| E90 M3 (Sedan) | E92 M3 (Coupe) | E93 M3 (Convert) (2008-2013) {Engine: S65 - Max Hp: 414 hp (420 hp Euro) at 8,300 rpm / 295 lb/ft at 3,900 rpm} |
![]() Location: Lake Oswego, OR
Thanks to jinxter's impetus, I have installed the Euro rear fog switch. It's really easy. I know he will be following up with a further enhancement of this mod, but I thought I'd post a basic DIY. It's an easy 10-15-minute job.
1) Part number is 61 31 6 932 796, "Control Element Light", $87.40 list 2) Starting at the outside (door side), gently pry out the edge of the trim piece that contains the left air vent. There are two prongs that are a friction fit. 3) Through the hole created, pull out the lower piece containing the light switch. It is a friction fit with 3 prongs. 4) Disconnect the light switch from the panel by depressing and releasing the two tabs on the top and two on the bottom. 5) Disconnect the electrical by rotating the lock lever and pulling out. 6) Connect the electrical to the new switch. 7) Attach the new switch to the panel, making sure each tab "clicks" into the lcoked position. 8) Reinstall the two removed panels by pushing gently back into place. The two rear fogs can now be turned on with the lower push switch. Warning: These are very bright, so only use them when it's really foggy (or maybe some A*hole is tailgating you).
Greg Lake Oswego, Oregon 2008 M3 Coupe - Alpine White/Fox Red/Carbon 2001 M3 Coupe - Titanium/Cinnamon (Sold 3/08) 2006 ML350 - Pewter/Charcoal Alcantara/Aluminum Last edited by GregW / Oregon; Wed, Apr-23-2008 at 02:57:42 PM. |
Inverse Paranoid
wow, i cant believe you are already doing mods like that and I dont even have my car yet!!! blasphemy!
What is the empty space on left? Is something meant to go there or is that just to make it look symmetrical?
08 E92 M3 (Sold 04/2010) ![]() - Space Grey/Fox Red/Carbon Leather, Sunroof, Tech and Premium Package, Ipod, 6spd, and 18s 02 M3 Jet Black/Cinnanmon (Stolen 01/2008) ![]() -19'' BBS LM's, Eisenmann exhaust, PSS9's, UUC SSK, Gone but never forgotten! 98 M3 Silver/Black -stock "If everything is in control, then you aren't going fast enough" Mario A. |
The space on the left has a thumb wheel for adjusting the headlights in some markets--not applicalble to the US with self-levelliing lights.
Greg Lake Oswego, Oregon 2008 M3 Coupe - Alpine White/Fox Red/Carbon 2001 M3 Coupe - Titanium/Cinnamon (Sold 3/08) 2006 ML350 - Pewter/Charcoal Alcantara/Aluminum |
#4 |
640rwhp
![]() Location: Bay Area
Well done!
05 BMW ///M3 SMG - Jet Black/Gray HPF Stg2 Turbo Kit 640rwhp, HPF Stg2 Feramic Clutch, HPF Carbon Fiber Stg3-4 Intake,HPF Catch Can, HPF Carbon Fiber Air Duct, HPF Methanol Switch, HPF Under Brace, HPF Subframe Kit, Custom AEM UEGO and AEM Boost Gauge in the OEM Mirror, Okada Plasma Coils, Eisenmann Race 83x4, Bilstein PSS9, Volk TE37 Time Attack, Toyo 275/30/19 & 245/35/19, Brembo BBK 380mm 6 pots & 345mm, Hardwired V1, 6K HID bulbs, 6K HID Fog Lights, 6K Umnitza Orion V2, Depo Smoked Corners, Solaris Bulbs, Full LEDs interiors,Umnitza LED licence plate lights, 30% Tint All Around, V-CSL V2Front Bumper with Race Lip, OEM CSL Bootlid, V-CSL Diffuser, ///M3 Monochrome, Flat Black Kidneys & Side Grills, Carbon Fiber BMW Emblems, Powerflex RTABs, Dension Ipod ICE>Link Plus, AudioControl unit, Phoenix Gold 600Ti, JL Audio 12W6v2 ![]() |
#6 |
They are not too subtle, actually. I took the photo from above thepoint of direct view and still had to add 5 stops of exposure--they are pretty bright.
#7 |
![]() Location: Columbus
Thanks for the fog DIY.
Where did you get your color corrected halos? How much were they? How did the install go. |
#8 |
![]() Location: California
rear fogs def. wont be subtle!
#9 |
Are the rear fog light bulbs already installed or do you have to change the bulbs after changing the switch ?
#10 | |
Restricted
![]() Location: in your head stealing your thoughts
would love to check her out sometime!!
I've got diarrhea of the mouth....want to listen? |
| Fog Light Install/DIY Help | Zummie | E36 M3 (1992-1999) | 11 | Mon, Mar-14-2011 02:59:56 PM |
| Hid Fog DIY | bigj2637 | E46 M3 (2001-2006) | 12 | Sat, Jul-07-2007 01:46:17 AM |
| DIY Angel Eye Remote Activation Kit ? | BrianSpilner | E46 M3 (2001-2006) | 0 | Mon, Jul-02-2007 07:18:24 PM |
| DIY Fog Lamp - 1997 E36 M3 | djxtc616 | Faults, Fixes and DIY | 2 | Fri, Feb-24-2006 06:02:53 PM |
| Hoen Fog lamps & High beams DIY install? | DCLeopard91 | E46 M3 (2001-2006) | 10 | Wed, Dec-15-2004 06:57:50 AM |
