Old Sat, Jun-14-2008, 02:37:03 AM   #1
Anubis
Dr. Awesomesauce
Anubis's Avatar
Default [DIY] E36 Underhood Lamp Retrofit (Pics!)
Ok. So. Many of us have noticed that there's an odd rectangle in the hood liner and hood sheet metal with nothing in it. On Euro cars, there was a little lamp in there that turns on when you turn on the parking lights. The light extinguishes when the hood is closed, or when the parking lights are off.
Parts required and approximate prices:
Parts from BMW (buy this stuff from Tischer):
-Engine room light assembly
63 31 8 350 554
$8.10
-Engine room light switch
61 31 8 360 875
$3.08
-Bulb 12V 10W
63 21 7 160 912 (or 07 50 9 063 577 - same part)
$1.39
-Rivet
65 75 8 357 500
$0.72
-Female Pin (Qty. 2) [Called 7-CBL SOCKET by BMW]
61 13 1 376 202
$0.74 ea.
Total cost from BMW: $14.77.
Parts from radio shack:
-Tap-in (18-22 Ga.) connector, to tap into parking light
-Insulated 1/4 inch female tab connector, to connect to switch
-Shrink tubing, to cover BMW pins
-Approx. 20 feet of cable, 18 gauge, solid (Better if this cable is black, mine is red as you can see in the DIY)
-Black tie-wraps (no more than 10 needed)
Most this DIY can be found at http://www.unofficialbmw.com/e36/ele...ood_light.html. I've copied a bit of the relevant text and added it to my own write-up. Credit for this procedure goes to Ron Stygar, who wrote the DIY from which I worked.
Step 0: The hood liner has a serrated rectangle directly above the valve cover. If you look into it, you will see a similar rectangle in the hood sheet metal below the hood liner or above the hood liner depending how you look at things. The engine room light assembly will end up snapping into this hood liner sheet metal rectangle with its connector end facing away from the nose of the car (at least in my case, it might be reversed on your car).
Step 1:
Examine parts. Note the two female connectors. These will connect to the two male pins on the bottom side of the lamp itself. Note the bulb. Insert the bulb into the light, and put the plastic cover on. It should snap on. Push the female connectors onto the male pins at the bottom of the light.
Step 2:
Cut your wire into two equal length strands, approx. 10 feet. Strip one end of each wire (strip approx. 1/2" inch) and insert the stripped ends into the female connectors. Use needlenose pliers on the two sets of small tabs at the near ends of the female connectors to clamp the wire into place. Slide two pieces of shrink tubing (3" long each) down the length of each wire and cover up the entire connection from the male pins to the part of the wire that's unstripped.
Step 3:
Open the hood. Look above the passenger side high-beam. You will see two 1/4 inch holes and a dimpled smaller hole to the right of the 1/4 hole closest to the front of the car. The dimpled hole is the switch mounting screw hole. The screw is the same as the one used in the trunk light switch. You can use any screw you like, as long as it isn't longer than, say, 1". Before you screw the switch in, however, you have to enlarge the hole to its left.
Step 3.5:
Get a drill and a towel (you can see above where the towel goes, so as to not get bits of metal everywhere). Get a 3/8" or better yet, a 7/16" drill bit. The 1/4" hole to the left of the dimpled screw hole has to be enlarged to accommodate the switch barrel. Once the hole is enlarged, put the switch in and make sure it fits. Take the switch back out, and leave it aside for now.
Switch test fit (you can see where I've scratched up the area to the left of the switch- BMW touch up paint will do well here later):
Step 4:
Remove the passenger side hood liner. There are a number of small screws and expanding rivets. You will need to remove approximately 7-8. Pull the hood liner down from the passenger side and either have someone hold it up and away, or just push it towards the intake manifold. It should stay.
Step 5:
Insert the other end of the wires through the hood liner sheet metal rectangle and snap the light assembly in place. Follow the wiring down the hood support continuing toward the right front parking light area of the vehicle, tie-wrapping as you go.
Step 6:
Tap one of the two wires coming from the underhood lamp to the front right hand parking light (gray/yellow) wire using one tap-in connector.
Step 7:
Route the remaining wire to the hole which you enlarged for the swich. Crimp the 1/4 inch female tab connector to this wire and attach to the switch. Install the switch.
Step 8:
Turn on your parking lights. Your engine compartment light should turn on. Pressing in the black engine light switch button should extinguish the engine compartment light. If this happens, good job!
Step 9:
Note the presence of a small hole in the hood, right above where the light switch is. This hole does not extend through the hood liner. In my case, this hole was located at the exact spot of the light switch. Cut this exact size hole in the hood liner (make sure it's aligned properly). Install the rivet. Reattach the hood liner. This should depress the switch when you close the hood. It's VERY hard to tell if you've done this right. If you really care, wait until nighttime, turn off ALL the lights around you, and just turn on your parking lights with the hood closed. If you get down under the car and can see the hood light illuminated, your rivet isn't positioned properly or isn't pushing the switch down far enough (it only needs to push it by 1/8" of an inch - barely any force will extinguish it, and I'm not even sure that you need the rivet at all).
And you're done!
Note:
In my photos, you can see my two red wires running from the lamp to the parking light area. I've since wrapped these properly in electrical tape, and clipped them into the stock clips that hold the wiring harness along the passenger side of the hood. It is now basically impossible to tell what I've done, except that there's an underhood lamp now!
1999 Estoril Blue/Dove Grey M3
Old Sat, Jun-14-2008, 02:40:34 AM   #2
PetrolHD
Reputation: 0 PetrolHD is on a distinguished road
nice
Jump to top PetrolHD is offline   Reply With Quote
Old Sat, Jun-14-2008, 02:48:22 AM   #3
thedood
Can't touch this
Reputation: 0 thedood is on a distinguished road
Good stuff, Jeff. I'm still contemplating whether or not to do this, but I think I will once I tackle everything else on my ever-growing list.
Jump to top thedood is offline   Reply With Quote
Old Sat, Jun-14-2008, 04:09:42 AM   #4
Anubis
Dr. Awesomesauce
Anubis's Avatar
Considering that the parts are so cheap, and it really only takes 30 minutes, it's worth it.
Old Sat, Jun-14-2008, 05:07:10 AM   #5
PurduinaM3
Reputation: 0 PurduinaM3 is on a distinguished road
I figured since you whored this DIY out and posted it in like 5 other threads i better post here to make you happy jk jk
Looks good man. I don't really have the need for it so I probably wont spend the money or time doing it, but seems like a great DIY. As for the hood switch, I'm pretty sure I already have one (not sure what for) hooked up, so I'm curious to know if I colud just tap into that.... hmm
Jump to top PurduinaM3 is offline   Reply With Quote
Old Sat, Jun-14-2008, 05:08:18 AM   #6
KnudsonsM3
Reputation: 0 KnudsonsM3 is on a distinguished road
Good DIY man. I wont ever do it but clean job non the less
Jump to top KnudsonsM3 is offline   Reply With Quote
Old Sat, Jun-14-2008, 05:09:19 AM   #7
Anubis
Dr. Awesomesauce
Anubis's Avatar
You're a good man, *****. Err, Bobby.
The hood switch that you already have supposedly is for the alarm. I have one, too. But I don't have an alarm. Oh well.
And yes, you SHOULD do it.
Old Sat, Jun-14-2008, 05:09:20 AM   #8
thedood
Can't touch this
I was wondering the same thing.
Old Sat, Jun-14-2008, 05:13:07 AM   #9
PurduinaM3
Yeah.... see? I don't have a factory alarm either (just an "aftermarket" plug and play keyless thing that works great), but I think that switch should do the same thing. If you think about it, thats all it is, a switch that sends 12v when activated (when hood is open). You should swap the wires on yours and tell us if it works, be a pioneer!!
Old Sat, Jun-14-2008, 05:13:30 AM   #10
Anubis
Dr. Awesomesauce
Anubis's Avatar
It doesn't seem particularly easy to tap into.
Plus, BMW decided to do it this way for a reason, I would assume.
Also - I don't have any alarm, of any kind.
diy, engine bay, lamp, light, underhood
Ultimate LED Retrofit DIY Guide ///PICS BAV_M_PWR Faults, Fixes and DIY 32 Sat, May-31-2008 04:57:10 PM
DIY– TSX Projector Retrofit into ZKW Headlights with Lens “Pupils” (>60 Pics) fivefreshfish E36 M3 (1992-1999) 7 Tue, Aug-15-2006 06:16:28 AM
Finally got the hood popped...pics of the underhood damage Binzes E36 M3 (1992-1999) 20 Fri, Mar-17-2006 12:51:09 AM
DIY Fog Lamp - 1997 E36 M3 djxtc616 Faults, Fixes and DIY 2 Fri, Feb-24-2006 06:02:53 PM
DIY for LED retrofit? AudiOn19s Faults, Fixes and DIY 7 Thu, Apr-21-2005 06:05:32 PM
Discussing [DIY] E36 Underhood Lamp Retrofit (Pics!) in the E36 M3 (1992-1999) Forum - {Euro - S50 B32 321hp @ 7400 rpm} {U.S. - S52 B32 240 hp @ 6000 rpm}
