-install.
Tighten w\pump securing bolts to 11 ft|Ibs or 15Nm .. re-install fan, shroud,airbox, lower panel etc..and refill according to above Flush DIY.
3) *OPTIONAL*--Since I had the engine drain bolt removed doing a complete coolant flush, I also decided to rinse the RAD and Engine block (through the t=stat housing to cyl head pipe using a garden hose) Was surprised to see lots of crap\sediment come out that I would've missed otherwise)
4) Reinstall in reverse of removal, refill system slowly, thoroughly bleed system and recheck for a few days after a few heat\cool cycles..
***Hope this helps those whom are DIY inclined,..I would give this a 4.5\10 for difficulty depending on experience, it's pretty straight fwd once everything is exposed. Takes approx 2-4 hrs depending on facility--take your time and enjoy the fact that once done..you $aved yourself $$$ and can spend it towards other important mods.
Jump to top Surk///M is offline   Reply With Quote
Old Wed, Oct-15-2008, 01:33:54 AM   #2
babydevilj
Sperm Dispenser
babydevilj's Avatar
Reputation: 0 babydevilj is on a distinguished road
how much is the pump and the thermostat? good reminder + writeup. is the new pump a metal impeller or plastic?
Jump to top babydevilj is offline   Reply With Quote
Old Wed, Oct-15-2008, 01:41:09 AM   #3
Surk///M
BMW Oem pump is the expensive parts of this job... can't imagine what dealer would have charge.. New pump is updated..looks like a stronger composite design..
JVT headers--HF Cats--SS MidPipe--AP Muffler--BMC Filter & Elbow--CSL Custom mapped Software--///M 4.10 Diff--PSS9 Coils--ECS 2 pc Rotors--Stoptech Pads--RE RTAB--PF FCAB--Rogue SSK--HID Fogs
Old Wed, Oct-15-2008, 01:43:26 AM   #4
hogger453
hogger453's Avatar
Reputation: 0 hogger453 is on a distinguished road
Bulgaria
Did mine at 45,000. My new pump came with a plastic/compostie impeller. Good DIY.
Pretty straight forward job.
Two possibilities exist:
Either we are alone in the universe or we are not.
Both are equally terrifying.
Arthur C. Clarke
Jump to top hogger453 is offline   Reply With Quote
Old Wed, Oct-15-2008, 02:26:22 AM   #5
m3 guy
Praise the good blood!
m3 guy's Avatar
Reputation: 0 m3 guy is on a distinguished road
Thanks for the write up. I will be doing this soon along with my zionsville radiator. Any other tips?
2010 E60 M5 Saphire Black-Black JOURNAL
2012 E70 X5M Monte Carlo Blue-Silverstone JOURNAL
2013 F30 335 Estoril Blue-Black SOLD
2001 E46 M3 Oxford Green Metallic II-Cinnamon SOLD
Jump to top m3 guy is offline   Reply With Quote
Old Wed, Oct-15-2008, 02:34:28 AM   #6
B1mmerM
'11.5 E92 M3, '05 X5 4.8is
B1mmerM's Avatar
Reputation: 0 B1mmerM is on a distinguished road
Great writeup, thanks for the contribution.
Drives: '11.5 Interlagos Blue E92 M3, '05 LeMans Blue X5 4.8is
Sold: '03.5 Mystic Blue E46 M3 | Angel Eyes DIY
Jump to top B1mmerM is offline   Reply With Quote
Old Wed, Oct-15-2008, 03:08:36 AM   #7
Surk///M
Just take it slow and dbl check your work..I changed my tensioner idler also while in there since I find the worst of this job is fan and shroud removal= PITA..
Old Wed, Oct-15-2008, 04:33:09 AM   #8
playskool1
NorCal's S54 S65 S85 Rod Bearing spc.
playskool1's Avatar
Reputation: 0 playskool1 is on a distinguished road
+1 for the write up. could come in handy in the future.
01/01 build date[LSB][Cinn.][6 Spd.]MAXIMUM PSI TURBO 14psi PT6266 [230k total miles][original motor]
[115k supercharged miles][17k E85 miles][9k turbocharged miles][1.9k track miles]
INSTAGRAM: @skweakykleen
Full Beisan VANOS overhaul, TMS Subframe Reinforcement, WPC rod bearings = bulletproof
fully built S54 w/ Precision 6870 coming soon!
Jump to top playskool1 is offline   Reply With Quote
Old Wed, Oct-15-2008, 04:48:12 AM   #9
leletyM3
640rwhp
leletyM3's Avatar
Reputation: 0 leletyM3 is on a distinguished road
Italy
Great DIY!!! I hope I won't have any problem on my car.
05 BMW ///M3 SMG -->now 6MT - Jet Black/Gray
08 BMW ///M5 6MT - Sapphire Black/Gray
HPF Stg2 Turbo Kit 640rwhp, HPF Stg2 Feramic Clutch, HPF Carbon Fiber Stg3-4 Intake,HPF Catch Can, HPF Carbon Fiber Air Duct, HPF Methanol Switch, HPF Under Brace, HPF Subframe Kit, Custom AEM UEGO and AEM Boost Gauge in the OEM Mirror, Okada Plasma Coils, Eisenmann Race 83x4, Bilstein PSS9, Volk TE37 Time Attack, Toyo 275/30/19 & 245/35/19, Brembo BBK 380mm 6 pots & 345mm, Hardwired V1, 6K HID bulbs, 6K HID Fog Lights, 6K Umnitza Orion V2, Depo Smoked Corners, Solaris Bulbs, Full LEDs interiors,Umnitza LED licence plate lights, 30% Tint All Around, V-CSL V2Front Bumper with Race Lip, OEM CSL Bootlid, V-CSL Diffuser, ///M3 Monochrome, Flat Black Kidneys & Side Grills, Carbon Fiber BMW Emblems, Powerflex RTABs, Dension Ipod ICE>Link Plus, AudioControl unit, Phoenix Gold 600Ti, JL Audio 12W6v2
Jump to top leletyM3 is offline   Reply With Quote
Old Wed, Oct-15-2008, 12:45:48 PM   #10
Surk///M
Moderators >> Plz move this to DIY section
diye46, replacement, thermostat, wpump
Smg Pump Replacement Diy Feeler mr.andersen Faults, Fixes and DIY 82 Mon, Jan-22-2018 10:05:46 PM
Need Help: DIY for DMTL Pump replacement IR M3 Faults, Fixes and DIY 5 Sat, Aug-28-2010 05:55:38 AM
Anyone interested in E46 M3W\pump & thermostat DIY? Surk///M E46 M3 (2001-2006) 13 Wed, Oct-15-2008 12:12:58 PM
Anyone know where I can get the water pump thermostat? MRaty E46 M3 (2001-2006) 1 Mon, Oct-08-2007 04:18:35 AM
Need DIY for E46 M3 water pump and thermostat install / replacement ninekrpm Faults, Fixes and DIY 7 Mon, Aug-06-2007 03:44:34 AM
Discussing DIY--E46 M3 Thermostat & W\Pump Replacement in the E46 M3 (2001-2006) Forum - Engine: S54 - Max Hp: 333 hp at 7,900 rpm / 262 lb/ft at 4,900 rpm
