E36 M3 (1992-1999) {Euro - S50 B32 321hp @ 7400 rpm} {U.S. - S52 B32 240 hp @ 6000 rpm} Total Produced: 71,212 - Years Produced: 1992 to 1999 |
The Curmudgeon Cop
![]() Location: Upper Midwest
As my "Euro Clear PI(T)A" thread stated, I've been plagued with electrical gremlins of all sorts ever since I swapped out the OEM ambers for Euro Clears. I was able to eliminate most of them by swapping out blown fuses in 23, 34, and (I think) 37. With that said, why would I blow fuses swapping out the lenses if the bulbs were the correct ones (i.e., they now work without switching out locations)?
Now the one remaining electrical problem: My left turn signals do not work. That means the front, sidemarker, and back turn signals are out. The green left arrow on the dashboard is out, too. That leads me to believe the switch (relay?) got fried. So my question is this: Where are the electronics associated with the turn signals? I'm hoping you'll tell me they're in the engine bay because I don't want to have to tear my whole dashboard apart. If someone knows, please take a picture and send it my way. I wish I had just gone with OEM. This "simple" installation has led to two+ days of wasted time and energy.
"The descent to hell is easy. The gates stand open day and night. But to reclimb the slope and escape to the upper air: This is labor." --Virgil, Aeneid, Book 6 Rob 1999 BMW ///M3 ![]() |
Sponsored Links |
The Curmudgeon Cop
No one?
booooooooooooooost
Wish I could help, but I've never ran into this before .. maybe this will help though.
Looked around and I don't see a relay specifically referencing turn signals, but your relays are in the same box as your fuses, which is in the engine bay at the rear corner (I think driver's side, but I forget and I'm about 600mi away from my E36 ![]() ![]() Should be a label in there stating what each fuse is as well .. but sounds like you've already been in the fuse box. No clue where all the other electronics are that are associated with turn signals ..
![]() 2001 E46 M3 SC ESS VT2-525 with pretty much everything else done 2009 E90 335i xDrive (Daily) with JB4 and DCI 1995 E36 M3 (indefinite hiberation) with Garage-Built Hodgepodge Turbo and more mods than I can remember anymore; 415whp/371wtq @ 12psi 2000 E39 M5 (sadly gone; traded in for 335) with Magnaflow exhaust that I miss the most and would buy another in a heartbeat |
#4 |
I couldn't find the sports car of my dreams, so I built it
There are multiple ways (at least the way my car is wired) to connect the turn signal. There are 3 pins that need to be wired. One controls the turn signal and then one controls the parking lights, and on the is ground. Not sure on the voltages of the pins.
The fog lights should be unrelated to this issue - unless you did something else to them. Did you turn the foglights off in the cabin? The green light on the dash will be on regardless of if your foglights are working. Check all the fuses related to lighting as well. The fuse box is on the driver's side of the engine compartment. It could just be a coincidence that the foglight dash bulb burned out at the same time as you install.
-Derek Prior BMWs: E36 M3 E86 Z4MC E92 M3 |
#5 |
The Curmudgeon Cop
I think I found it. As SOnik stated, it was in the fuse box. It's a relay labeled "2/4 x 21W + 0-5W" and it has part number 1 388 533. It's number 7 in the diagram below.
#6 |
![]() Location: Sykesville
Did you go with OEM clears or aftermarket clears??
///M3 12 MB E63 AMG 95 Toyota Supra TT 95 BMW M3 95 BMW M3 boosted 83 Porsche 911SC Past M3s 08 E90 BMW M3 05 E46 BMW M3 02 E46 BMW M3 97 E36 BMW M3 ![]() |
#7 |
The Curmudgeon Cop
Here's one from BavAuto but it doesn't have the same part number. Maybe that's because the OEM model was made by Siemens and the one from BavAuto is not. The damn thing is $49! A couple more dollars and I could have had the OEM clears which wouldn't have blown the relay in the first place.
#8 | |
![]() Location: Sanford
![]() Quote:
#9 | |
Team Nexen Racing
that sounds like a case of crappy lights, bad bulbs and confusion.
![]() Current - '99 estoril/mulberry coupe || Past - '97 alpine/anthrazit coupe || 10,000+ post club || OG club Quote:
#10 |
TEAM OEM
![]() Location: Los Angeles
How much did you 'save' by not going OEM?
Bookmarks |
Tags |
left, signal, turn |
Thread Tools | |
Display Modes | |
Thread | Thread Starter | Forum | Replies | Last Post |
M3 Turn Signal Out OR IS IT? | Viper966 | E46 M3 (2001-2006) | 10 | Sun, Jan-30-2011 04:52:15 PM |
Turn signal | awesome83 | E46 M3 (2001-2006) | 4 | Thu, Aug-21-2008 11:18:59 PM |
Left turn signal doesn't work PLEASE HELP :) | Carnag3 | E46 M3 (2001-2006) | 9 | Fri, Mar-21-2008 01:36:51 AM |
Dim Turn Signal | stocksure | Faults, Fixes and DIY | 2 | Tue, Oct-03-2006 04:06:01 PM |
Red Left Turn Light, no Traffic: Turn or no turn? | Kevin034 | Off Topic | 8 | Wed, Apr-07-2004 05:25:39 AM |
