Old Wed, Mar-19-2008, 06:56:21 PM   #1
FCars4Ever
FCars4Ever's Avatar
Reputation: 0 FCars4Ever is on a distinguished road
Default Battery Problem with my car?
So today I was driving home from school and something odd happened. My radio randomly went out, my radar went off (Hardwired), and my dash went out. About 5 seconds later the radar came back on, the CD continued playing and my dash lit up again but the mileage/time indicators were reset.
Then I pull in to get some gas and turn off my car but left the key in position 2 and the same thing happened again. The entire dash went black and the radio/radar both went out as well. I turned the key and nothing. Then suddenly everything came back on to normal.
I am guessing this is a problem with the battery, or maybe even the connection. Anyone have any ideas??
2008 Chevrolet Corvette Coupe
Arctic White/Two Tone Red/Black
2004 BMW ///M3 Coupe SMG (SOLD)
Laguna Seca Blue/Black
Jump to top FCars4Ever is offline   Reply With Quote
Old Wed, Mar-19-2008, 07:08:52 PM   #2
bluesting004
Reputation: 0 bluesting004 is on a distinguished road
I had a dumb dumb who had an M leave a piece of metal in the batery conpartment and it was making contact with both poles.
Jump to top bluesting004 is offline   Reply With Quote
Old Wed, Mar-19-2008, 09:18:21 PM   #3
deilenberger
deilenberger's Avatar
Could be battery, could be connections, you'll find out when it does it for good and stops being intermittent.
  • 2001 M-Coupe - TiSilver/Black - Das Boot..
  • 2006 Cayenne/S - Iceland Silver Metallic/Stone-steel Gray - Truckster.
  • 2007 R1200R - Roadster, black mit/white pinstripes - the REAL BMW..
Old Thu, Mar-20-2008, 05:34:15 AM   #4
FCars4Ever
FCars4Ever's Avatar
I'd hate to be in the middle of nowhere when it decided to do it for good.....
Old Thu, Mar-20-2008, 07:23:08 AM   #5
coolmody
Reputation: 0 coolmody is on a distinguished road
Looks like the connections to your battery. They could be loose or dirty. If there is crap on the connections use some battery terminal cleaner and a wire brush to clean them.
My E28 ALWAYS does this, and its so annoying. Happens really often too when the boost kicks in and always causes me to lose races because I lose all power, steering etc. My battery is loose as well because the battery tie down is broken which adds to my problem.
'02 E46 M3 Vert | '85 E28 Turbo
Jump to top coolmody is offline   Reply With Quote
Old Thu, Mar-20-2008, 09:34:14 AM   #6
FCars4Ever
FCars4Ever's Avatar
I'll check this out later today. Thanks for the input
Old Thu, Mar-20-2008, 10:20:49 AM   #7
Carbon Metallic
'02 M3
Reputation: 0 Carbon Metallic is on a distinguished road
It could be the alternator as well. If you bring it to Advanced Auto or something similar they will test your battery and alternator for free.
Matt
Jump to top Carbon Metallic is offline   Reply With Quote
Old Thu, Mar-20-2008, 08:02:19 PM   #8
FCars4Ever
FCars4Ever's Avatar
Would the alternator be covered under warranty if it needed to be replaced?
Old Thu, Mar-20-2008, 08:08:15 PM   #9
deilenberger
If you have a warranty - an alternator would certainly be covered.
Old Thu, Mar-20-2008, 08:13:10 PM   #10
FCars4Ever
FCars4Ever's Avatar
Good to know. I'll have to get it checked out since my warranty is expiring in may
battery problem? Smurthette E46 M3 (2001-2006) 0 Mon, Oct-16-2006 12:56:48 AM
Do you have to unplug battery from car with Battery Tender? custom E36 M3 (1992-1999) 3 Sat, Feb-04-2006 04:09:04 PM
Do I Have Battery Problem???????? Jeff@Fusion E46 M3 (2001-2006) 3 Sat, May-08-2004 05:05:09 PM
Do I Have Battery Problem???????? Jeff@Fusion General BMW Discussion 3 Sat, May-08-2004 05:39:28 AM
help...my battery is gone? or other problem? chohoya E36 M3 (1992-1999) 4 Wed, Nov-12-2003 08:45:35 PM
Discussing Battery Problem with my car? in the E46 M3 (2001-2006) Forum - Engine: S54 - Max Hp: 333 hp at 7,900 rpm / 262 lb/ft at 4,900 rpm
