I recently had new tires put on my 2003 M3. Now, the low tire warning sensor keeps going off after 10 or so miles after resetting. Tires holding constant pressure. Any ideas or remedies are appreciated. I noticed that my metal valve stem caps were replaced with plastic caps. Does that effect the signal?
Thanks! JW |
Practice using the search function:
http://www.m3forum.net/m3forum/showthread.php?t=211011 http://www.m3forum.net/m3forum/showthread.php?t=219379 |
Slow in fast out
![]() Location: San Diego (Solana Bch)
Plastic caps will not affect it.
What pressures are you running and what size tires did you get (in case they are wildly off the norm)?
Clint 2012 Alpine Wht E92 M3 DCT ZCP 2003 Topazblau 6MT (Past) Mods: stuff |
| What is the best tire/tire size drag radial I can put on a OEM 18" rear tire? | yellowssm | E46 M3 (2001-2006) | 13 | Thu, Sep-11-2008 03:15:55 AM |
| tire sensors- (TPMS where is it located?) | kewlwhip | E46 M3 (2001-2006) | 5 | Mon, Mar-24-2008 11:01:13 PM |
| Tire sensors | ethersage | E46 M3 (2001-2006) | 2 | Fri, Oct-05-2007 08:12:23 AM |
| o2 sensors | Rob Himself | E36 M3 (1992-1999) | 7 | Tue, Oct-31-2006 07:40:13 PM |
| how do tire pressure sensors | PSC23M3 | E46 M3 (2001-2006) | 8 | Wed, Aug-27-2003 12:09:58 AM |
