Go Back   BMW M3 (E30 M3 | E36 M3 | E46 M3 | E92 M3 | F80/X) > BMW M3 Discussions > E46 M3 (2001-2006)
Old Tue, Apr-29-2008, 02:51:39 PM   #1
Reputation: 0 davemulheran is on a distinguished road
United Kingdom
Default Replacing Front Wishbone , Diy>>>
Hi guys
my passenger side bush has gone on the wishbone
Do I have to replace the whole wishbone?
If so, is it an easy DIY job?
has anyone done this before and posted a DIY guide?
all help appreciated and if someone could point me towards a link showing the removal / refitting of the wishbone, IF its been done
Jump to top davemulheran is offline   Reply With Quote
Old Tue, Apr-29-2008, 06:42:03 PM   #2
blue dragon
Proudly Canadian
Reputation: 0 blue dragon will become famous soon enough
You do not need to change the control arm, the bushing is serviceable. The balljoint is not serviceable. Supposedly you can pull the bushing without having to pull the control arm, but its way easier to pull the control arm to do it.
Happiness is not just around the corner, it is the corner!
Jump to top blue dragon is offline   Reply With Quote
Old Tue, Apr-29-2008, 07:53:16 PM   #3
Reputation: 0 martinh has a spectacular aura about
imho, only a DIY if you have access to a lift. It's a major pain to try and take off and install the bushings with little clearance. Also, you'll most likely need a puller to take the old one out.
If I had to do it again, I'd pay someone...
Jump to top martinh is offline   Reply With Quote
Is there a DIY for replacing AC belt? gazosnic E46 M3 (2001-2006) 19 Mon, May-11-2009 04:48:34 PM
anyone have a DIY for replacing the shift lever only? gazosnic E46 M3 (2001-2006) 5 Thu, Feb-28-2008 10:40:55 PM
Powerflex front lower wishbone bushes. steveg E36 M3 (1992-1999) 3 Tue, Mar-08-2005 12:29:01 PM
DIY: Replacing M Badge ///M3 FX Faults, Fixes and DIY 4 Thu, Dec-16-2004 10:13:03 AM
bmw suspension, why dont they use the superior double wishbone on the front? bobe30 General BMW Discussion 7 Tue, Nov-16-2004 11:38:22 PM
Copyright ©2000 - 2018, Jelsoft Enterprises Ltd. and is in no way sponsored, endorsed or affiliated by or with BMW NA / BMW AG or any of it's subsidiaries or vendors.
Copyright 1999-2017
Discussing Replacing Front Wishbone , Diy>>> in the E46 M3 (2001-2006) Forum - Engine: S54 - Max Hp: 333 hp at 7,900 rpm / 262 lb/ft at 4,900 rpm
Total Produced: 45,000+ - Years Produced: 2001 to 2006. at BMW M3 (E30 M3 | E36 M3 | E46 M3 | E92 M3 | F80/X)
