Old Thu, Mar-27-2008, 09:03:38 PM   #1
Cadeez99M3
170k Club
Cadeez99M3's Avatar
Reputation: 0 Cadeez99M3 is on a distinguished road
Default Gas pedal removal?
How do I remove the gas pedal without breaking it off of it's base? I was able to disconnect it from the upper metal linkage but not at the base. I unclipped the little "switch" at the back of the pedal, but it doesn't budge. Can anyone help me out here?
1999 E36 ///M3 Coupe - Estoril Blau
Jump to top Cadeez99M3 is offline   Reply With Quote
Old Thu, Mar-27-2008, 09:21:39 PM   #2
PetrolHD
Reputation: 0 PetrolHD is on a distinguished road
out of curiousity, why are you removing the gas pedal?
Jump to top PetrolHD is offline   Reply With Quote
Old Thu, Mar-27-2008, 09:25:04 PM   #3
Cadeez99M3
170k Club
Cadeez99M3's Avatar
Instalation of aluminum ///M pedals. The bottom right allen bolt sits flush against the inside of the plastic pedal, can't fit the dremmel in there to cut that piece out so the nut and washer will fit on...
Old Mon, Jan-25-2010, 07:45:05 PM   #4
stubadub
stubadub's Avatar
Reputation: 0 stubadub is on a distinguished road
reviving this old thread in hopes someone has an answer for this removal.
a full write up would be great...
Jump to top stubadub is offline   Reply With Quote
Old Mon, Jan-25-2010, 07:48:26 PM   #5
OahuMPower
:FACEPALM:
OahuMPower's Avatar
no need to remove the gas pedal... if you cant get that bolt to fit, just skip it..
you can't get the gas pedal out without removing the carpet, and you dont want to do that.
Old Mon, Jan-25-2010, 08:18:44 PM   #6
stubadub
stubadub's Avatar
well its more than just that corner....the alen nuts provided are tiny and a pita to put on to begin with and on the gas pedal it has a more honeycomb type backside than the brake/clutch so you cant really get them on correctly anyway unelss i have better access...ill try and take the top piece off in hopes it will rotate backwards toward me.
also having one nut/bolt off will drive me crazy even if i'm the only one who knows or see's it.
-thx for the reply
Old Mon, Jan-25-2010, 08:21:02 PM   #7
srg_23
//M Power FTW
srg_23's Avatar
Reputation: 0 srg_23 is on a distinguished road
I took it off once, dont remember how i did it. i just remember it was a serious PITA
1999 M3 Coupe
Dinan Exhaust, Dinan CAI, Dinan Throttle Body, Dinan Software, Dinan Sway Bars, M50 Manifold,X-Brace, UUC Tran Mounts
Jump to top srg_23 is offline   Reply With Quote
Old Mon, Jan-25-2010, 08:29:06 PM   #8
OahuMPower
:FACEPALM:
OahuMPower's Avatar
I was able to get ALL four of my bolts on....
Old Mon, Jan-25-2010, 08:32:13 PM   #9
stubadub
stubadub's Avatar
well either way i will get all four of mine on....i cant stand half azzz'd jobs and will have none of it. apparently its possible to do no matter the trouble.
Old Wed, Jan-27-2010, 01:44:43 AM   #10
KWorker17
Brett Favre of M3's
KWorker17's Avatar
Reputation: 0 KWorker17 is on a distinguished road
Just took mine off yesterday
http://forums.bimmerforums.com/forum...d.php?t=353811
Kevin
Jump to top KWorker17 is offline   Reply With Quote
gas, pedal, removal
gas pedal removal iigigol0ii E46 M3 (2001-2006) 21 Fri, Sep-26-2008 01:12:06 AM
Anyone ever change their Gas pedal. brake Pedal and Clutch pedal? BigmansM E36 M3 (1992-1999) 3 Mon, Oct-29-2007 05:56:41 PM
FS: Ultimate Pedal - Gas Pedal (E46 M3) ninekrpm Parts for Sale/Wanted 5 Sun, Jun-17-2007 06:09:05 AM
Dead Pedal Removal JIMBOFISHERMAN E46 M3 (2001-2006) 2 Fri, Mar-02-2007 05:38:14 PM
Gas pedal dmg E46 M3 (2001-2006) 2 Sat, Apr-01-2006 10:03:42 PM
Discussing Gas pedal removal? in the E36 M3 (1992-1999) Forum - {Euro - S50 B32 321hp @ 7400 rpm} {U.S. - S52 B32 240 hp @ 6000 rpm}
