Old Fri, Sep-19-2008, 02:12:30 PM   #1
Miami M3
If I only Had Gummybears ...
Miami M3's Avatar
Reputation: 0 Miami M3 has disabled reputation
Switzerland
Default Why Doesn't My Passenger Side Mirror Tilt in Reverse Anymore?
it always tilted in reverse when the mirror switch was in the drivers position and the car was in R
now, nothing -- have no idea why the tilt function became inactive
i searched, but only found threads about adjusting the tilt feature -- i just want it to tilt the way it did before
Official Boobie Connoisseur Number Fifty-Four
Jump to top Miami M3 is online now   Reply With Quote
Old Fri, Sep-19-2008, 02:31:29 PM   #2
djm3
CSL (finished) inside
djm3's Avatar
Reputation: 0 djm3 is on a distinguished road
Shouldn't the switch be in the passenger position for it to work? If reprogramming at the dealer doesn't work you may have a bum window motor.
Jump to top djm3 is offline   Reply With Quote
Old Fri, Sep-19-2008, 02:36:50 PM   #3
Miami M3
Miami M3's Avatar
Switzerland
nope, it works in the drivers position
as for the motor, cant be bad since it works (just not the auto tilt function)
Old Fri, Sep-19-2008, 02:45:21 PM   #4
NETO
Reputation: 0 NETO is on a distinguished road
hmmm my passenger's side mirror vibrates as it tilts down. Miami M3, did yours do the same before it crapped out?
if your in the south FL. area, and ur car is still under warranty, why don't u try taking it to South Motors BMW?
Jump to top NETO is offline   Reply With Quote
Old Fri, Sep-19-2008, 03:31:10 PM   #5
Miami M3
Miami M3's Avatar
Switzerland
not under warranty - and the mirror motor WORKS -- just not the auto tilt function
Old Fri, Sep-19-2008, 03:51:40 PM   #6
roobe16
Certified Naysayer
roobe16's Avatar
Reputation: 0 roobe16 is on a distinguished road
Antarctica
Are you using a different key than before? Maybe the memory settings in the key are different...?
Jump to top roobe16 is offline   Reply With Quote
Old Fri, Sep-19-2008, 04:29:23 PM   #7
Miami M3
Miami M3's Avatar
Switzerland
same key
Old Fri, Sep-19-2008, 04:30:45 PM   #8
F1benz
F1benz's Avatar
Reputation: 0 F1benz is on a distinguished road
I think it only works when in the drivers position. mine won't auto tilt in the passenger's position either. i'm assuming since it's only the passenger side tilting, when in the passenger position, it thinks you want to adjust, so it won't auto-tilt. personally, i don't know why there isn't a neutral position, because when i rest my knee on my door handle, sometimes, it get's in the way.
Jump to top F1benz is offline   Reply With Quote
Old Fri, Sep-19-2008, 04:53:16 PM   #9
m3grl
m3grl's Avatar
Reputation: 0 m3grl is on a distinguished road
Does your backup lights work ? May be the reverse switch in the trans.
2002 E46 M3 AW
1995 E36 M3 gone
2006 E46 M3 gone
2004 E46 M3 gone
1998 E36 M3 gone
1995 325i gone
1994 318i gone
Jump to top m3grl is offline   Reply With Quote
Old Fri, Sep-19-2008, 06:20:42 PM   #10
Miami M3
Miami M3's Avatar
Switzerland
i will check later
and just so i am clear, because based upon some responses, i must not have been clear
1) my passenger side mirror motor works - i can still adjust the mirror manually
2) i have the mirror switch set to the drivers side
3) when i put the car in reverse, the passenger side mirror does NOT tilt
4) i've had the car nearly 3 years and the passenger side mirror ALWAYS use to tilt
-- i am trying to figure out why the passenger side mirror no longer tilts when i put it in reverse
Passenger Mirror Reverse Tilt m///tre E46 M3 (2001-2006) 3 Sat, Jul-07-2007 06:04:40 PM
Mirror Reverse Tilt Problem discochan E46 M3 (2001-2006) 2 Sun, Mar-11-2007 09:34:21 PM
Adjusting passenger side mirror tilt Beowoulf E46 FAQ 1 Sat, Jan-28-2006 12:04:37 AM
Reverse Tilt Mirror, Question Unanswered in Search..sort of sk8ermoo E46 M3 (2001-2006) 42 Thu, Sep-16-2004 07:10:24 AM
Passenger mirror tilt adjustment BoxsterSBoy E46 M3 (2001-2006) 1 Sat, Mar-02-2002 09:34:00 PM
Discussing Why Doesn't My Passenger Side Mirror Tilt in Reverse Anymore? in the E46 M3 (2001-2006) Forum - Engine: S54 - Max Hp: 333 hp at 7,900 rpm / 262 lb/ft at 4,900 rpm
